| liladams1 |
 liladams1 Borekit Bruiser
| Baffler186 |
 Baffler186 World Chat Champion
| Hong Kong Phooey |
 Posted: 14:27 - 15 Oct 2019 Post subject: |
General service is a must on a bike you don't know much about, so oil, filters, plugs, check brakes for free operation and chain, headstock, barings and pads for wear. Suspension was never the best but inspect it for free play and damping.
I think the rear brake on these is a known area of trouble, location of it means it gets full of crap and can stick.
Breather system blockage might be part of the oil leak cause.
Only problem I had other than a puncture was dodgy connection to spark plugs, so new leads fixed that.
While you're under the tank for the plugs just remove the carbs in one lump, drain them, clean and inspect needle valves and float heights.
In the meantime be careful that fuel isn't washing through and locking/damaging the cylinder(s).
Carb rubbers of this age can crack and leak, or might not have been put back right last time.
Balance the carbs last of all to finish the job. ____________________
'81 CG125, '97 FZS600 : '99 CBR600F4, '09 KTM RC8 |
| liladams1 |
 Posted: 14:59 - 15 Oct 2019 Post subject: |
Purchased a Hayes manual, so I get to understand how this come apart ans go back together  ____________________ Doesn't Matter what your ride as long as it has two wheels and ain't Chinese. |
| A100man |
 A100man World Chat Champion
 Posted: 16:38 - 15 Oct 2019 Post subject: |
One of the mags which runs a Thundercat (same motor) found an oil leak from a corroded feed pipe - I think to the head.
Just sayin'. ____________________ Now: A100, GT250A, XJ598, FZ750, SL1000
The last post was made 6 years, 263 days ago. Instead of replying here, would creating a new thread be more useful? |
