GSX750 Starts fine but will only run on choke.
mike mock
PostPosted: 16:01 - 10 Sep 2019    Post subject: GSX750 Starts fine but will only run on choke. Reply with quote
My GSX750 Starts fine and runs sweetly for the first few seconds, but will only run on choke, then it gets hot and dies.
If I try the throttle it dies.
Ive cleaned the carbs, jets, blown them through, and they are well synched.
Fuel is fresh, vacuum tap works, air filter clean, plugs new...etc..
Anyone got any ideas please?
Mike
RhynoCZ
PostPosted: 16:08 - 10 Sep 2019    Post subject: Reply with quote
Are the jets stock sizes? Is the air filter there and functional, any air leaks before the carburetors (airbox). A huge air leak = a lot of air, would explain why it only runs with choke, that makes the mixture alright enough for the engine to run, by reducing the amount of air coming into the engine.
Did you clean the idle jets, as well? How did you balance the carburetors, when the engine runs only with the choke?
mike mock
PostPosted: 16:10 - 10 Sep 2019    Post subject: Reply with quote
Standard jets, and exhaust.
Just checked the air filter and box. All seems fine.
Nicely screwed in, snug.
Mike
RhynoCZ
PostPosted: 16:26 - 10 Sep 2019    Post subject: Reply with quote
When you took the carburetors apart, did you take out the mixture screws and if so, when you put them back did you tune (turn) them according to what the service manual says?
mike mock
PostPosted: 16:30 - 10 Sep 2019    Post subject: Reply with quote
Yes. 2 1/4 turns.
Mike
RhynoCZ
PostPosted: 16:39 - 10 Sep 2019    Post subject: Reply with quote
Well, the last time I experience poor running (choke only, with backfiring into the airbox), all it took to fix was a yet another clean up and reassembly. The idle jets were still not perfectly clean, although an air compressor was used to blow through them.
Does the engine run smooth, all 4 cylinders?
garth
PostPosted: 16:45 - 10 Sep 2019    Post subject: Reply with quote
Have you ever had it running correctly?
What are the diaphragms like?
mike mock
PostPosted: 16:59 - 10 Sep 2019    Post subject: Reply with quote
Just taken them out for a look. They seem fine.
Mike
mike mock
PostPosted: 17:00 - 10 Sep 2019    Post subject: Reply with quote
Sorry, yes it was running well, The tank had rusted, so I resealed it etc. and it has run well since.
Then it just started doing this weird choke issue thing..
Mike
jaffa90
PostPosted: 17:08 - 10 Sep 2019    Post subject: Reply with quote
"""""""Then it just started doing this weird choke issue thing.."""""
The choke (jets) sound ok to me, try to find why it won`t run on the pilot jets.
Is there room for an inline filter inbetween the tap and carbs?
garth
PostPosted: 17:54 - 10 Sep 2019    Post subject: Reply with quote
Checked the bowl or gauze on the fuel tap?
Checked fuel flow of tap?
Tried running on aux tank?
Fizzer Thou
PostPosted: 21:02 - 10 Sep 2019    Post subject: Reply with quote
It sounds as though the inlet manifold 'O' rings are split,allowing too much air into the engine.Running with the choke on allows more fuel in to compensate a little.
Not sure which model of GSX750 you mean so I found this as a guide
https://www.fowlersparts.co.uk/parts/4514505/gsx-750hfgh-h-1987/cylinder-head
Part #24 on the fiche
Always have a 'Plan B'
The last post was made 6 years, 131 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.34 - MySQL Queries: 13 - Page Size: 70.88 Kb
