| mission360 |
 mission360 L Plate Warrior
 Posted: 18:05 - 28 Dec 2019 Post subject: Yamaha Tracer 900 GT Fast Charging Phone/Nav |
Can anyone please help with the issue I am having?
I have trawled the forums regarding this and want to be able to up the amperage of the 12v accessory socket near the handlebars. At the moment my phone drains quicker than it charges when Nav/comms/music are active. I have read that it struggles to deliver even 1.6 amps.
I purchased an Optimate Usb charger plug that states it will deliver 3.3 amps as long as only one usb socket is used https://www.optimate.co.uk/products/o106-usb-charger-cig-plug
I have disconnected the 12v accessory socket and I have wired in a 30 amp relay with 17amp cable going direct to the 12v accessory socket instead. I have found a switched live to provide switched power etc etc. The relay is doing it's job and providing switched power to the accessory socket, and also a connection directly to the battery to the relay but I am still no better off amperage wise.
Have I misunderstood that this was even possible? I followed the instructions in the link below.
https://www.r1200gs.info/howto/relay.html
Help!! |
| WD Forte |
 WD Forte World Chat Champion
 Posted: 19:37 - 28 Dec 2019 Post subject: |
USB/phone/satnav sockets are all 5V dropped from a 12-14v supply on cars bikes.
and the current they can supply to your gadgets will depend on the internal circuitry
of the USB socket despite what current your 12v supply is capable of.
This means even if you have a 12v supply capable of giving say a steady 20 Amps (240 watts)
the 5V regulation circuit may throttle it to 1.5 or 2 amps ( 10 watts ish ) to protect itself from
over current/over heating.
I haven't had any apart to see how they're built so can only speak in generalities
but their physical size will have an affect how much heat they can handle safely
and they probably have self protection circuitry which limit power out.
All your devices are in effect 'loads'
bigger load = more current = more potential heat
Let's say the socket is rated at 10 watts that's just 2 amps at 5V
so two devices wanting 1.5 amps each will struggle.
That optimate thing sounds too good to be true to me
2 ports giving 5V @ 3.3A each?
A total of 6.6A/33watts?
Hmmmm nahh, I reckon that's total output and would want to test that for myself before believing it.
Those fag lighter plug connectors are convenient but iffy
for electronics, especially on a bike.
I'd want mine hard wired.
It says 5V @ 3.3 amps output on the barrel so that's 1.65A per channel
which sounds more realistic considering its size.
It it was 3.3A per channel, it would say Output 5VDC - 6.6A
here endeth the teffing  ____________________ bikers smell of wee |
| ZebraDriver |
 ZebraDriver Scooby Slapper
| mission360 |
| mission360 |
| ZebraDriver |
| Nobby the Bastard |
| ZebraDriver |
| jimspeed |
 jimspeed World Chat Champion
| ThatDippyTwat |
 ThatDippyTwat World Chat Champion
The last post was made 6 years, 287 days ago. Instead of replying here, would creating a new thread be more useful? |
