leaking clutch slave???
Streaky100
PostPosted: 16:32 - 27 Sep 2019    Post subject: leaking clutch slave??? Reply with quote
I changed the clutch fluid in the reservoir on my GPZ1100 and bled it until the biting point was about half way through the lever travel. after a day of riding, the biting point is right by the handle bar. I can't see anything obviously leaking, so could it be the seal inside the clutch slave cylinder and the fluid is just building up inside the engine case?
PostPosted: 16:52 - 27 Sep 2019    Post subject: Reply with quote
The only way to answer that question would be to have a look.
I do wonder if you've fully bled it though, you should be getting pressure from the very top of the lever action. If there is air left in the system, it'll be decidedly odd and will do odd things. Bleed it until no air comes out.
Riejufixing
PostPosted: 16:54 - 27 Sep 2019    Post subject: Re: leaking clutch slave??? Reply with quote
Bleeding the thing should remove all air from the circuit. It shouldn't "adjust the bite point". What else if anything can be changed o be worn? It might be worth looking inside the casing, but if it wasn't leaking before changing the fluid, why has it suddenly changed?
Streaky100
PostPosted: 13:02 - 03 Oct 2019    Post subject: Reply with quote
Sorted it...I think the seal had maybe dried out letting in air. Replaced the seal and sorted it out 😀😀😀
The last post was made 7 years, 12 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 43.74 Kb
