| NJD |
 NJD World Chat Champion
 Posted: 18:35 - 24 Oct 2019 Post subject: CBF1000 - Drilling a drain hole in link pipe |
Hi,
I have a CBF1000 with an aftermarket exhaust (OEM header pipes > aftermarket link pipes > aftermarket exhaust). Aftermarket link pipe has no drain hole and would like to drill one to prevent the amount of condensation / white smoke build up upon start ups and to prevent rusting as the weather continues to decline.
Have small drill bit, drill and OEM pipes (if anything goes wrong).
Am aware:
> Note position of OEM drain hole and ensure is done is as close to the original position as possible.
> Should only be a very small hole (a few mm wide).
Anything else to be aware of/advice to give?
Simple as propping the bike on a stand (more room underneath to drill) and get to work?
Link pipe image clicky. ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
| jaffa90 |
 jaffa90 World Chat Champion
 - Super Spammer
| NJD |
 Posted: 23:56 - 24 Oct 2019 Post subject: |
| jaffa90 wrote: | Only ever seen drain holes in cans, would your proposed hole be directly inline with the back tyre? |
Ah, I see, good job I didn't just "go at it."
Seems my mistake as to the location as I hadn't yet looked at the OEM ones before posting, or since, so assumed it would be on the link pipe as lower point (ie: water drains downwards).
Even though its only a cheap can I'd rather not butcher it by drilling into it.
So I guess the question becomes is there a risk of internal rusting on the pipe/connector pipe and, most importantly, the OEM donwpipes due to there not being a drain hole?
As I say I've got the OEM pipes so am not bothered about the aftermarket ones (refit OEM when sell) but would rather not damage the OEM header-pipes internally.
Bikes ridden fairly regularly so isn't sitting after a wet ride for an extended period of time. ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
 - Super Spammer
 Posted: 09:30 - 25 Oct 2019 Post subject: |
| NJD wrote: | | jaffa90 wrote: | Only ever seen drain holes in cans, would your proposed hole be directly inline with the back tyre? |
Bikes ridden fairly regularly so isn't sitting after a wet ride for an extended period of time. |
Surely they'll rot from the non-oily outside in before the oily inside out?
If you're that worried, carry a bung to put in the end can for when you park it up. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Jaguar S Type 3.0 V6 Sport R, VW Transporter T5 GP LWB Shuttle 140ps DSG. |
| NJD |
| xX-Alex-Xx |
 xX-Alex-Xx World Chat Champion
The last post was made 6 years, 257 days ago. Instead of replying here, would creating a new thread be more useful? |
