Suzuki Master Cylinder circlip 70s
A100man
PostPosted: 13:10 - 29 Aug 2019    Post subject: Suzuki Master Cylinder circlip 70s Reply with quote
Looks like I need to refurb my Gt250 master cylinder . If you know the 70s (Tokico?) master cylinder it has an irritating circlip set deep inside the lever side cavity that also corrodes making it a bastard to get out - even if you have the right pliers.
Tips on removal gratefully received otherwise I may bludgeon it out by knocking the piston through form the outlet end, with a punch.
Riejufixing
PostPosted: 13:24 - 29 Aug 2019    Post subject: Re: Suzuki Master Cylinder circlip 70s Reply with quote
Is that the internal circlip with lugs and holes for circlip pliers?
If so I'd be inclined to warm the whole job up and then let it cool a few times, then wiggle the clip's ends with a pointed thing before getting the pliers on it.
Surely if you bash the thing out, it'll shag (at least) the cylinder?
PostPosted: 13:27 - 29 Aug 2019    Post subject: Reply with quote
Doing a full refurb with new piston?
Hot (near boiling) saturated alum solution will dissolve steel but not aluminium.
A100man
PostPosted: 13:40 - 29 Aug 2019    Post subject: Re: Suzuki Master Cylinder circlip 70s Reply with quote
That's the fella.. Yep - heat and wiggle will come first.
Bashing might just work. I think my brother did this once as he didn't know the clip was in there Shocked ..
I think it deforms just enough to lose its hold - not ideal though more of a last resort.
Alum.. final last resort maybe.. Smile
Riejufixing
PostPosted: 14:33 - 29 Aug 2019    Post subject: Reply with quote
You can probably get better leverage with a pointy thing through one of the holes especially if you've a pellet or strip of some soft stuff to put in the hole as a fulcrum (small strip of aluminium sheetbent into a circlip shape and pushed into the bore?) than you can with pliers, to get the thing started. "Good luck have fun" whatever you do Smile
A100man
PostPosted: 22:37 - 29 Aug 2019    Post subject: Reply with quote
'tis done Smile .
wasn't too bad bad after I got my +2 specs on and had the darn thing out in bright sunlight. Thanks for all the tips.
Pointy thing was indeed needed (bradawl) to 'drill' through the crap/rust in the circlip hole then lever - also some cheap picks I remembered i had.
Sister Sledge
PostPosted: 07:21 - 30 Aug 2019    Post subject: Reply with quote
Might be a good idea to properly protect that circlip somehow for next time it needs removing? I'm thinking a simple smear with the correct lube or something?
CCM 404 DS
PostPosted: 14:56 - 30 Aug 2019    Post subject: Reply with quote
They have a rubber boot over them when new. Probably long gone.
The last post was made 6 years, 307 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 57.23 Kb
