Yamaha FZS600
liladams1
PostPosted: 12:17 - 15 Oct 2019    Post subject: Yamaha FZS600 Reply with quote
Hello guys, purchased a bit beated up fzs 600 as a project to fix up for the summer
It has 51K on in apparently my question is any of you can tell me the things I need to look out for
It has 2 main issues at the moment
1 carb is leaking petrol and bike hesistates at low revs but rides through it
Has an oil leak but didnt get the chance to check yet.
I want to make it reliable for at least the summer
I will change plugs, oil filter, oil, check air filter anything else you guys can think of?
Doesn't Matter what your ride as long as it has two wheels and ain't Chinese.
Baffler186
PostPosted: 13:09 - 15 Oct 2019    Post subject: Re: Yamaha FZS600 Reply with quote
Has an oil leak
Then you'll need to take the carbs off, inspect, clean and possibly rebuild them with new parts. Then identify where the leak is and fix that; might need a new gasket somewhere or may have been cracked/damaged.
Once that's sorted it might well have cured the hesitation but that's something you might have to fine tune when you stopped all the leaks.
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
Hong Kong Phooey
PostPosted: 14:27 - 15 Oct 2019    Post subject: Reply with quote
General service is a must on a bike you don't know much about, so oil, filters, plugs, check brakes for free operation and chain, headstock, barings and pads for wear. Suspension was never the best but inspect it for free play and damping.
I think the rear brake on these is a known area of trouble, location of it means it gets full of crap and can stick.
Breather system blockage might be part of the oil leak cause.
Only problem I had other than a puncture was dodgy connection to spark plugs, so new leads fixed that.
While you're under the tank for the plugs just remove the carbs in one lump, drain them, clean and inspect needle valves and float heights.
In the meantime be careful that fuel isn't washing through and locking/damaging the cylinder(s).
Carb rubbers of this age can crack and leak, or might not have been put back right last time.
Balance the carbs last of all to finish the job.
liladams1
PostPosted: 14:59 - 15 Oct 2019    Post subject: Reply with quote
Purchased a Hayes manual, so I get to understand how this come apart ans go back together Very Happy
A100man
PostPosted: 16:38 - 15 Oct 2019    Post subject: Reply with quote
One of the mags which runs a Thundercat (same motor) found an oil leak from a corroded feed pipe - I think to the head.
Just sayin'.
The last post was made 6 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 44.91 Kb
