weird noise coming from my scooter
simon39uk
PostPosted: 19:56 - 05 Nov 2019    Post subject: weird noise coming from my scooter Reply with quote
Hello everyone
i have a lexmoto valencia 125cc
and tonight ive ran into a problem with my scooter i have done a vid for you.
would you please take a look and listen to the sound and see if you can identify what it may be to you.
im a complete beginner with bikes and really need to sort it as i use it for work
https://www.youtube.com/watch?v=uuPZj8FeOVw
thank you
Easy-X
PostPosted: 21:20 - 05 Nov 2019    Post subject: Reply with quote
I'm assuming it's just your standard Chinese scooter in faux-italian clothing Smile
It only seems to "rattle" at higher revs Thinking Well, you're gonna have to pop the cover off the CVT and peek in and see what's loose. Hopefully something obvious as all the parts in there - variator, drive belt, clutch... maybe the starter sprag - are all easy to replace and pretty cheap.
Doh! I'm assuming again that that's where the noise is coming from!
Other thoughts: something loose is rattling on the engine case, big lump of shit in the fan or - and I do hope it's not this - mangled gears in the final drive (the "gear box" area from the clutch to the back wheel.)
Nobby the Bastard
Harley Gaydar
PostPosted: 21:39 - 05 Nov 2019    Post subject: Reply with quote
It'll be the sound of your cunt lips flapping.
Triumph Sprint ST 1050
simon39uk
PostPosted: 21:55 - 05 Nov 2019    Post subject: Reply with quote
Cheers pal for the response
I'll have to take alook at weekend
It started happening after I hit a pothole
I know a garage who will take alook I just hope it's something simple
bikenut
PostPosted: 15:10 - 07 Nov 2019    Post subject: noise Reply with quote
You are taking it to a bike garage...........get a parts exploded view for your scooter, so you know whats where and how much etc..
Is the back wheel spinning when the noise starts and seems to grow with revs and rear wheel speed.........sounds are like metal to metal and may be transmission related, but you say you went into a pot hole and the noise started after that???????
Get the parts exploded views.......
nuts about bikes
WD Forte
PostPosted: 15:21 - 07 Nov 2019    Post subject: Reply with quote
Sounds like the grass box needs emptying
bikers smell of wee
Fizzoid
PostPosted: 16:03 - 07 Nov 2019    Post subject: Reply with quote
Heathsield on the exhaust?
Rogerborg wrote: It'd certainly make it easier to ego-find my own posts on pages, given the number of fags (gay like traps) who insist on putting my name in their .sig
barrkel
PostPosted: 13:46 - 08 Nov 2019    Post subject: Reply with quote
Exhaust and downpipes are in good shape? Nothing physically loose, like a heat shield?
It sounds like something metal that's loose and rattling with vibration.
I once had a quite peculiar noise from the inside of the final drive on my scooter, when I had one of the gears the wrong way around. The thrust washer on one side of the gear had too much free play and was tinkling as it rattled around. Flipping the gear fixed it.
Pop the beltcase cover off and see if there's anything obvious if it seems like the rattle is coming from there.
The last post was made 6 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 55.84 Kb
