| Codey90 |
 Codey90 Derestricted Danger
| Ste |
 Ste Not Work Safe
| G |
 G The Voice of Reason
| Freddyfruitba... |
| Codey90 |
| grr666 |
 grr666 Super Spammer
 Posted: 18:44 - 27 Aug 2019 Post subject: |
If he had only flashed a left you might have overtaken and copped it there instead. People towing trailers need
the space to make the turn. His confusing signals were not helpful but the hazards would have had me dropping
back until I was sure what he was doing. He was attempting to communicate with you and was certainly
aware of you. I certainly wouldn't attempt a pass, on either side tbh until I had seen him clear. You lives and you learns.
It's why its good noobs have to ride smaller bikes to learn their chops on. You can't run into trouble nearly as quick. On
a big bike you would have been away lots quicker and straight into the nearside of him. Assuming driver only he would
walk away without a scratch while you may well have needed airlifted out. No harm done this time. Chalk it up, move
on and give trailers (including and especially artics) lots of room at slower town speeds, after all it's only really at slow
speeds that BIG space needing manouvres are attempted. As for big lorries you should try and sit behind an artic far
enough for you to see his mirrors. I tend to sit out to the right of my lane so I'm the first thing he sees in his offside
mirror. Now he can see you too and if he stops suddenly (and 40tonnes with umpteen massive tyres on the
ground and air brakes with ABS can stop surprisingly quickly in wet or dry conditions) and you'll have room to stop too.
We've all ballsed up and got ourselves into a spot. If you see a situation developing and you can't avoid it
sit back, observe, evaluate and then react. If you do the first 3 then the fourth is usually pass without hinderance
anyway as whatever it was has happened and your way is now clear. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
| Easy-X |
 Easy-X Super Spammer
| iooi |
 iooi Super Spammer
| Kawasaki Jimbo |
| dynax |
 dynax Trackday Trickster
 Posted: 19:34 - 27 Aug 2019 Post subject: |
I used to drive a 7.5 with trailer, and if i needed to swing wide, i would indicate which direction first then pull wide if it was safe, worst was having to reverse on occasions, there were some stupid twats that would do whatever they could to get past  ____________________ Mike.
Bikes: Xena, Bridget,Florence
https://www.youtube.com/channel/UCmihUc0xXxYbR4_0l-F1FzA/videos?view_as=subscriber |
| Teflon-Mike |
 Posted: 19:49 - 27 Aug 2019 Post subject: Re: Near Miss with Caravan. Who was in the wrong? |
| Codey90 wrote: | Near Miss with Caravan. Who was in the wrong? |
YOU
Bluntly. Plus you iz on L-Plate which mean 'Learner' so by implication it your fault.
If you check the HWC Haxards shoyuld NOT be used on a moing vehing vehicle ECEPT to inicate sjhowing for a hazed like queing traffoic ob a druel carriagfeway or road works.. its actually not a chjange I like itr was introfuced to legfalikse common practice, and easier than re-educaytiong hundreds of llreaduy qualifoed drivers, but cest la vive, carz is the majority bikes the minoroty you lived,. sop LEARN from it.....
Car was at error 'ish' by your accounbt indication was 'miusleading'cos no road works or quing traffioc BUT a) you stil on a bike so in the wrong untol proven otherwide,. b) on L's so in the wrong tiull proven oytjherwise, twice damned....
You ain dead.. cars do daft things and indicators mean effall in the real world, expecially on anything german or a tow bar... ESPECIUALLUon a tow bat on a bank holiday weekend.. chalkm itr uyp to experience and count your belessiongs anf next tome DONT fcuk with things bigger than you, especually on a draw hitch... they can hurt...
And remember.. "But it was MY right of way" is of small solace when wending your way up the pearly stairs... expecxt the unexpected, and assume YOU are in the wrong is only not making dufficient 'allkowancxe' for the idiocy of others... THIS one would not go in your favour, if YOU do0nt want to get hurt YOU are the one that has to be well above reproach, and from your account, you ent.. but you IS breathin's so learn from it. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| 1198 |
 1198 World Chat Champion
| adam277 |
 adam277 Spanner Monkey
| adam277 |
 Posted: 20:57 - 27 Aug 2019 Post subject: |
| Kawasaki Jimbo wrote: | | Easy-X wrote: | When in doubt, hang back. No sense rushing early to your grave! |
Although if he'd had a faster bike he'd have been through the gap before... I'm kidding!
It looks like a simple misunderstanding fair enough, but caution is the watchword. However, I do hate hazard lights and I've seen delivery drivers do similar manoeuvres on the High Street excused by hazard lights, as is their subsequent illegal parking . They tell you little of the driver's intentions and should be reserved for times when the vehicle breaks down in a dangerous spot. I'd have preferred a left indication from the caravanner even if they then go wide. |
The problem with indicating left and going wide is people often think you just indicated in the wrong direction.
I dunno what the rulebook says but says but the hazard lights seem appropriate.
| Quote: | The Highway Code also states that hazard warning lights should not be used while driving or being towed. The only exceptions to this rule are if “you are on a motorway or unrestricted dual carriageway and you need to warn drivers behind you of a hazard or obstruction ahead”. Furthermore, hazard lights should only be used “long enough to ensure that your warning has been observed”.
Regardless I have no doubt many accidents have occurred due to large vehicles having to take turnings wide and other vehicles not understanding this. ____________________ Bikes: Previous Bikes: Piaggio x8 125: 2012/2013, YBR 125: 2013/2013 BMW R1150GS 2013/2017, Honda CBR600RR 2017/2017, Honda CB500 2018/2018, Suzuiki Address 110cc 2019/2020, BMW R1200GS 2021-2023
Current Bike: Honda CBF 125: current |
| Kawasaki Jimbo |
| Ste |
 Ste Not Work Safe
 Posted: 21:21 - 27 Aug 2019 Post subject: |
They had the desired effect in that they got his attention.  |
| Kawasaki Jimbo |
| Ste |
 Ste Not Work Safe
 Posted: 21:37 - 27 Aug 2019 Post subject: |
There's the possibility that the wiring from car to caravan was less than perfect so the driver thought he was indicating left.
OP, had you passed a sign telling you there's a left turn ahead? |
| adam277 |
| doggone |
 doggone World Chat Champion
| Riejufixing |
| Kawasaki Jimbo |
| Codey90 |
| doggone |
The last post was made 6 years, 301 days ago. Instead of replying here, would creating a new thread be more useful? |
