| TravisBickle |
 TravisBickle World Chat Champion
 Posted: 20:15 - 15 Oct 2019 Post subject: Misfiring/spluttering around 4-5k |
Hi guys another one then, partially linked to the last one.
So my bike has developed some odd behaviour. The last time I took it out for a proper ride it was behaving fine the whole time and right up to and including parking up on my drive and turning it off etc.
Next time I came to use it, it started first time, then cut out after about 5 seconds. After that it wouldn't start up. Well I did eventually manage to get it running but only after cranking it for a very long time, giving it a short rest between goes. When it did eventually fire up it seemed to run fine on idle but as soon as I took it up to around 4-5k (whether it be on its stand in neutral or riding it in any gear) around that 4-5k mark it would lose power, cough and splutter, feels/sounds to me like a misfire or a fuelling problem. If I am able to get past the 4-5k mark it seems to run fine at the higher end of the rev range it's just that middle bit that's the problem.
I've changed the spark plugs and this hasn't made a difference.
Three things I would mention:
1) Even from when I first got the bike a couple of years ago, when cruising on the motorway at say around 70mph, it would always cruise fine but if I gave it an absolute fistfull while already doing about 70mph it would usually (not always) give one, only one, splutter, like a very brief fuel starvation only for a fraction of a second, would jerk my body forwards because of the sudden back-off in acceleration and then it would get up and go again fine. As I said it's been doing that for since I first got it but never around town or 40/50mph roads giving it a fistful at lower speeds in lower gears never got that sensation of a fuel starvation judder, only when already doing motorway speed. I don't know if this is linked, like an existing problem that was always there but has suddenly got worse.
2) It has been very wet lately, I had to blow a shitload of water and crap away from the top of the spark plugs before I removed them, there was literally a swimming pool collected in the spark plug recesses just from it being parked up in the rain. I'm not sure if the problem could be water-related.
3) The carb rubbers are cracked and have been since I got the bike. I don't THINK they're cracked all the way through as the rubber is quite thick but I can't be 100% sure. Looked on Fowlers for some new ones but they wanted about £80 each IIRC!!! Copied the part number and looked around including eBay and Amazon for some cheaper genuine ones but couldn't find any reasonably priced. Normally only go for genuine parts but this would probably be more than the bloody bike is worth so I begrudgingly got some cheap Chinese copies off eBay for £20 for a set of 4. They look a pig to fit though so will probably wait for a Sunday with some reasonable weather and have at it armed with the Haynes bible.
https://i.ibb.co/dMMv3Gf/20191015-200445.jpg
https://i.ibb.co/2WpQNdN/20191015-200434.jpg
Any ideas what might be the cause? Think I'm barking up the wrong tree with the carbs?
All help and advice gratefully received! |
| Nobby the Bastard |
| TravisBickle |
| TravisBickle |
| Nobby the Bastard |
| TravisBickle |
| Nobby the Bastard |
| Tdibs |
 Tdibs Traffic Copper
| Easy-X |
 Easy-X Super Spammer
| TravisBickle |
| TravisBickle |
| Nobby the Bastard |
| TravisBickle |
| TravisBickle |
| Nobby the Bastard |
| TravisBickle |
| TravisBickle |
 Posted: 16:55 - 23 Oct 2019 Post subject: |
| Nobby the Bastard |
| Easy-X |
| Nobby the Bastard |
| Tdibs |
| Grubscrew |
 Grubscrew Scooby Slapper
| Nobby the Bastard |
| TravisBickle |
 Posted: 20:36 - 23 Oct 2019 Post subject: |
| Nobby the Bastard wrote: | You need to solve where the water is coming from before you do anything ekse. Has it been raining constantly since you've had it?
The water must be coming from somewhere. |
No this is the thing, this afternoon it's been drizzling a bit but apart from that I think it's pretty much been dry since I got it back from the mechanic so shouldn't be any NEW water coming in from outside. I can only assume it's residual in the system that the mechanic wasn't able to get rid of. But you're right to ask the question how did it get in there in the first place? As I said he had a few theories, the most likely of which seems to be the blocked breather/leakoff pipe that runs from the top of the inside of the filler cap to down below the tank to drain away any unwanted water.
| Tdibs wrote: | Wipe the tank fill cap seal/inside of the fuel cap completely dry with a paper towel.
Pour some water over your fuel tank, open it back up and check for any ingress. Might be seeping through the key barrel slowly or the seal is gone. |
A useful tip, thank you I will try this, although I'm not convinced this is the cause as it looks like it's had a relatively new fuel cap fitted by the previous owner as it has a separate key to the ignition. I did actually happen to clock the seal earlier and had a good look, the rubber seems new and bouncy... not old, cracked brittle or plasticky.
| Grubscrew wrote: | As for the carb rubbers: any small split going through the rubber will cause erratic running. And yes try the wd40 , it works. ( also a cheap fix)
If the carbs need a clean, find/ buy/ borrow a sonic cleaner with cleaning fluid....you’ll have to dismantle the carbs totally, take pics as you go to remind you of placements of bits. |
Dunno how my mechanic cleaned the carbs but he says he did a thorough job. Rubbers were replaced as it went back together but thinking about it that shouldn't have been the original cause of water ingress in the first place as if you think about it they sit between the carbs and the engine, so any water seeping through there would be going straight downstream into the engine, not back upstream into the carbs...
Time flies! Thought I'd had this bike for at least a couple of years but just checked back and see I only purchased it in March. Could well be this is simply the first lot of proper wet weather we've had since then, the problem was there before it just never had the chance to manifest itself until now because of not being wet enough? |
| Andy_Pagin |
 Andy_Pagin World Chat Champion
The last post was made 6 years, 259 days ago. Instead of replying here, would creating a new thread be more useful? |
