| mike mock |
 mike mock L Plate Warrior
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 16:08 - 10 Sep 2019 Post subject: |
Are the jets stock sizes? Is the air filter there and functional, any air leaks before the carburetors (airbox). A huge air leak = a lot of air, would explain why it only runs with choke, that makes the mixture alright enough for the engine to run, by reducing the amount of air coming into the engine.
Did you clean the idle jets, as well? How did you balance the carburetors, when the engine runs only with the choke? ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| mike mock |
| RhynoCZ |
| mike mock |
| RhynoCZ |
 Posted: 16:39 - 10 Sep 2019 Post subject: |
Well, the last time I experience poor running (choke only, with backfiring into the airbox), all it took to fix was a yet another clean up and reassembly. The idle jets were still not perfectly clean, although an air compressor was used to blow through them.
Does the engine run smooth, all 4 cylinders? ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| garth |
 garth World Chat Champion
| mike mock |
| mike mock |
| jaffa90 |
 jaffa90 World Chat Champion
| garth |
| Fizzer Thou |
 Posted: 21:02 - 10 Sep 2019 Post subject: |
It sounds as though the inlet manifold 'O' rings are split,allowing too much air into the engine.Running with the choke on allows more fuel in to compensate a little.
Not sure which model of GSX750 you mean so I found this as a guide
https://www.fowlersparts.co.uk/parts/4514505/gsx-750hfgh-h-1987/cylinder-head
Part #24 on the fiche ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
The last post was made 6 years, 132 days ago. Instead of replying here, would creating a new thread be more useful? |
