Honda C110 clutch
Bossboy
PostPosted: 21:37 - 30 Dec 2019    Post subject: Honda C110 clutch Reply with quote
Hello,
Rebuilt the complete engine around 18 months ago, on the bench, not in bike.
I ask, is there anything I should do to the clutch, could it be seized from standing ?
Would rather do it now before I put back into bike
Thanks in advance
Easy-X
PostPosted: 21:40 - 30 Dec 2019    Post subject: Reply with quote
If you have reason to suspect the clutch is worn out then by all means strip it down. Worse ways you haven't totally wasted your time, soak the plates in oil for a bit and pop them back in.
Bossboy
PostPosted: 21:43 - 30 Dec 2019    Post subject: C110 clutch Reply with quote
Thanks
It was a brand new clutch, I must admit, I did not soak it in oil before I fitted
Do you recommend to do this, and best oil
Riejufixing
PostPosted: 22:52 - 30 Dec 2019    Post subject: Re: Honda C110 clutch Reply with quote
Bossboy wrote:
Rebuilt the complete engine around 18 months ago, on the bench, not in bike. I ask, is there anything I should do to the clutch, could it be seized from standing ?
Less likely to sieze with a new clutch, from new. Disengage the clutch and try to turn the engine with the kickstart. Engine no turn, clutch no stuck.
WD Forte
PostPosted: 23:59 - 30 Dec 2019    Post subject: Reply with quote
Yeah, what that Arab boy said
bikers smell of wee
Easy-X
PostPosted: 01:12 - 31 Dec 2019    Post subject: Re: C110 clutch Reply with quote
Bossboy wrote:
Thanks
You never want to go in dry Wink
I recommend KY-Jelly using the same oil you were gonna fill the bike with.
Bossboy
PostPosted: 09:52 - 31 Dec 2019    Post subject: C110 clutch Reply with quote
Many thanks for replies
So, do I have to take clutch part to oil plates before reassembly ?
Thankyou
Triton Thrasher
PostPosted: 10:41 - 31 Dec 2019    Post subject: Re: Honda C110 clutch Reply with quote
[quote="Riejufixing"]
Does this bike not have the “primary kickstart” that means you can kickstart start it in gear with the clutch lever pulled in?
Some old Japanese bikes did, anyway.
Rrrrrrrrrrrrrrrrrr
PostPosted: 11:25 - 31 Dec 2019    Post subject: Re: C110 clutch Reply with quote
Thankyou
No you don't. If you fitted new plates then fit the engine, fill with oil and go ride the bike.
Nobby the Bastard
Harley Gaydar
PostPosted: 12:36 - 31 Dec 2019    Post subject: Reply with quote
The last set of ebc plates I fitted had 'soak in oil before fitting' in the instructions from the manufacturer.
Triumph Sprint ST 1050
PostPosted: 12:45 - 31 Dec 2019    Post subject: Reply with quote
Perhaps because that's what people expect to see? I never had such instructions with clutch packs for my Hayabusa.
Can't see them stopping production lines to soak the plates in oil. Or taking the time to clean up the mess from dripping oil on all the following operations.
Easy-X
PostPosted: 17:55 - 31 Dec 2019    Post subject: Reply with quote
Okay, let's put it another way: will a drop of oil on the plates help or hinder?
Manufacturers rarely put copper grease on any bolts they torque up... which you discover many moons later when you want to do your swing arm or something Neutral
The last post was made 6 years, 280 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 72.38 Kb
