BMW belts (F650CS)
ThatDippyTwat
PostPosted: 19:10 - 27 Sep 2019    Post subject: BMW belts (F650CS) Reply with quote
Looking at buying a commuter hack - F650CS. Bloke says it'll need a new belt, fair enough. But what the actual fuck, how fucking much?
Is there a non-OEM, or cheaper alternative to the OEM one that is nearly 300 beer tokens. Do I remember a reply on here with an alternative, or is that just wishful thinking.
Robby
Dirty Old Man
PostPosted: 16:22 - 28 Sep 2019    Post subject: Reply with quote
There are aftermarket belts for Harleys, usually made by drag specialities. Much googling will be required to see if one will fit the BMW. Hunt around some American bike parts sites and see if you can find anything.
Expect the belt to still be over a hundred quid. They last a long time, but are expensive.
ThatDippyTwat
PostPosted: 16:56 - 28 Sep 2019    Post subject: Reply with quote
Cheers for the pointer. I get £100-£150. but some googling has pointed to the manufacturer (Gates) being very, very strict about exclusivity to BMW, and BMW have jacked the price a few times.
I'll have another look around, but at £300, it's almost what the bike itself is worth, and kills any idea of buying it. I'm not chucking money at a winter hack, and will look for a chain driven 650 instead.
iooi
PostPosted: 17:04 - 28 Sep 2019    Post subject: Reply with quote
If you could find the belt details Size/teeth
You could try a factor that does bearing & drive belts to see if they have anything the same size.
Only worry would be the quality.
A100man
PostPosted: 18:16 - 28 Sep 2019    Post subject: Reply with quote
Could be an urban myth but I've heard said a Renault Clio belt will fit a Ducati 916.. I guessing therefore there might be other parallels..
ThatDippyTwat
PostPosted: 20:23 - 28 Sep 2019    Post subject: Reply with quote
It looks like an F800 one is one tooth longer, and a few mm wider, but can *probably* be made to work, and they're about £100-£150.
Shaft
PostPosted: 23:51 - 28 Sep 2019    Post subject: Reply with quote
I can see how you might be able to take up the tension, but how do you squeeze the extra 'few mm' between the sprocket channels?
Edit: just had a look at a few pictures of F650s and it looks like they only have a flange on the inside of the rear sprocket, so there might be room for some overhang on the outside, although there doesn't seem to be much clearance on the lower guard.
Grubscrew
PostPosted: 10:22 - 29 Sep 2019    Post subject: Reply with quote
Gates, these are THE belt company of global proportion.
FJR1300/CBR1000F
MCN
PostPosted: 12:04 - 29 Sep 2019    Post subject: Reply with quote
https://www.james-sherlock.co.uk/
This chap is handy.
He breaks BMWs for parts.
I use them regularly.
davebike
PostPosted: 08:28 - 30 Sep 2019    Post subject: Reply with quote
Be aware belt change on a F650CS is a real pitta ! it is swing arm out as as there is no main stand it a real long job
Last time we estimated it was £500 in labour + a lot for the belt !
You have to strip the plastics drain the tank and oil remove the battery so you can lay the bike on it side ! Swing arm bolts often sized !
Dave
NC750Xdct + others at work !
[email protected]
PostPosted: 09:03 - 30 Sep 2019    Post subject: Reply with quote
Or, instead of taking the entire bike to bits, you could put the footpegs in the other way round (so they flip down, not up) and stand it on two axle stands... Or go fully old-school and balance the bike on top of a milk crate. Just saying.
davebike
PostPosted: 09:27 - 30 Sep 2019    Post subject: Reply with quote
Bottom of engine is V shaped ! I heard of big V box used but !
Not sure the footrest mounts don't have to come off I years since I done much with a CS!
Dave
[email protected]
ThatDippyTwat
PostPosted: 09:40 - 30 Sep 2019    Post subject: Reply with quote
While I can probably sort it out and get a new belt on it., it sounds like too much bother even for a cheap-arse like me.
The last post was made 6 years, 356 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 76.12 Kb
