| MikeyC |
 MikeyC World Chat Champion
 Posted: 08:41 - 02 Sep 2019 Post subject: Cylinder Head knackered on a 2000 R6 5EB |
So my bike hadn't been used for a few weeks. When I went to take it out, it was dead as a dodo. I initially thought it was the battery, so charged it up for a few hours. Still nothing. Bought a new battery, changed it over, still, exactly the same.
Now i'm not technically minded at all, so that's as far as my expertise stretches So I got a mechanic over to check it out. He thought it was spark plugs. So he went to change then, but when he did, he did a compression test. All 4 cylinders showing 90psi, which he said is very low. He then basically said I need a new cylinder head. He explained why but if i'm honest, I can't even remember what else he said
Problem is, I can't get the bike anywhere to get it sorted. Do i spend a few hundred getting it sorted with the worry that, as an old bike, it's only going to cause me more problems? Do I sell the bike as a non-runner? What to do?  |
| andym |
 andym World Chat Champion
 Posted: 09:35 - 02 Sep 2019 Post subject: |
Your bike ran a few weeks ago and now it doesn't start? A knackered cylinder head is not the cause of that and as AndyM says it should still start and run. Low compression could be valves or pistons/rings but your main problem is it's not starting.
Try giving us a better description of the symptoms than 'dead as a Dodo' because that suggests that you get absolutely nothing from the bike even electrically. If it were true you couldn't crank the engine to do a compression test.
What does and does not happen? ____________________ a.k.a 'Geri'
| MikeyC |
 Posted: 09:42 - 02 Sep 2019 Post subject: |
Yeah fair point Electrics work - The kill switch is switched off and I then attempt to start her up, I can hear it attempt to start for literally a second, and then nothing. Silence.
Best way I can describe it I guess, is when you try and start a bike and its just cranking over and over but never creates that spark and actually starts? Its that crank noise but I get it once and then nothing.
Does that make sense?! |
 Posted: 09:48 - 02 Sep 2019 Post subject: |
Ok, so you have electrics, the bike cranks over but doesn't fire and it only cranks for a second then stops. You've fitted a new battery and it still does the same? ____________________ a.k.a 'Geri'
| MikeyC |
 Posted: 09:58 - 02 Sep 2019 Post subject: |
Well no wonder your compression figures are low. To do a compression test you need to spin the engine up on the starter with the throttle held open. If it's only turning briefly you will always get a low figure.
Sounds like the mechanic has seen the chance of a cheap bike by making you believe it's a lot more knackered than it is. ____________________ a.k.a 'Geri'
| MikeyC |
| jaffa90 |
 jaffa90 World Chat Champion
| andym |
| Nobby the Bastard |
| andym |
| BusterGonads |
 BusterGonads Trackday Trickster
 Posted: 08:23 - 03 Sep 2019 Post subject: |
| Nobby the Bastard wrote: | | andym wrote: |
Also, (and I know there are a lot of people here who will say not to do this), if you know someone who has a car and jump leads, use them to try jumping the bike. |
I've never had a problem jumping a bike from a running car system. |
I never understood that warning either. Car electrics are limited to about 14.8v which is pretty much what all bikes are at when they are running. To be fair, any charged up car battery should whiz a bike engine around without having the car running anyway since by and large, bike engines are a good bit smaller than most cars.
If the op's bike is not spinning over properly with a new battery, or a charged up battery, the first issue is to find out why. Bad earth? Bad solenoid? Once that is sorted and he can spin up the motor, he could eliminate valves/head by putting a teaspoon full of oil down each plug hole and see if the compression improves. If it doesn't, the low compression issue is the valves. If it does, the bores are worn or it has stuck or broken rings. Obviously, the compression test is done with the throttle wide open and all plug leads off. One assumes his compression tester has been calibrated against a known good one. ____________________ 2023 Royal Enfield Classic 350; 2000 Honda CG125; 1997 Honda Nighthawk CB250 |
 Posted: 10:33 - 03 Sep 2019 Post subject: |
The thing is, unless the OP's been playing silly buggers and bouncing it off the limiter bending valves etc there's no reason to believe that the non-starting is simply the fault of low compression. It causes lack of power, poor difficult starting, unsteady idle, smoking exhaust etc but it doesn't suddenly turn a bike that starts and runs one week into one that no longer start the next. It's a gradual degradation.
Year 2000 bike is still carbs. OP says it spends long periods standing. Carbs need a strip and service IMO. Failing to crank over is another issue. ____________________ a.k.a 'Geri'
| stevo as b4 |
| Nobby the Bastard |
The last post was made 6 years, 310 days ago. Instead of replying here, would creating a new thread be more useful? |
