Anti mist coating, I think ive cracked it!
Ribenapigeon
PostPosted: 17:48 - 27 Dec 2019    Post subject: Anti mist coating, I think ive cracked it! Reply with quote
The recipe is.... 85% water 10% sugar and 5% detergent.
Ive been experimenting on and off for ages and finally landed on this mix. Recovering from a hernia op so not able to test on the bike but my tests on the bathroom mirror and my old helmet visor indoors have worked with this mix. The water is just a medium but its the sugar which has the hydrophilic properties that prevent misting and the detergent wets out the water/sugar mix.
Cheers
PostPosted: 17:56 - 27 Dec 2019    Post subject: Reply with quote
Shaving foam.
Ribenapigeon
PostPosted: 18:19 - 27 Dec 2019    Post subject: Reply with quote
Ste wrote:
Shaving foam.
Tried several brands of shaving foam and nowhere near as good as the sugar. Detergants do work to a degree as a detergant is hydrophilic but the sugar is far better. Try it its cheao enough.
doggone
PostPosted: 18:25 - 27 Dec 2019    Post subject: Reply with quote
So practically will this sit as a spray in an old kitchen cleaner squirt bottle or something?
Ribenapigeon
PostPosted: 18:33 - 27 Dec 2019    Post subject: Reply with quote
You can get pocket sized spray bottles from superdrug.
Spray on, polish dry with tissue.
recman
PostPosted: 20:30 - 27 Dec 2019    Post subject: Reply with quote
Washing up liquid detergent?
Ribenapigeon
PostPosted: 21:34 - 27 Dec 2019    Post subject: Reply with quote
I used some handwash liquid soap.
- This post is not being displayed because it has a low rating (Boring). Unhide this post / all posts.
ThatDippyTwat
PostPosted: 08:25 - 28 Dec 2019    Post subject: Reply with quote
mpd72 wrote:
How many of the regulars on here still work for a living?
Who put 50p in the fuckwit?
Come on, own up...
Sister Sledge
PostPosted: 08:43 - 28 Dec 2019    Post subject: Reply with quote
How good is the mix for dry days?
I'm wondering if it will attract dust. Yes you're wiping it dry but will dust stick to the layer??
CCM 404 DS
weasley
PostPosted: 10:23 - 28 Dec 2019    Post subject: Reply with quote
I can see the chemistry angle, but I wonder how reversible this will be and for how long? The sugar will, indeed, absorb water but unless you force dry it this will likely be a one-time thing and it will probably sit there quietly deliquescing even when you are not wearing it.
Have you tried different sugars, or just sucrose? How about salts? And also, is the film that you apply visually transparent?
andyscooter
PostPosted: 11:21 - 28 Dec 2019    Post subject: Reply with quote
a smearing of shower gel does the same on mirrors
Ribenapigeon
PostPosted: 11:48 - 28 Dec 2019    Post subject: Reply with quote
Just ordinary granulated white sugar dissolved in tap water. Im sure the recipe could be refined using distilled water etc
The detergant element seems the worse for visibility issues. I think I could probably reduce the % of detergant as its simply there to help wetting out the mix. I suspect the handwash i used may have some salt in it anyway. Is there a more pure detergant I could use, do you know?
I think degradatuon of wipe/spray on anti mist solutions is a problem with commetcial ones so i suspect my mix will also not be permanent. However it is cheaper.
Ribenapigeon
PostPosted: 11:54 - 28 Dec 2019    Post subject: Reply with quote
Come on, own up...
Nobody has to. I suspect Terrence is powered by methane gas harvested from his own s#it. Given just how much s#ite he produces I think the chances he will shut up anytime soon are limited. Shocked
Nobby the Bastard
Harley Gaydar
PostPosted: 12:33 - 28 Dec 2019    Post subject: Reply with quote
I find it funny that hes basically become a caricature of himself.
Triumph Sprint ST 1050
PostPosted: 12:52 - 28 Dec 2019    Post subject: Reply with quote
Ribenapigeon wrote:
Terrence
His name is Donk, get it right. Razz
- This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
Nobby the Bastard
Harley Gaydar
PostPosted: 13:41 - 28 Dec 2019    Post subject: Reply with quote
It must drive you crazy that most immigrants are hard working.
recman
PostPosted: 13:42 - 28 Dec 2019    Post subject: Reply with quote
Most immigrants we know about... Pass the popcorn
MCN
PostPosted: 18:35 - 28 Dec 2019    Post subject: Reply with quote
Are immigrants good for de-misting/anti-misting a visor or should I use the 3.4% unemployment solution in de-fatted H2o?
PostPosted: 18:40 - 28 Dec 2019    Post subject: Reply with quote
Just like MPD, sugar is abrasive.
Ribenapigeon
PostPosted: 18:51 - 28 Dec 2019    Post subject: Reply with quote
Not as superior as the mpd72hotairblower.
recman
PostPosted: 21:55 - 28 Dec 2019    Post subject: Reply with quote
This thread started in a fairly interesting way.
TaffyTDM
PostPosted: 23:52 - 28 Dec 2019    Post subject: Reply with quote
The wasps will love it in the spring Silence
The last post was made 6 years, 302 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 126.85 Kb
