Misfiring/spluttering around 4-5k
TravisBickle
PostPosted: 20:15 - 15 Oct 2019    Post subject: Misfiring/spluttering around 4-5k Reply with quote
Hi guys another one then, partially linked to the last one.
So my bike has developed some odd behaviour. The last time I took it out for a proper ride it was behaving fine the whole time and right up to and including parking up on my drive and turning it off etc.
Next time I came to use it, it started first time, then cut out after about 5 seconds. After that it wouldn't start up. Well I did eventually manage to get it running but only after cranking it for a very long time, giving it a short rest between goes. When it did eventually fire up it seemed to run fine on idle but as soon as I took it up to around 4-5k (whether it be on its stand in neutral or riding it in any gear) around that 4-5k mark it would lose power, cough and splutter, feels/sounds to me like a misfire or a fuelling problem. If I am able to get past the 4-5k mark it seems to run fine at the higher end of the rev range it's just that middle bit that's the problem.
I've changed the spark plugs and this hasn't made a difference.
Three things I would mention:
1) Even from when I first got the bike a couple of years ago, when cruising on the motorway at say around 70mph, it would always cruise fine but if I gave it an absolute fistfull while already doing about 70mph it would usually (not always) give one, only one, splutter, like a very brief fuel starvation only for a fraction of a second, would jerk my body forwards because of the sudden back-off in acceleration and then it would get up and go again fine. As I said it's been doing that for since I first got it but never around town or 40/50mph roads giving it a fistful at lower speeds in lower gears never got that sensation of a fuel starvation judder, only when already doing motorway speed. I don't know if this is linked, like an existing problem that was always there but has suddenly got worse.
2) It has been very wet lately, I had to blow a shitload of water and crap away from the top of the spark plugs before I removed them, there was literally a swimming pool collected in the spark plug recesses just from it being parked up in the rain. I'm not sure if the problem could be water-related.
3) The carb rubbers are cracked and have been since I got the bike. I don't THINK they're cracked all the way through as the rubber is quite thick but I can't be 100% sure. Looked on Fowlers for some new ones but they wanted about £80 each IIRC!!! Copied the part number and looked around including eBay and Amazon for some cheaper genuine ones but couldn't find any reasonably priced. Normally only go for genuine parts but this would probably be more than the bloody bike is worth so I begrudgingly got some cheap Chinese copies off eBay for £20 for a set of 4. They look a pig to fit though so will probably wait for a Sunday with some reasonable weather and have at it armed with the Haynes bible.
https://i.ibb.co/dMMv3Gf/20191015-200445.jpg
https://i.ibb.co/2WpQNdN/20191015-200434.jpg
Any ideas what might be the cause? Think I'm barking up the wrong tree with the carbs?
All help and advice gratefully received!
Nobby the Bastard
Harley Gaydar
PostPosted: 20:24 - 15 Oct 2019    Post subject: Reply with quote
When were the valve clearanes last checked?
Triumph Sprint ST 1050
TravisBickle
PostPosted: 20:38 - 15 Oct 2019    Post subject: Reply with quote
Possibly never??? Got the bike dirt cheap a couple of years ago with 40k on the clock. No service history whatsoever. Only maintenance that's been done since I owned it is regular oil changes, spark plugs just done for the first time, chain and sprockets, and air filter. Does it have a fuel filter somewhere? Can't see one...
TravisBickle
PostPosted: 20:39 - 15 Oct 2019    Post subject: Reply with quote
I just think it's strange it was fine the whole time the last time I used it. Not until a few days later went to start it up after it had been raining very hard that now I am having problems. That's why I'm thinking water ingress somewhere is the cause...???!!!
Nobby the Bastard
Harley Gaydar
PostPosted: 20:45 - 15 Oct 2019    Post subject: Reply with quote
Try starting it from cold and check the temp of the pipes, preferably with a temperature laser gun thing.
Any cylinders that aren't firing will warm up slower than ones that are.
Bear in mind that it's not much slower if the pipes are Connected.
This will identify if its a global or local issue.
TravisBickle
PostPosted: 20:48 - 15 Oct 2019    Post subject: Reply with quote
I haven't got the tool to do that. Might need a trip to the mechanic... He's a bit lazy and prefers me to order the parts if possible (actually he's not really lazy he's just very old school and not very computer-literate so finds it easier if I supply the parts for him). Already got the rubbers. Anything else I will need if it's carb-related? Gaskets or whatever?
Nobby the Bastard
Harley Gaydar
PostPosted: 20:52 - 15 Oct 2019    Post subject: Reply with quote
The odds are it'll be electrical or mechanical (valve clearances). Id be very surprised if carbs just suddenly go like that overnight.
The leakey rubbers won't help but the usual symptom of air leaks is cutting out when shutting the throttle to pull up.
Tdibs
PostPosted: 21:02 - 15 Oct 2019    Post subject: Reply with quote
Easiest way to see if the rubbers are completely gone, spray wd40 right on the cracks when it is idling. If it cracked through the revs will change. But yes, they are on the way out, better to change them out.
To your original problem, I would inspect the HT leads. Pull the caps from the sparkplugs, unscrew the wire from the cap, inspect if its all green and corroded or nice and shiny copper. If its all horrible, you can trim off the end of the lead slightly and screw back in.
If the Carb boots are that far gone, plug leads/caps might be suffering also.
Usually the cause of giving it a handful and it bogging and dropping a cylinder, then kicking back in.
Easy-X
PostPosted: 02:40 - 16 Oct 2019    Post subject: Reply with quote
I have some rubbers I bought for my failed Fazer project. They're only cheap Chinese copies but you're welcome to them if they'll be of help.
TravisBickle
PostPosted: 12:26 - 16 Oct 2019    Post subject: Reply with quote
Wow that's really kind thank you but I've already just purchased a cheap Chinese set for £20... wish I'd known beforehand :-/
TravisBickle
PostPosted: 16:34 - 23 Oct 2019    Post subject: Reply with quote
So the bike went to the mechanic and he found water in the system. A LOT of water. Dirty water and the petrol was cloudy. He drained the tank, removed the carbs, cleaned them up etc. Bike is back together again now and the symptom remains but to a slightly lesser extent. He's showed me how to drain the carbs with the little screw on the side of each carb. Carbs need draining before every time I use it. If I go to use it without draining the carbs it will splutter around 3-5k. If I manage to get it above 5k it seems ok at the top end of the rev range and as long as I keep the power on it rides ok. Drain the carbs before using the bike each time and the bike will run fine, until the next time I park it up and turn the engine off. After it's been parked up and turned off the next time I use it carbs will need draining again, even if only 15 minutes have elapsed i.e. stopping for petrol. But the bike seems to run fine until it's been turned off and left a short while. There's water in the petrol every time it's drained but both the water and the petrol are coming out clean now so although the tank has been drained and the carbs cleaned there's clearly still some water coming from somewhere. He said he didn't bother removing the fuel pump as in his experience as it's a 20 year old pump often you go disturbing parts like that after 20 years you find you put them back and they're no longer working any more so thought it best to leave it alone along with the filter rather than disturb it.
I'm happy to change the filter but apart from draining the carbs before every use is there anything else I can do to help get rid of the water? I'm thinking eventually if I keep draining it before every use eventually I should get the last of it but there seems to be no light at the end of the tunnel at the moment. I reckon I must have drained them a good 10 times or more and still water keeps coming out after every time I've used it.
Can you get fuel additives that will help with this?
Nobby the Bastard
Harley Gaydar
PostPosted: 16:40 - 23 Oct 2019    Post subject: Reply with quote
How is water getting into the tank?
You did throw the contents of the tank away and refill with completely new fuel didn't you?
TravisBickle
PostPosted: 16:42 - 23 Oct 2019    Post subject: Reply with quote
His theory is the breather pipe that goes from the filler cap to drain off any sitting watter got blocked so every time I fill up when it's wet water has been seeping back into the tank. He found it blocked anyway and unblocked it. The only thing that confuses me about this theory though is the fact that the bike was running fine until one day I went to use it and it was reluctant to start, had to crank it for ages before it fired up, and it was spluttering really badly just overnight after a really heavy downpour. It's not something that just gradually got worse over time.
You did throw the contents of the tan away and refill with completely new fuel didn't you?
I didn't. He did. Fresh fuel from the petrol station up the road. He's given me the old petrol in a can which I will use on the bon fire later in the week.
TravisBickle
PostPosted: 16:49 - 23 Oct 2019    Post subject: Reply with quote
He said there is a breather under the tank for the carbs which could have been the source of water ingress but he reckons unlikely as although water could go straight into the carbs from here if presented but because it's under the tank it's fairly well protected and unlikely to allow water in, even in a heavy downpour.
Nobby the Bastard
Harley Gaydar
PostPosted: 16:51 - 23 Oct 2019    Post subject: Reply with quote
Where is the water coming from? It can't just be coming from nowhere.
And don't say up the breather pipe, how is it getting into the breather in the first place?
TravisBickle
PostPosted: 16:53 - 23 Oct 2019    Post subject: Reply with quote
I don't know. He has a couple of theories but no conclusive evidence of the cause. Personally I would doubt it's getting in through the carb breather as if that was the case surely draining it once would cure the problem? As the water keeps coming back only logical place it can be coming from is the tank???
TravisBickle
PostPosted: 16:55 - 23 Oct 2019    Post subject: Reply with quote
https://www.amazon.co.uk/WYNNS-FUEL-WATER-REMOVER-325ml/dp/B01M0E2F2T
Anyone had any experience and success with this???
Nobby the Bastard
Harley Gaydar
PostPosted: 17:06 - 23 Oct 2019    Post subject: Reply with quote
You need to solve where the water is coming from before you do anything ekse. Has it been raining constantly since you've had it?
The water must be coming from somewhere.
Easy-X
PostPosted: 17:40 - 23 Oct 2019    Post subject: Reply with quote
It's not going to be something daft like E10 (higher ethanol content petrol) affecting an old bike?
Nobby the Bastard
Harley Gaydar
PostPosted: 17:42 - 23 Oct 2019    Post subject: Reply with quote
No. All that ethanol do will perish rubbers eventually, not fill the tank with water.
Tdibs
PostPosted: 18:25 - 23 Oct 2019    Post subject: Reply with quote
Wipe the tank fill cap seal/inside of the fuel cap completely dry with a paper towel.
Pour some water over your fuel tank, open it back up and check for any ingress. Might be seeping through the key barrel slowly or the seal is gone.
This sounds like multiple issues though, if you have known fresh fuel in, drained the carbs and ran it a few times, should be purged the majority of the water out already.
Grubscrew
PostPosted: 19:20 - 23 Oct 2019    Post subject: Reply with quote
Water could be coming from condensation build up in a tank if left for long periods less than full, due to atmospheric temperature outside, the bikes components will take time to adjust to the same temp causing condensation.
If you can put an in-line see through fuel filter in do so. (Cheap)
As for the carb rubbers: any small split going through the rubber will cause erratic running. And yes try the wd40 , it works. ( also a cheap fix)
If the carbs need a clean, find/ buy/ borrow a sonic cleaner with cleaning fluid....you’ll have to dismantle the carbs totally, take pics as you go to remind you of placements of bits.
The other cheap thing you could do is use a satellite fuel tank and run engine, in the dark (turn the lights out) and look to see if there is any arking of sparks etc across to the frame whilst running/ revving.
FJR1300/CBR1000F
Nobby the Bastard
Harley Gaydar
PostPosted: 19:35 - 23 Oct 2019    Post subject: Reply with quote
Enough condensation to cause the carb to need draining wouldn't have built up in the 9 days since this thread started, let alone since the tank was emptied by the mechanic.
TravisBickle
PostPosted: 20:36 - 23 Oct 2019    Post subject: Reply with quote
No this is the thing, this afternoon it's been drizzling a bit but apart from that I think it's pretty much been dry since I got it back from the mechanic so shouldn't be any NEW water coming in from outside. I can only assume it's residual in the system that the mechanic wasn't able to get rid of. But you're right to ask the question how did it get in there in the first place? As I said he had a few theories, the most likely of which seems to be the blocked breather/leakoff pipe that runs from the top of the inside of the filler cap to down below the tank to drain away any unwanted water.
A useful tip, thank you I will try this, although I'm not convinced this is the cause as it looks like it's had a relatively new fuel cap fitted by the previous owner as it has a separate key to the ignition. I did actually happen to clock the seal earlier and had a good look, the rubber seems new and bouncy... not old, cracked brittle or plasticky.
Dunno how my mechanic cleaned the carbs but he says he did a thorough job. Rubbers were replaced as it went back together but thinking about it that shouldn't have been the original cause of water ingress in the first place as if you think about it they sit between the carbs and the engine, so any water seeping through there would be going straight downstream into the engine, not back upstream into the carbs...
Time flies! Thought I'd had this bike for at least a couple of years but just checked back and see I only purchased it in March. Could well be this is simply the first lot of proper wet weather we've had since then, the problem was there before it just never had the chance to manifest itself until now because of not being wet enough?
Andy_Pagin
PostPosted: 17:42 - 24 Oct 2019    Post subject: Reply with quote
I'd avoid jumping to the conclusion that there is just one thing wrong that's causing the symptoms. I had a similar problem at about the same mileage, in my case it turned out that the spark plug caps where knackered, one actually fell to pieces when I gave it a gentle squeeze. A new set of caps costs about fifteen quid or thereabouts? Wouldn't do any harm to change them.
The last post was made 6 years, 260 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 2.09 - MySQL Queries: 13 - Page Size: 130.16 Kb
