| chris___ |
 chris___ Brolly Dolly
 Posted: 22:32 - 29 Mar 2005 Post subject: neutral |
Can someone please give me some advice as to why my bike doesn't like going into neutral please!? Its a yamaha rxs100.
It seems to go in better when its moving, but if i come to a stop at lights and i'm in first at a standstill it just will not go into neutral for some reason
cheers
chris ____________________ Yamaha rxs100 > Kawasaki ZZR600 > Kawasaki ZX6R > Honda Hornet 600 > Honda Bros 400 > Suzuki SV650S K2
Bikepics page |
| Bendy |
 Bendy Mrs Sensible
| chris___ |
| Aikman666 |
 Aikman666 World Chat Champion
 Posted: 22:41 - 29 Mar 2005 Post subject: |
Does the lever jam or does it skip it and go into the gear above/below? ____________________ Will work for petrol
My Design Blog |
| White Noise |
 White Noise Mr Dudwee
maybe the clutch is a bit cold, what you can do it while in neutral give it a little revs and let out the clutch just a little then try to put it into first, it should clunck in, be sure to be covering the brakes when you do it!
WN ____________________ Buy my wife: 96' Yam XJ600s (Diversion)
Riding Tip #86: See God, then back off a bit: Problem is i haven't seen god yet, just a close up of tarmac on revett straight |
| garth |
 garth World Chat Champion
 Posted: 22:42 - 29 Mar 2005 Post subject: |
It's quite common, just snick it into neutral before you stop.
I can't tell you why it won't do it, something to do with about three billion tiny cogs not spinning at the same rate I suspect!  ____________________ You ain't a has been if you never was |
| chris___ |
| Gazdaman |
 Gazdaman I did a trackday!!!
 Posted: 22:51 - 29 Mar 2005 Post subject: |
I suspect it's suffering from "I'm-an-old-bike-that's-been-ragged-for-a-decade-syndrome".
Get used to holding that clutch in
My MZ was tempramental about going into neutral, it was easier to knock down from second though.
Gaz |
| chris___ |
| Gazdaman |
| stinkwheel |
 Posted: 01:05 - 30 Mar 2005 Post subject: |
They don't test the engine or gearbox during the MOT, it certainly used to be the case that you didn't even have to have an engine in the bike, you could MOT a rolling chassis.
We are spoiled these days because most modern bikes have a neutral finder in the gearbox that makes the change to neutral when stationary very positive. Many older bikes are (and always were) a complete pig to get into neutral when stationary, you get used to it with practice. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| culpan |
 culpan Renault 5 Driver
| mr.z |
 mr.z World Chat Champion
 Posted: 02:04 - 30 Mar 2005 Post subject: |
An oil (and filter) change might help, ive found when the oil needs a change getting it into neutral at stop is a pain (it tends to skip past) my cx did the same so did my cg... worth a go...
Edit: One other cgs little tricks i'd forgoten about... Engine off, first gear, leting the clutch out drag the bike backwards and then try going up a gear, if not move forward and then back again.. yep that was a bit of a pain... ____________________ >RidingSkills<->Tech Tips<->MyBikes<
| beast rider |
 beast rider Could Be A Chat Bot
| Scotsman37 |
 Scotsman37 World Chat Champion
 Posted: 03:26 - 30 Mar 2005 Post subject: |
You may need to get your clutch plates replaced as they maybe now wearing out !
Clutch Kits and read the info section shown next your model of bike via a link;
https://www.gear4bikes.com/acatalog/Yamaha_Clutch_Kits.html
| mchaggis |
 mchaggis World Chat Champion
 Posted: 03:31 - 30 Mar 2005 Post subject: |
Just wheeling the bike back a few inches whilst putting pressure on the lever can be a big help and normally makes it work.
Alternatively, adjusting the clutch cable tighter so that it pulls the plates further apart fully in can be a help but probably won't be much use for going slowly as the biting point will be much further forward and they might not engage fully when the lever is fully out.
A poorly adjusted clutch can make a fairly major difference to gear selection if it's too loose, and if it's too tight, it'll slip at high rpm.
At the end of it all, getting used to pulling off in second gear and slipping the clutch will be of most use in sticky spots. Sometimes it just doesn't want to play. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush.  |
The last post was made 21 years, 200 days ago. Instead of replying here, would creating a new thread be more useful? |
