Royal Enfield Bullet 500
piratebiker
PostPosted: 14:46 - 21 Oct 2019    Post subject: Royal Enfield Bullet 500 Reply with quote
Hi guys, recently bought an Enfield 500, starts & runs fine but when I switch the headlights on/flash & stop light is activated, the engine cuts out. If engine revs are increased lights do not stop engine. Also when engine is revving the amp meter doesn't increase, any help please, thanks.
Nobby the Bastard
Harley Gaydar
PostPosted: 14:48 - 21 Oct 2019    Post subject: Re: Royal Enfield Bullet 500 Reply with quote
Sounds like your bike isn't generating electricity. check stator first, the reg/rec and wiring.
Triumph Sprint ST 1050
RhynoCZ
PostPosted: 15:44 - 21 Oct 2019    Post subject: Reply with quote
It's probably a short circuit/bad earth (bulb socket, switches, wiring) and you should find it, as stuff might burn if you don't.
Does it run an alternator (AC) or a dynamo (DC)?
Does it have a battery?
PostPosted: 18:41 - 21 Oct 2019    Post subject: Reply with quote
What year? There are several different bullets. Does it have a separate engine and gearbox? Is it electric start? Does the headlight work with the engine off?
piratebiker
PostPosted: 09:53 - 23 Oct 2019    Post subject: Reply with quote
Turns out the the alternator can't cope with running lights at low rpm, so have to trickle charge every night to keep the batt topped up. Rolling Eyes
jaffa90
PostPosted: 10:15 - 23 Oct 2019    Post subject: Reply with quote
That does not sound normal, also you have come on here for help and not answered any questions. Rolling Eyes
piratebiker
PostPosted: 11:51 - 23 Oct 2019    Post subject: Reply with quote
Yes has an alternator & battery, 1994 bike, kick start only, lights do run without engine when battery has enough juice. Don't know about separate gearbox. thanks.
Nobby the Bastard
Harley Gaydar
PostPosted: 12:13 - 23 Oct 2019    Post subject: Reply with quote
What voltage is it giving out at about 3k revs? if it's less than 14.5v your alternator is knackered.
PostPosted: 14:03 - 23 Oct 2019    Post subject: Reply with quote
Ok.
It should work fine. You need to do some fault finding.
I'd say chances are you either have a bad earth or one of your charging phases is knackered.
Aftermarket alternators are cheap and effective and pretty easy to swap out if it's gone.
Here's a detailed fault finding guide.
https://accessories.hitchcocksmotorcycles.com/core/media/media.nl?id=188331&c=1062795&h=ebaccc421262c7f1c541&_xt=.pdf
piratebiker
PostPosted: 15:42 - 23 Oct 2019    Post subject: Reply with quote
Thank you for the fault finding info, very helpful.
BusterGonads
PostPosted: 10:51 - 24 Oct 2019    Post subject: Reply with quote
Stinkwheel knows all about these beasts. See his thread on rebuilding a knackered one.
2023 Royal Enfield Classic 350; 2000 Honda CG125; 1997 Honda Nighthawk CB250
The last post was made 6 years, 250 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 67.88 Kb
