Head stock bearings - best options?
skyehigh
PostPosted: 12:42 - 24 Sep 2019    Post subject: Head stock bearings - best options? Reply with quote
I'm going to change the head stock bearings on my 91 FZ750 and wondered if anyone has any thoughts on the best make to buy. Pyramid Products @ £28 seem good value or "Japanese made" @£40
Many Thanks
Ray
yen_powell
PostPosted: 13:28 - 24 Sep 2019    Post subject: Reply with quote
I have fitted original ball bearings and tapered after market types to various bikes over the years.
The only difference I have found is that the OE usually have a torque setting, initial and final which I use a carved up socket to apply, this has always been just right, not too tight or too loose. The aftermarket I do by feel, sometimes had to readjust after a test ride.
They all lasted the life of the bike, I have never fitted a set to a bike more than once, I believe this is because I put grease on the things and the factories don't seem to bother.
On most Yamahas I have had to use an expanding type tool to remove the shells from the head stock as there was no edge to place a drift against to drive them out.
XT1200Z and a DR350 in bits
weasley
PostPosted: 13:39 - 24 Sep 2019    Post subject: Reply with quote
Last time I did headset (and wheel) bearings I got the bearing dimensions then went to a bearing supplier for them. They offer them in sealed, semi-sealed, unsealed etc so you get what you want.
Start somewhere like cmsnl, look at the part numbers and track down dimensions, then look at somewhere like Simply Bearings.
xX-Alex-Xx
PostPosted: 20:08 - 24 Sep 2019    Post subject: Reply with quote
Only ever needed to replace one set of head bearings. Just made sure they were tapered, didn't think much about the rest. Latest longer than the rest of the bike 🤐
DILLIGAF
A100man
PostPosted: 21:21 - 24 Sep 2019    Post subject: Reply with quote
FZ750 were shipped with tapered AFAIK. Ebay shows a wide range including KOYO brand for 23 quid. Pretty sure they would do you fine (or the Pyramid parts)
Confusion
PostPosted: 23:57 - 25 Sep 2019    Post subject: Re: Head stock bearings - best options? Reply with quote
Many Thanks
Ray
Koyo tapered roller bearings are:
Still made in Japan.
Of the highest quality.
Original equipment on many Japanese bikes.
Bandit 650SA, ZZ-R1100
PostPosted: 00:54 - 26 Sep 2019    Post subject: Reply with quote
Koyo are run of the mill, not 'highest quality'. They will suffice though.
skyehigh
PostPosted: 13:39 - 28 Sep 2019    Post subject: Reply with quote
Many Thanks Guys - probably go for the pyramid ones as there is 10% off eBay orders at the moment - use code "pleased" at checkout
Robby
Dirty Old Man
PostPosted: 16:17 - 28 Sep 2019    Post subject: Reply with quote
I've used bearings from pyramid loads of times, they're fine.
The last post was made 6 years, 359 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 59.21 Kb
