Kawasaki Vulcan Clutch Odd Behavior
rebeltaz
PostPosted: 17:00 - 09 Oct 2019    Post subject: Kawasaki Vulcan Clutch Odd Behavior Reply with quote
I need to explain quite a bit here, so please bear with me.
On my 2002 Kawasaki Vulcan VN1500 Classic Fi, the clutch started slipping big time. I rebuilt that, replacing most everything in there. It seemed to be ok for a while, but then started slipping again, a little more at a time until I almost couldn't get it back to my shop.
I've seen something similar happen to brakes when the slave cylinder will stick, so I took that apart, cleaned it, rebuilt it and put it back on. Again, it seemed ok for a while and then started slipping more and more just like last time.
This time, as soon as I got it back to the shop, I broke open the bleeder valve and, sure enough, a stream of fluid shot out as the piston was pushed back by the clutch springs. I took the bike back out immediately and, once again, the clutch was fine. I figured that the clutch hose was clogged. I blew that out and couldn't find anything clogged, so I went ahead and replaced it in case it was collapsing.
Once again, ok and then slipping. This time I broke the banjo bolt loose at the master cylinder. The fluid pushed out the bolt and the clutch worked again. The only thing left was the master cylinder, so I rebuilt that last night. I didn't see anything wrong with that while I was in there - nothing clogged and the rubbers looked fine.
I haven't taken it back out yet, but I have a strong suspicion that I am going to still have this problem. Both because I didn't see anything wrong, but also because after the last to repairs (the clutch line and the master cylinder), when I bled the system it was really odd. I use a vacuum bleeder. I could not get the system to bleed using that, so I reverted to the old pump/hold/bleed/release method. No air, but I still couldn't get a good solid pressure. The weird thing is that if I quit trying to bleed it, the pressure would build up and it will stay that way, unless I break open the bleeder valve, at which time it acts like air is being sucked in and it looses that pressure until it's built back up.
Does anyone have any ideas for if/when this clutch starts slipping again?
Derek Tombrello
www.ShelbyCycle.com (for profit)
www.RobotsAndComputers.com (just for fun)
doggone
PostPosted: 17:10 - 09 Oct 2019    Post subject: Reply with quote
My Bandit 1200 had me changing plates when there was no need, it was the little pushrod which goes through close to the sprocket needed cleaning.
Is the VN shaft though, still might be similar.issue.
rebeltaz
PostPosted: 17:14 - 09 Oct 2019    Post subject: Reply with quote
When you say pushrod, you mean the pushrod that the slave cylinder press against to disengage the clutches? Yes, it is pushrod, but I called myself checking that when I rebuilt the slave cylinder. If it does it again, I'll triple check that, though.
Derek Tombrello
Robby
Dirty Old Man
PostPosted: 20:21 - 09 Oct 2019    Post subject: Reply with quote
Well clearly something is wrong in the hydraulic system. Blocked return hole in the master cylinder could cause it.
PostPosted: 20:39 - 09 Oct 2019    Post subject: Reply with quote
I agree with Robby.
I would be overhauling the mastercylinder as the fluid pressure has to release back into the reservoir which it obviously isn't doing if you have pressure in the system when the clutch lever is released.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:18 - 09 Oct 2019    Post subject: Reply with quote
Thirded, clearly an issue in the master cylinder retaining pressure.
Triumph Sprint ST 1050
rebeltaz
PostPosted: 21:41 - 09 Oct 2019    Post subject: Reply with quote
Well, like I said... I rebuilt that yesterday. I'm going to take it back out tomorrow and see how it does. Thanks everyone.
Derek Tombrello
Stalk
PostPosted: 22:04 - 09 Oct 2019    Post subject: Reply with quote
Probably a stupid question but, is the lever binding? Has it been changed for one that is slightly different? Have you put on a custom lever?
The point is, could it be the lever not allowing the master cylinder to return fully to its rest position, and therefore retaining a bit of fluid pressure.
You seem to have tried everything else.
Hopefully you will sort it.
rebeltaz
PostPosted: 00:16 - 10 Oct 2019    Post subject: Reply with quote
No such thing as a stupid question. No, the lever is the original. The pivot point on it was squeaking, so I cleaned and lubed that while I had it apart, but no... This particular lever is spring-loaded and adjustable. When it starts slipping, I have even tried pulling the lever back against the spring so that it's not even resting on the plunger. I thought about that too, but nope....
Sad
Derek Tombrello
There is a gap of 5 years, 58 days between these two posts...
twanny
PostPosted: 10:07 - 05 Dec 2024    Post subject: Vulcan clutch oddity Reply with quote
Hi, did you ever solve you clutch problem? I am wondering since I am experiencing similiar issues.
Thanks for any help.
Just ask.
sickpup
Old Timer
PostPosted: 14:17 - 19 Dec 2024    Post subject: Reply with quote
Clean the slave piston and fit new seals, buy a new braided steel clutch hose, rebuild master cylinder.
That pretty much covers it all assuming the clutch stack is within spec.
twanny
PostPosted: 23:51 - 19 Dec 2024    Post subject: Reply with quote
Thanks for coming back to me. So really a pretty much full rebuild will fix the problem as long as the plates are good.
Thanks again
Just ask.
sickpup
Old Timer
PostPosted: 18:38 - 20 Dec 2024    Post subject: Reply with quote
Try it after each step, that's what I would do and the order I'd do it.
The last post was made 1 year, 333 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 79.51 Kb
