| rebeltaz |
 rebeltaz Renault 5 Driver
 Posted: 17:00 - 09 Oct 2019 Post subject: Kawasaki Vulcan Clutch Odd Behavior |
I need to explain quite a bit here, so please bear with me.
On my 2002 Kawasaki Vulcan VN1500 Classic Fi, the clutch started slipping big time. I rebuilt that, replacing most everything in there. It seemed to be ok for a while, but then started slipping again, a little more at a time until I almost couldn't get it back to my shop.
I've seen something similar happen to brakes when the slave cylinder will stick, so I took that apart, cleaned it, rebuilt it and put it back on. Again, it seemed ok for a while and then started slipping more and more just like last time.
This time, as soon as I got it back to the shop, I broke open the bleeder valve and, sure enough, a stream of fluid shot out as the piston was pushed back by the clutch springs. I took the bike back out immediately and, once again, the clutch was fine. I figured that the clutch hose was clogged. I blew that out and couldn't find anything clogged, so I went ahead and replaced it in case it was collapsing.
Once again, ok and then slipping. This time I broke the banjo bolt loose at the master cylinder. The fluid pushed out the bolt and the clutch worked again. The only thing left was the master cylinder, so I rebuilt that last night. I didn't see anything wrong with that while I was in there - nothing clogged and the rubbers looked fine.
I haven't taken it back out yet, but I have a strong suspicion that I am going to still have this problem. Both because I didn't see anything wrong, but also because after the last to repairs (the clutch line and the master cylinder), when I bled the system it was really odd. I use a vacuum bleeder. I could not get the system to bleed using that, so I reverted to the old pump/hold/bleed/release method. No air, but I still couldn't get a good solid pressure. The weird thing is that if I quit trying to bleed it, the pressure would build up and it will stay that way, unless I break open the bleeder valve, at which time it acts like air is being sucked in and it looses that pressure until it's built back up.
Does anyone have any ideas for if/when this clutch starts slipping again? ____________________ Derek Tombrello
www.ShelbyCycle.com (for profit)
www.RobotsAndComputers.com (just for fun) |
| doggone |
 doggone World Chat Champion
| rebeltaz |
| Robby |
 Robby Dirty Old Man
| Polarbear |
 Polarbear Super Spammer
| Nobby the Bastard |
| rebeltaz |
 Posted: 21:41 - 09 Oct 2019 Post subject: |
Well, like I said... I rebuilt that yesterday. I'm going to take it back out tomorrow and see how it does. Thanks everyone. ____________________ Derek Tombrello
| Stalk |
 Stalk Brolly Dolly
| rebeltaz |
There is a gap of 5 years, 58 days between these two posts... |
| twanny |
 twanny L Plate Warrior
| sickpup |
 sickpup Old Timer
| twanny |
| sickpup |
 sickpup Old Timer
The last post was made 1 year, 333 days ago. Instead of replying here, would creating a new thread be more useful? |
