Cylinder Head knackered on a 2000 R6 5EB
MikeyC
PostPosted: 08:41 - 02 Sep 2019    Post subject: Cylinder Head knackered on a 2000 R6 5EB Reply with quote
So my bike hadn't been used for a few weeks. When I went to take it out, it was dead as a dodo. I initially thought it was the battery, so charged it up for a few hours. Still nothing. Bought a new battery, changed it over, still, exactly the same.
Now i'm not technically minded at all, so that's as far as my expertise stretches Very Happy So I got a mechanic over to check it out. He thought it was spark plugs. So he went to change then, but when he did, he did a compression test. All 4 cylinders showing 90psi, which he said is very low. He then basically said I need a new cylinder head. He explained why but if i'm honest, I can't even remember what else he said Embarassed
Problem is, I can't get the bike anywhere to get it sorted. Do i spend a few hundred getting it sorted with the worry that, as an old bike, it's only going to cause me more problems? Do I sell the bike as a non-runner? What to do? Sad
andym
PostPosted: 09:26 - 02 Sep 2019    Post subject: Reply with quote
I believe it should be around 120psi, but it should still run at 90.
PostPosted: 09:35 - 02 Sep 2019    Post subject: Reply with quote
Your bike ran a few weeks ago and now it doesn't start? A knackered cylinder head is not the cause of that and as AndyM says it should still start and run. Low compression could be valves or pistons/rings but your main problem is it's not starting.
Try giving us a better description of the symptoms than 'dead as a Dodo' because that suggests that you get absolutely nothing from the bike even electrically. If it were true you couldn't crank the engine to do a compression test.
What does and does not happen?
MikeyC
PostPosted: 09:42 - 02 Sep 2019    Post subject: Reply with quote
Yeah fair point Embarassed Electrics work - The kill switch is switched off and I then attempt to start her up, I can hear it attempt to start for literally a second, and then nothing. Silence.
Best way I can describe it I guess, is when you try and start a bike and its just cranking over and over but never creates that spark and actually starts? Its that crank noise but I get it once and then nothing.
Does that make sense?!
PostPosted: 09:48 - 02 Sep 2019    Post subject: Reply with quote
Ok, so you have electrics, the bike cranks over but doesn't fire and it only cranks for a second then stops. You've fitted a new battery and it still does the same?
MikeyC
PostPosted: 09:51 - 02 Sep 2019    Post subject: Reply with quote
Exactly that. One thing to add... I bought the bike in Jan after a 10 year break from biking. Once back on, and my nerves had gone, I always felt like something wasn't quite right. Like the bike was being held back in a sense, not at its full potential. But then I thought it was because of my long break. So I wonder if there's been an issue with the bike that's been building? Been a bit of a fair weather biker too, so only used it a handful of times this year, and its kept in a garage the whole time.
PostPosted: 09:58 - 02 Sep 2019    Post subject: Reply with quote
Well no wonder your compression figures are low. To do a compression test you need to spin the engine up on the starter with the throttle held open. If it's only turning briefly you will always get a low figure.
Sounds like the mechanic has seen the chance of a cheap bike by making you believe it's a lot more knackered than it is.
MikeyC
PostPosted: 10:06 - 02 Sep 2019    Post subject: Reply with quote
I wasn't there when the mechanic was working on the bike - he came as a recommendation, so would like to think he wouldn't be like that... plus he didn't tell me he can fix it and didn't charge me anything, as he couldn't fix it. But... who knows!
Problem I have now is, how do I get the bike up and running with not being able to get it anywhere? I don't want to be spending hundreds and hundreds of pounds on a bike that's only worth £1500 either....
jaffa90
PostPosted: 10:56 - 02 Sep 2019    Post subject: Reply with quote
The engine should turn over briskly when pressing the starter button.
Have you good battery connections to the bike?
andym
PostPosted: 11:05 - 02 Sep 2019    Post subject: Reply with quote
A problem I used to have (quite rare now), was every now and then the engine would turn over then just lock up (sometimes with a thump, other times just stop dead), if I pressed the start button the starter would just click, a few rapid presses of the start button would sort it out though.
Also, (and I know there are a lot of people here who will say not to do this), if you know someone who has a car and jump leads, use them to try jumping the bike.
Nobby the Bastard
Harley Gaydar
PostPosted: 14:38 - 02 Sep 2019    Post subject: Reply with quote
I've never had a problem jumping a bike from a running car system.
Triumph Sprint ST 1050
andym
PostPosted: 20:02 - 02 Sep 2019    Post subject: Reply with quote
Me either, but I know there was a thread about it here and a lot of people believed it would fry something on the bike.
BusterGonads
PostPosted: 08:23 - 03 Sep 2019    Post subject: Reply with quote
I never understood that warning either. Car electrics are limited to about 14.8v which is pretty much what all bikes are at when they are running. To be fair, any charged up car battery should whiz a bike engine around without having the car running anyway since by and large, bike engines are a good bit smaller than most cars.
If the op's bike is not spinning over properly with a new battery, or a charged up battery, the first issue is to find out why. Bad earth? Bad solenoid? Once that is sorted and he can spin up the motor, he could eliminate valves/head by putting a teaspoon full of oil down each plug hole and see if the compression improves. If it doesn't, the low compression issue is the valves. If it does, the bores are worn or it has stuck or broken rings. Obviously, the compression test is done with the throttle wide open and all plug leads off. One assumes his compression tester has been calibrated against a known good one.
2023 Royal Enfield Classic 350; 2000 Honda CG125; 1997 Honda Nighthawk CB250
PostPosted: 10:33 - 03 Sep 2019    Post subject: Reply with quote
The thing is, unless the OP's been playing silly buggers and bouncing it off the limiter bending valves etc there's no reason to believe that the non-starting is simply the fault of low compression. It causes lack of power, poor difficult starting, unsteady idle, smoking exhaust etc but it doesn't suddenly turn a bike that starts and runs one week into one that no longer start the next. It's a gradual degradation.
Year 2000 bike is still carbs. OP says it spends long periods standing. Carbs need a strip and service IMO. Failing to crank over is another issue.
stevo as b4
PostPosted: 19:56 - 03 Sep 2019    Post subject: Reply with quote
I once knew of a nutter with an early R6 who always thrashed it and always kept up with his mates on Fireblades, ZX9R's, and GSXR 1000's etc.
I remember him saying something about getting another head, as you get valve seat recession in under 20'000miles from hammering the arse out it it. I didn't think much of it other than that the guy sounded like a nutter, but maybe he was onto something. Yamaha might not have tested 10'000miles of 13000rpm?
Nobby the Bastard
Harley Gaydar
PostPosted: 21:50 - 03 Sep 2019    Post subject: Reply with quote
My exup had valve seat recession. This is why valve clearances tend to get smaller.
It will get to the point that the engine suddenly won't start because the clearances when warm are negative when cold so valves are always slightly open.
The last post was made 6 years, 311 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 92.97 Kb
