| Codey90 |
 Codey90 Derestricted Danger
 Posted: 22:29 - 18 Jan 2020 Post subject: MOT Failure Head Bearings |
Hi all,
My bike failed it's MOT yesterday due to movement in the forks caused by a faulty head bearing. This was due to the bike being stolen a while back and a hammer being taken to the yoke to get rid of the steering lock.. Lovely
Question being, look at the below part diagram
https://www.chinesemotorcyclepartsonline.co.uk/microfiche/8012/477
The issue is some parts the garage can't get hold of.
Parts 3, 5 and 7 (Upper Yoke Bearing Set) has been ordered but parts 4, 6 and 8 (Yoke Bearing Set) they cannot and the supplier has said they do not if they will be back in stock anytime soon.
After ringing my dealership where the bike was from, they said there is no lower yoke bearing, all it is is merely a plastic cup filled with grease and ball bearings.
Looking at the diagram, I can't tell what is what. Is the upper yoke bearing set likely to fix the issue? What is the difference between upper yoke bearing set and yoke bearing set? The last thing the garage wants is to take the bike to bits and then find out they can't get hold of the necessary part.
Any help will be much appreciated! ____________________ Current: Lexmoto ZSX-F 125
Previous: Lexmoto FMS 125 (Blew Up)
Lesson: Don't Blast a Moped Down the A38 for 70 miles |
| WD Forte |
 WD Forte World Chat Champion
| weasley |
 weasley World Chat Champion
| steve the grease |
| Codey90 |
 Posted: 00:43 - 19 Jan 2020 Post subject: |
My bearing size for the lower is 48 OD, 27 Bore and 14.6mm Height
I've found one on that website with the same dimensions but 14mm height. Doubt the 0.6mm height difference will affect much? ____________________ Current: Lexmoto ZSX-F 125
| Easy-X |
 Easy-X Super Spammer
 Posted: 00:48 - 19 Jan 2020 Post subject: |
I was going to write a Tef-sized post about the generic nature of ball-bearings, their history, etc. but looking at the picture again I suspect the complication (for the hard of thinking garage mechanic seemingly) is they are caged ball races.
Still shouldn't be a problem. Ball races are common things you just need to know the size. If you have play in the steering then one would hope all the parts are still present to measure.
While I agree with my esteemed fellow member, weasley, that it may just need tightening up it seems rather lazy not to take the thing apart and assess the damage (if any) before ordering parts.
I suspect it's a case of "order all relevant parts, strip and replace, return unneeded parts to supplier." Wasteful but commonplace strategy in the spanner business. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| steve the grease |
 Posted: 01:35 - 19 Jan 2020 Post subject: |
Hitting the yoke with a hammer will not bother the actual bearings in the slightest. I've seen me whaling directly on a steering beraing race for half an hour with a lumphammer and drift trying to remove it and it just laughed at me. They are made from the hardest of hard steel.
So if there is play there, they either need tightening (most likely) or there is a more fundamental problem like missing ball bearings or damaged yoke. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| WD Forte |
| jaffa90 |
 jaffa90 World Chat Champion
 Posted: 02:06 - 19 Jan 2020 Post subject: |
 Posted: 02:17 - 19 Jan 2020 Post subject: Re: MOT Failure Head Bearings |
| Codey90 wrote: | Hi all,
Any help will be much appreciated! |
Nut 11 is the adjuster for the headstock bearings. Remove bolt 10 to get access to it. Find some way of keeping the front wheel off the floor and have someone push/pull on the wheel to feel for play. Tighten nut 11 until the play is removed but not so much that the steering feels notchy (it won't take much). Once you can feel no front/back play in the steering tighten it all back up and go for your re-test. ____________________ a.k.a 'Geri'
| yen_powell |
The last post was made 6 years, 167 days ago. Instead of replying here, would creating a new thread be more useful? |
