Cleaned seized fuel cap lock, now the lock is borked... Halp
NutsyUk
PostPosted: 12:59 - 22 Sep 2019    Post subject: Cleaned seized fuel cap lock, now the lock is borked... Halp Reply with quote
Hias having a perplexing issue...
My fuel cap lock on the er6f 2007 seized up. Over the last few months it progressively got harder to unlock the thing...
So before it was totally seized ive taken it apart to clean it up... Turned out the entire locking area was utterly filled with alu corrosion powder. like chalk...
Anyway.......
I couldnt get the tumbler out of the lock. I saw somewhere about there being spring loaded retainer on the tumbler, and i did see a brass shim that stops the lock endlessly rotating, but I couldnt put it back in with my micro screwdriver... Anyway WD40 and scrubbed as much of the corrosion away as i could... and put it back together...
But heres the real issue... The lock is now free moving. I can open it with a screw driver...
Ive not lost any parts, now its entirely possible this lock was always like this, as before now I never used anything other than the key to open it. But ummmm
2 questions.
How do i get the tumbler out to properly clean it?
And have i some how reset the tumbler and i need to re-pair it with the key some how?
Yamaha FZ8/Fazer800 (split headlight one) 2014, gingerly getting used to the massive increase in HP and not killing myself in the process! That was easy to get used to.
Kawasaki ER6F 2007 650 Gonna sell as a project bike!
Lexmoto XTR S 125 Sold!
Riejufixing
PostPosted: 13:11 - 22 Sep 2019    Post subject: Re: Cleaned seized fuel cap lock, now the lock is borked... Reply with quote
By the "tumbler" do you mean the barrel? That's the thing you push your key into. Unsure how it's retained in your cap, you might find a pin or clip or nut some such thing on the far end from the key hole.
If you get the barrel out and somehow disassemble it, and you get the tumblers back in the wrong positions, the lock (probably) won't open with your key.
Perhaps your best bet, if you want a fuel tank lock that actually locks (can't see much point myself....), a £20 pattern replacement with keys might be an option.
NutsyUk
PostPosted: 13:15 - 22 Sep 2019    Post subject: Re: Cleaned seized fuel cap lock, now the lock is borked... Reply with quote
Yes the bit the key goes into, Ive always called locks tumblers as thats where the key pins go... like an old puzzle tumbler or codex...
Anyway, i couldnt find any real retainer pin...
Riejufixing
PostPosted: 13:43 - 22 Sep 2019    Post subject: Reply with quote
Do the pictures in these give a clue?
https://www.ebay.co.uk/itm/Fuel-Gas-Tank-Cap-Key-For-Kawasaki-ER4N-ER650-ER-6N-ER6F-Ninja-EX650-06-15-BS2/323793003662?hash=item4b6391248e:g:fJMAAOSwwgxcx5oQ
https://www.ebay.co.uk/itm/Fuel-Gas-Tank-Cap-Key-For-Kawasaki-ER400-ER4N-ER650-ER-6N-ER6F-Ninja-EX650-06-15/133082638049?hash=item1efc57e6e1:g:mq8AAOSwt~1dANU-
NutsyUk
PostPosted: 13:51 - 22 Sep 2019    Post subject: Reply with quote
Not really... no
PostPosted: 14:08 - 22 Sep 2019    Post subject: Reply with quote
Why bother?
Who is going to try and syphon at max 15 litres of fuel from your tank. They have to try and open it without a key to force it anyway so it's really going to make no odds.
I would just use as is and use the key to open it.
NutsyUk
PostPosted: 14:11 - 22 Sep 2019    Post subject: Reply with quote
Polarbear wrote:
Why bother?
Or worse some one be a cunt and put a bag of sugar in D:
Nobby the Bastard
Harley Gaydar
PostPosted: 14:13 - 22 Sep 2019    Post subject: Reply with quote
Tbh most bike locks can be opened with a screwqdriver if you add a spanner to the nut bit.
You don't have screwdrivers that have a nut bit? You're toolkit is lacking......
Triumph Sprint ST 1050
Riejufixing
PostPosted: 14:22 - 22 Sep 2019    Post subject: Reply with quote
Yes, you'd then have to clean out your filters and get the sugar out of the tank. Siphon off or tip out the petrol, keeping it for re-use, then wash out the sugar, dry your tank, and away you go.
NutsyUk
PostPosted: 14:25 - 22 Sep 2019    Post subject: Reply with quote
Well actually you dont usually find out you had sugar put in your tank till the engine has seized!
Nobby the Bastard
Harley Gaydar
PostPosted: 14:30 - 22 Sep 2019    Post subject: Reply with quote
How do people find out it can be opened with a screwdriver unless they are going around trying to find a bike that that has a petrol cap that can be opened with a screwdriver?
If they want to steal the petrol it's much easier to just cut the fuel pipe.
Riejufixing
PostPosted: 14:31 - 22 Sep 2019    Post subject: Reply with quote
Why would it do that?
NutsyUk
PostPosted: 14:36 - 22 Sep 2019    Post subject: Reply with quote
Well multiple ways, firstly on an injection bike its god a good chance of clogging up the injectors with syrupy mess...
If it makes it into the valves it cooks and cakes up seizing the valves, and could also seize up the pistons too...
Put sugar in some ones tank you have a very expensive repair job... complete engine rebuild scrubb down and likely will need to replace some parts.
Riejufixing
PostPosted: 14:51 - 22 Sep 2019    Post subject: Reply with quote
NutsyUk wrote:
(sugar) on an injection bike its god a good chance of clogging up the injectors with syrupy mess...
It doesn't do that. Well, yes, the grains of sugar might clog inline filters (like sand would, not with a "syrupy mess") if the fuel pipe out of the tank is right at the bottom, or so much sugar's put in that it fills the tank to that point, but that's all. You'd only need to clean your filters and get the sugar out of the tank.
Nobby the Bastard
Harley Gaydar
PostPosted: 14:52 - 22 Sep 2019    Post subject: Reply with quote
Once again, I'll ask you how many people walk around with a screwdrivers testing petrol caps to see if they can undo them and will add how many have a bag of suger in their pocket?
Unless you've clearly pissed someone off and are expecting retribution?
NutsyUk
PostPosted: 14:53 - 22 Sep 2019    Post subject: Reply with quote
Ha not that i know of :p hopefully..... >.> <.<
Nobby the Bastard
Harley Gaydar
it'll fuck the engine quite badly. Petrol is a incredibly good solvent and sugar will disolve into it readily.
Riejufixing
PostPosted: 14:59 - 22 Sep 2019    Post subject: Reply with quote
Sorry, nope. Try getting some petrol in a jam-jar or something, and stirring a teaspoon or two of sugar into it.
Nobby the Bastard
Harley Gaydar
PostPosted: 15:09 - 22 Sep 2019    Post subject: Reply with quote
So all those stories about putyting sugar inthe tanks of police cars since I was a kid was a lie?
NutsyUk
PostPosted: 15:15 - 22 Sep 2019    Post subject: Reply with quote
Its a really well known way to give some one a really bad time...
PostPosted: 15:18 - 22 Sep 2019    Post subject: Reply with quote
I'll leave this here. It's Honda but I suspwect kawasaki ones will be broadly similar.
https://youtu.be/rNNUJMmEgf4
The tumblers are probably corroded in the "unlocked" position and just need wiggling and spraying with WD40.
NutsyUk
PostPosted: 15:26 - 22 Sep 2019    Post subject: Reply with quote
Thanks, though sadly the kawaski lock is NOTHING like that one Very Happy
PostPosted: 15:45 - 22 Sep 2019    Post subject: Reply with quote
The barrel will be though, you just need to work out what's holding it in.
Found a ZX9 howto but the pics have been ruined by the photobucket of fail.
https://www.zx-9r.net/phpBB3/viewtopic.php?t=42979
MCN
PostPosted: 16:30 - 22 Sep 2019    Post subject: Reply with quote
I was lucky, 350 parts and labour for a Trumpet engine sugar-ized by a lesbian I was shagging. (Sex wasn't all that good.)
Sugar turns to a hard carbon deposit it heated enough. Caramel/Toffee.
DO NOT EAT.
Nobby the Bastard
Harley Gaydar
PostPosted: 16:35 - 22 Sep 2019    Post subject: Reply with quote
MCN wrote:
DO NOT EAT.
Lesbians or sugar?
The last post was made 7 years, 9 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.46 - MySQL Queries: 13 - Page Size: 135.35 Kb
