1967 Suzuki b100p/b105p - Lights on when not running
robster94gt
PostPosted: 17:19 - 19 Oct 2019    Post subject: 1967 Suzuki b100p/b105p - Lights on when not running Reply with quote
Hey all,
I don't have any experience with bikes but i just finished putting together a Suzuki b100p.
I was wondering if the headlight and tail light should be on if the key is switched on, but the engine is not running. I haven't tried to run the engine yet, but just wanted to check if there are any electrical issues.
Currently, when I've got the key switched on, i can get the brake light to come on when i press the foot brake, but the tailight and headlight are not working. I'm not sure if they should be on, or only work when engine is running.
Thanks for your help,
Rob
jaffa90
PostPosted: 17:53 - 19 Oct 2019    Post subject: Reply with quote
Sounds normal to me for an old bike.
The rest should follow when the engine runs.
kingsblue
PostPosted: 18:14 - 19 Oct 2019    Post subject: Reply with quote
On the old 6 volt bikes the engine usually needs to be running for the headlight and tail light to work as these work off the magneto.
robster94gt
PostPosted: 18:32 - 19 Oct 2019    Post subject: Reply with quote
Thanks guys Smile That's good to know.
Cheers,
Rob
PostPosted: 19:56 - 19 Oct 2019    Post subject: Reply with quote
Yep normal. Lighting power (and ignition power in most cases) is not dependant on the battery. Many of that era of small bikes didn't even require a working battery to run. The only thing the ignition key did to prevent the spark plug from sparking was to earth the points and kill the spark, hence why they were so easy to steal, they just pulled the plug off the ignition switch and kicked it into life.
Easy-X
PostPosted: 21:58 - 19 Oct 2019    Post subject: Reply with quote
Hah! Don't I know it Smile Taking apart the DT today I discovered the reason the kill switch didn't work: just not connected. Not even a bullet connector on the end Rolling Eyes And yes, I kicked it over with no battery installed.
I think I might add an imobiliser alarm or hidden kill switch once I'm finished.
There is a gap of 1 year, 280 days between these two posts...
Jimmyjam
PostPosted: 19:26 - 26 Jul 2021    Post subject: 1967 Suzuki 105bp Reply with quote
I am new to this forum , I just picked up a barn find 105bp
Bike is complete 600 miles in pretty good shape, anyone know where I can find a service manual?
Also need help locating a few minor parts
Any help appreciated
Thanks
Jimmy j
Nobby the Bastard
Harley Gaydar
PostPosted: 20:45 - 26 Jul 2021    Post subject: Re: 1967 Suzuki 105bp Reply with quote
Thanks
Barnfind at 600 miles?
Hahahahahahahahahahahaha.
Bollocks is it.
Triumph Sprint ST 1050
Jimmyjam
PostPosted: 21:09 - 26 Jul 2021    Post subject: Reply with quote
If u weren’t such a smart a. I would have been happy to show you pictures
Everybody on here like you?
Jimmy j
A100man
PostPosted: 08:21 - 27 Jul 2021    Post subject: Reply with quote
Mostly, you'll get used to it.
Jimmyjam
PostPosted: 09:22 - 27 Jul 2021    Post subject: Reply with quote
Unfortunate, was hoping to find some help
Jimmy j
Easy-X
PostPosted: 09:49 - 27 Jul 2021    Post subject: Reply with quote
Most of the ppl on here hail from the Celtic nations where modesty and discretion are highly regarded. Willy waving your 600 mile barn find will not gain you any friends neither will thread-hijacking an old post.
jeffyjeff
PostPosted: 10:08 - 27 Jul 2021    Post subject: Reply with quote
here you go. good luck with your project.
https://www.oldjapanesebikes.com/mraxl_GT_Resource/manuals/b100p_service/index.php
Here is some more interesting stuff.
https://www.suzukicycles.org/B-series/B100_brochures.shtml#gsc.tab=0
xX-Alex-Xx
PostPosted: 11:54 - 27 Jul 2021    Post subject: Re: 1967 Suzuki 105bp Reply with quote
It's literally the first result on your major search engine Wink
DILLIGAF
A100man
PostPosted: 12:10 - 27 Jul 2021    Post subject: Reply with quote
Hey JimmyJam, JeffyJeff's a yank like you and getting along famously here - two orange blobs already.
Lovin' the alliteration by the way guys - sure you don't know each other?
Robby
Dirty Old Man
PostPosted: 12:27 - 27 Jul 2021    Post subject: Reply with quote
It is possible that it has 600 miles on, if something broke so fundamentally in the first 600 miles that it wasn't worth repairing.
Easy-X
PostPosted: 12:40 - 27 Jul 2021    Post subject: Reply with quote
More likely it was stripped for "field work" as Americans are wont to do and it's the first time the clocks have been reattached in 50 years Laughing
Robby
Dirty Old Man
PostPosted: 13:44 - 27 Jul 2021    Post subject: Reply with quote
Indeed, and I suspect the options will be that binary as is expected for "barn finds". It was either a lemon when new, or is knackered from years of use. Either way it will likely have quite a bit of monetary value from a small amount of work, but that is not the same as being something one would choose to keep.
jeffyjeff
PostPosted: 23:28 - 27 Jul 2021    Post subject: Reply with quote
Shocked
A100man
PostPosted: 10:10 - 28 Jul 2021    Post subject: Reply with quote
Shocked
The last post was made 4 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 104.28 Kb
