Bandit oil change - do you need new washer
seeyalater
PostPosted: 17:16 - 10 Dec 2019    Post subject: Bandit oil change - do you need new washer Reply with quote
Hey, as all bikes cars are different thought id best ask before i commit to the change, does the sump bolt need replacing or a washer adding. made mistake on my audi once and it leaked and cant afford the risk with a bike.
its a 2007 K6 bandit. no idea what oil was in previous so should i go for semi synthetic or what oil would you put in a bike new to you.
has little service history but not detailed at all.
thanks in advance.
PostPosted: 17:26 - 10 Dec 2019    Post subject: Reply with quote
Yes, get a new washer. They are usually either copper or aluminium. Copper ones can be re-annealed but they are cheap to replace.
I'm not going to be drawn into the usual epic oil debate. Consult the users manual, don't use anything of a lower grade than they recommend.
I personally fit a dowty bonded seal washer on sump plugs these days. Those can be re-used. Usually M12.
Be very careful not to overtighten the sump bolt, it is easy to strip them on motorcycles.
Baffler186
PostPosted: 17:30 - 10 Dec 2019    Post subject: Reply with quote
You can get away with re-using the crush washer but they are cheap as chips so if you can, use a new one. No, you don't need a new bolt. Don't over-tighten, use a torque wrench if you have one, but otherwise just use common sense. If you've got a big ratchet then hold it close to the ratchet head (not the end). They are very easy to strip.
there are loads of threads on oil. Use whatever the manufacturer says. but in my case I have used the cheapest 10w40 I could find, and change it every 2.5k - 3k miles. I still think using cheap oil is fine as long as you change it regularly (I usually go 500-1000 miles sooner than the manufacturer recommends).
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
seeyalater
PostPosted: 17:31 - 10 Dec 2019    Post subject: Reply with quote
cheers, looked at new bolt with washer on fleabay for 8.99 but says m14 with 1.25 washer.
jaffa90
PostPosted: 17:38 - 10 Dec 2019    Post subject: Reply with quote
I just clean all and use a small amount silicon sealant around the washer and put back not too tight.
seeyalater
PostPosted: 17:43 - 10 Dec 2019    Post subject: Reply with quote
manual says SF/sg which means nothing to me. lol
from what ive read semi sythetic is best. if there is a oil thread to save me talking shit and wasting time let me know, i know this is simple stuff but bike info seems harder to find than it ever was for the car
NJD
PostPosted: 17:46 - 10 Dec 2019    Post subject: Reply with quote
The oil drain bolt (or sump bolt as you name it) can be re-used, and unless the head is damaged or corroded there's no need to replace it. You'll find the threads within well lubricated by the oil so should come undone with ease. You can, of course, order a replacement from places like Wemoto (online parts store) if you'd rather know what state your bike is in after buying it (I did when I recently got my CBF, and its always handy to have spares of various parts).
In terms of copper washers you can get assorted kits from Halfords for like £7-9. I've used it across a couple of bikes for banjo bolt's and sump plugs. Also, though, if you order a new bolt from Wemoto then it shouldn't be hard to find the washers on their too (probably about 0.50-0.99 per one as a guess).
In terms of oil I'd go 10w40 semi synthetic, but refer to your user handbook or workshop manual for guidance. As to what brand it depends how much you want to spend, and how often you want to change it. I used to buy 4L + 1L free for something like £26-30 for the ZR7 when I had it from Motul (5000 I think that was). On the CBF I've gone for Halfords (because money was tight at the time with the amount of work I was doing to it) and will probably change that when the weather improves.
As above make sure you research torque values for the bolt as stripping it can lead to a world of hurt, and even more so if the bike doesn't have a removable sump pan (as in the bottom of the engine is one complete part). Some people get confused about the direction to tighten and enlighten since the bolts are often upside down but set your ratchet the correct way (practice on another bolt) before tightening / loosening it and you can't go wrong.
When it comes to tightening the bolt thread it in by hand until it seats and then either torque up with wrench or nip it with a spanner or 1/4 ratchet (use a 3/8 and no idea of feeling and it will soon go).
Its advisable to run the bike on the stand after an oil change in neutral to check for leaks, turn it off and then let it settle to see how much you need to top it up by (drain, fill, start the bike and run for a minute or two, let it settle and refill). Then after that go for a ride and stop part way to see if there's any leakage.
Make sure you've got rags spare for the oil that will, probably, leak on the downpipes.
Also if you're doing it outside at this time of year think about asking a local shop to do it as it shouldn't cost more than half of an hour to an hour (depending how stingy their feeling).
seeyalater
PostPosted: 18:31 - 10 Dec 2019    Post subject: Reply with quote
Nice one thanks, the online place will be handy for bits.
PostPosted: 18:35 - 10 Dec 2019    Post subject: Reply with quote
Yes fit a new washer if you can. The washer deforms to make the seal oil-tight.
There's many an oil change done without changing it but then there's many a stripped plug thread too caused by pulling the sump plug up to stop it dripping.
Be warned, sump plug threads strip easily. Don't over-tighten it.
NJD
PostPosted: 22:10 - 10 Dec 2019    Post subject: Reply with quote
May help you out, too:
https://www.sportsbikeshop.co.uk/motorcycle_parts/content_cat/169
https://www.fowlersparts.co.uk/browser/manufacturer/suzuki
https://www.ebay.co.uk/str/mandpdirect
Easy-X
PostPosted: 22:40 - 10 Dec 2019    Post subject: Reply with quote
If you do want to change the oil sump plug then it might be worth considering a few quid more and getting one with a magnet on the end to gather up any bits of steel and iron. Obviously it won't pick up alloy swarf but that's relatively soft stuff.
Riejufixing
PostPosted: 00:27 - 11 Dec 2019    Post subject: Reply with quote
Would it be this thing?
https://www.ebay.co.uk/itm/Motorcycle-Magnetic-Oil-Drain-Plug-Sump-M14-x-1-25-Copper-Washer-Suzuki-Models/302680683821?hash=item46792cb52d:g:M-sAAOSwe1xatPZy
The thread diameter is 14mm, the pitch of the thread (distance between each thread) is 1.5mm, the washer is copper. That'd do.
If you want more washers (you don't have to replace the sump plug), or just to replace the washer you have now:
https://www.ebay.co.uk/i/133058242807?chn=ps&var=432359891649&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&itemid=432359891649_133058242807&targetid=521197488368&device=c&mktype=pla&googleloc=1006933&campaignid=7412990545&mkgroupid=76068633770&rlsatarget=pla-521197488368&abcId=1139356&merchantid=7202084&gclid=EAIaIQobChMI0P_Dg5ys5gIVh7HtCh1dBQ8AEAQYASABEgICXPD_BwE
If you ever get really, really stuck, e.g. drop your sump bolt down the drain or something, you can actually use a 14mm sparking-plug to replace it temporarily.
seeyalater
PostPosted: 09:19 - 11 Dec 2019    Post subject: Reply with quote
thats the one, ive ordered washer and oil etc so will see how it goes.
great help here as usual.. thanks
Confusion
PostPosted: 17:36 - 12 Dec 2019    Post subject: Re: Bandit oil change - do you need new washer Reply with quote
Leearchertog wrote:
....does the sump bolt need replacing.....
The Bandit sump plug is made from steel. It will never wear out in
normal use. Don't replace it without good reason.
or a washer adding.
It is a good idea to replace the crush washer, although I don't
always replace mine at every oil change. Make sure you remove
the old washer first.
its a 2007 K6 bandit. no idea what oil was in previous so should i go for semi synthetic.....
10W-40 semi-synthetic is fine. Any of the big brands will be ok.
For the last few years, my Bandit 650 has been running happily
with Valvoline 10W-40 All-Climate (around £17 for 5 litres).
Will you also be changing the oil filter?
Bandit 650SA, ZZ-R1100
seeyalater
PostPosted: 13:24 - 19 Dec 2019    Post subject: Re: Bandit oil change - do you need new washer Reply with quote
or a washer adding.
Hi yes did the filter too, k&n and silkoline oil. all done and no leaks.
Thanks to all who commented. took my time, added tension in small stages to sump bolt. checked it over 24hrs before riding, then after 7 miles pulled up for a quick check and all good. over cautious maybe but cant hurt.
RhynoCZ
PostPosted: 15:34 - 19 Dec 2019    Post subject: Reply with quote
https://i.kym-cdn.com/entries/icons/original/000/004/029/motherofgod.jpg
linuxyeti
PostPosted: 17:26 - 19 Dec 2019    Post subject: Reply with quote
If I'm likely to own a bike lng enough to be carrying out multiple oil changes, then, where one's available, I get a Stahlbus oil drain valve
Beware what photos you upload, or link to on here, especially if you have family members on them
Easy-X
PostPosted: 17:40 - 19 Dec 2019    Post subject: Reply with quote
Oh yeah, those are kewl Smile Definitely worth it on oil boilers and Chinese bikes.
linuxyeti
PostPosted: 08:56 - 20 Dec 2019    Post subject: Reply with quote
Put the first one I had on my VTX1300, after that, pretty much any bike I could get 1 for. Makes oil changes so much easier, hook the hose up to a pump, and drain the oil straight into an old oil container, no mess, nice & quick.
There's still the odd bike you can't do this with, and, the odd bike, where you can just use the pump to suck the oil out of the sump using the pump by feeding a hose down through the oil filler cap.
jaffa90
PostPosted: 01:26 - 21 Dec 2019    Post subject: Reply with quote
I don`t even replace the spark plug crush washer after cleaning it, do you????????????????
RhynoCZ
PostPosted: 10:53 - 21 Dec 2019    Post subject: Reply with quote
I don't put any sealant there, that's for sure.
PostPosted: 13:11 - 23 Dec 2019    Post subject: Reply with quote
I never/rarely bothered, however after 12 years I finally have my first drain plug leak. so I certainly will in the future Laughing
The last post was made 6 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 127.04 Kb
