Near Miss with Caravan. Who was in the wrong?
Codey90
PostPosted: 18:13 - 27 Aug 2019    Post subject: Near Miss with Caravan. Who was in the wrong? Reply with quote
So today driving back from work on my 125, I was driving behind a carvan being towed by a car. The caravan put its hazard lights on and slowed down then swerved to the right hand lane where there was a lay-by. Naturally, I thought it had broken down. Once it was heading for the lay-by on the other side of the road I sped back up as normal to carry on.
The caravan then swerved back to the left and it turned out it was swinging out to make a turn into a side road on the left. Surely they should have just indicated left to indicate they was making a left turn rather than hazard lights? I had to slam all brakes on full, tyre skidding and it was lucky it wasn't worse. The speed I was doing before going into the emergency stop was only 28-30mph.
PostPosted: 18:31 - 27 Aug 2019    Post subject: Reply with quote
You were.
"watch out for long vehicles which may be turning at a junction ahead; they may have to use the whole width of the road to make the turn"
https://www.gov.uk/guidance/the-highway-code/using-the-road-159-to-203
Tyres are not meant to skid in an emergency stop. Wink
PostPosted: 18:33 - 27 Aug 2019    Post subject: Re: Near Miss with Caravan. Who was in the wrong? Reply with quote
In the past I've indicated left and swung out to the right in a long van because I'm turning into a really narrow driveway, for someone to try and nip up the left hand side - then get annoyed when I almost take them out.
I'd say even if it had broken down, it'd be sensible in that situation to hang back until it was very clear what was going on - possibly something had gone wrong enough that you wouldn't want to be close to it.
Also, left indicators wouldn't signal to oncoming vehicles or ones that may and try and pass on the right that they could be doing that - I'd probably just have used left, but I can see why they used hazard lights instead.
Freddyfruitba...
PostPosted: 18:37 - 27 Aug 2019    Post subject: Re: Near Miss with Caravan. Who was in the wrong? Reply with quote
So what you have said if they'd indicated 'left', then pulled out into the right-hand lane in order to make the tight turn (where you would be executing your emergency stop at that point instead?). Likewise, if he'd indicated 'right', you'd have again made an assumption and started to undertake him before slamming on the brakes.
From the point of view of a caravanner (or HGV driver if you prefer - same issue) there's no easy answer - but using the hazards seems a prgamatic solution for at least letting following traffic know that that something's going down and to be on high alert...
Codey90
PostPosted: 18:39 - 27 Aug 2019    Post subject: Reply with quote
Thanks guys, never came across this situation before so a bit of a learning experience. I think it may have just been confusing with the hazard lights and a lay-by being in close proximity. In the future if I see hazard lights I'll slow down to give enough distance until I find out what's going on
grr666
PostPosted: 18:44 - 27 Aug 2019    Post subject: Reply with quote
If he had only flashed a left you might have overtaken and copped it there instead. People towing trailers need
the space to make the turn. His confusing signals were not helpful but the hazards would have had me dropping
back until I was sure what he was doing. He was attempting to communicate with you and was certainly
aware of you. I certainly wouldn't attempt a pass, on either side tbh until I had seen him clear. You lives and you learns.
It's why its good noobs have to ride smaller bikes to learn their chops on. You can't run into trouble nearly as quick. On
a big bike you would have been away lots quicker and straight into the nearside of him. Assuming driver only he would
walk away without a scratch while you may well have needed airlifted out. No harm done this time. Chalk it up, move
on and give trailers (including and especially artics) lots of room at slower town speeds, after all it's only really at slow
speeds that BIG space needing manouvres are attempted. As for big lorries you should try and sit behind an artic far
enough for you to see his mirrors. I tend to sit out to the right of my lane so I'm the first thing he sees in his offside
mirror. Now he can see you too and if he stops suddenly (and 40tonnes with umpteen massive tyres on the
ground and air brakes with ABS can stop surprisingly quickly in wet or dry conditions) and you'll have room to stop too.
We've all ballsed up and got ourselves into a spot. If you see a situation developing and you can't avoid it
sit back, observe, evaluate and then react. If you do the first 3 then the fourth is usually pass without hinderance
anyway as whatever it was has happened and your way is now clear.
Easy-X
PostPosted: 18:47 - 27 Aug 2019    Post subject: Reply with quote
When in doubt, hang back. No sense rushing early to your grave!
iooi
PostPosted: 19:14 - 27 Aug 2019    Post subject: Reply with quote
Spot on.
How many cyclists have been killed failing to take note of a lorry indicating left and crept up the inside only to get squashed.... Laughing
Kawasaki Jimbo
PostPosted: 19:24 - 27 Aug 2019    Post subject: Reply with quote
Although if he'd had a faster bike he'd have been through the gap before... I'm kidding!
It looks like a simple misunderstanding fair enough, but caution is the watchword. However, I do hate hazard lights and I've seen delivery drivers do similar manoeuvres on the High Street excused by hazard lights, as is their subsequent illegal parking Thinking. They tell you little of the driver's intentions and should be reserved for times when the vehicle breaks down in a dangerous spot. I'd have preferred a left indication from the caravanner even if they then go wide.
dynax
PostPosted: 19:34 - 27 Aug 2019    Post subject: Reply with quote
I used to drive a 7.5 with trailer, and if i needed to swing wide, i would indicate which direction first then pull wide if it was safe, worst was having to reverse on occasions, there were some stupid twats that would do whatever they could to get past Rolling Eyes
Mike.
Bikes: Xena, Bridget,Florence
https://www.youtube.com/channel/UCmihUc0xXxYbR4_0l-F1FzA/videos?view_as=subscriber
Teflon-Mike
tl;dr
PostPosted: 19:49 - 27 Aug 2019    Post subject: Re: Near Miss with Caravan. Who was in the wrong? Reply with quote
YOU
Bluntly. Plus you iz on L-Plate which mean 'Learner' so by implication it your fault.
If you check the HWC Haxards shoyuld NOT be used on a moing vehing vehicle ECEPT to inicate sjhowing for a hazed like queing traffoic ob a druel carriagfeway or road works.. its actually not a chjange I like itr was introfuced to legfalikse common practice, and easier than re-educaytiong hundreds of llreaduy qualifoed drivers, but cest la vive, carz is the majority bikes the minoroty you lived,. sop LEARN from it.....
Car was at error 'ish' by your accounbt indication was 'miusleading'cos no road works or quing traffioc BUT a) you stil on a bike so in the wrong untol proven otherwide,. b) on L's so in the wrong tiull proven oytjherwise, twice damned....
You ain dead.. cars do daft things and indicators mean effall in the real world, expecially on anything german or a tow bar... ESPECIUALLUon a tow bat on a bank holiday weekend.. chalkm itr uyp to experience and count your belessiongs anf next tome DONT fcuk with things bigger than you, especually on a draw hitch... they can hurt... Confused
And remember.. "But it was MY right of way" is of small solace when wending your way up the pearly stairs... expecxt the unexpected, and assume YOU are in the wrong is only not making dufficient 'allkowancxe' for the idiocy of others... THIS one would not go in your favour, if YOU do0nt want to get hurt YOU are the one that has to be well above reproach, and from your account, you ent.. but you IS breathin's so learn from it.
1198
PostPosted: 20:16 - 27 Aug 2019    Post subject: Reply with quote
Being right isn’t any consolation when you’re laid on your back alongside a crashed motorbike checking that all your limbs work and you’re not destined to an existence with some poor unpaid sod wiping your arse for you after you’ve had a shit....
adam277
PostPosted: 20:54 - 27 Aug 2019    Post subject: Reply with quote
Definitely you.
But you live and you learn.
It's a tricky one with a long vehicle but he put the hazards on which should of made you aware.
Bikes: Previous Bikes: Piaggio x8 125: 2012/2013, YBR 125: 2013/2013 BMW R1150GS 2013/2017, Honda CBR600RR 2017/2017, Honda CB500 2018/2018, Suzuiki Address 110cc 2019/2020, BMW R1200GS 2021-2023
Current Bike: Honda CBF 125: current
adam277
PostPosted: 20:57 - 27 Aug 2019    Post subject: Reply with quote
The problem with indicating left and going wide is people often think you just indicated in the wrong direction.
I dunno what the rulebook says but says but the hazard lights seem appropriate.
The Highway Code also states that hazard warning lights should not be used while driving or being towed. The only exceptions to this rule are if “you are on a motorway or unrestricted dual carriageway and you need to warn drivers behind you of a hazard or obstruction ahead”. Furthermore, hazard lights should only be used “long enough to ensure that your warning has been observed”.
Regardless I have no doubt many accidents have occurred due to large vehicles having to take turnings wide and other vehicles not understanding this.
Kawasaki Jimbo
PostPosted: 21:17 - 27 Aug 2019    Post subject: Reply with quote
Doesn't what you posted simply confirm that hazard flashers were not appropriate in the situation the OP described?
PostPosted: 21:21 - 27 Aug 2019    Post subject: Reply with quote
They had the desired effect in that they got his attention. Smile
Kawasaki Jimbo
PostPosted: 21:29 - 27 Aug 2019    Post subject: Reply with quote
Brake lights = I'm slowing down.
Indicators = I'm going to turn right/left.
Hazards= Watch this! Take a guess!
PostPosted: 21:37 - 27 Aug 2019    Post subject: Reply with quote
There's the possibility that the wiring from car to caravan was less than perfect so the driver thought he was indicating left. Laughing
OP, had you passed a sign telling you there's a left turn ahead?
adam277
PostPosted: 21:41 - 27 Aug 2019    Post subject: Reply with quote
Maybe, it's open to interpretation.
All I know is I've seen alot of people try to undercut hgvs when they indicate left and take it wide.
With hazards your right it's anyone's guess. It's an unknown so you should slow down and be cautious.
I agree they are overused though. Maybe delivery drivers use them to warn you that they are working /unloading?
doggone
PostPosted: 21:47 - 27 Aug 2019    Post subject: Reply with quote
If I was doing it I'd have left turn on well in advance then use strong road positioning perhaps with hazards and hand signal to reinforce something unorthodox was going to happen.
But chances are they would not be familiar with the road layout so not aware themselves until later than was ideal.
Riejufixing
PostPosted: 21:49 - 27 Aug 2019    Post subject: Re: Near Miss with Caravan. Who was in the wrong? Reply with quote
Who was in the wrong? A bit of both.
The driver should not have been using his hazard lights in that situation. It's against the law.
You should have been a bit more considered in your actions which will come with time I guess.
Kawasaki Jimbo
PostPosted: 21:54 - 27 Aug 2019    Post subject: Reply with quote
The caravan was heading for a lay-by on the right. Reasonable to assume that was the destination. (Also reasonable not to trust it.)
I don't need to know. How many times have you seen a van/truck on the side of the High Street with right indicators on and thought they were going to pull out, only to realise as you get close that both indicators are flashing to indicate, pointlessly, that they are parked.
Codey90
PostPosted: 21:57 - 27 Aug 2019    Post subject: Reply with quote
There were no road signs unfortunately as it was a driveway if you will, a little dirt road leading to a farm.
I could see the road ahead for miles in front and there were no cars coming the opposite direction so a turn signal would have been much nicer and easier to understand
PostPosted: 22:06 - 27 Aug 2019    Post subject: Reply with quote
Towing a caravan is always wrong.
doggone
PostPosted: 22:12 - 27 Aug 2019    Post subject: Reply with quote
Well there is that, but it could have been a tractor with trailer and almost no rear visibility - also highly likely to want to turn off up a rough track or farm road.
The last post was made 6 years, 297 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.85 - MySQL Queries: 13 - Page Size: 136.2 Kb
