MOT Failure Head Bearings
Codey90
PostPosted: 22:29 - 18 Jan 2020    Post subject: MOT Failure Head Bearings Reply with quote
Hi all,
My bike failed it's MOT yesterday due to movement in the forks caused by a faulty head bearing. This was due to the bike being stolen a while back and a hammer being taken to the yoke to get rid of the steering lock.. Lovely
Question being, look at the below part diagram
https://www.chinesemotorcyclepartsonline.co.uk/microfiche/8012/477
The issue is some parts the garage can't get hold of.
Parts 3, 5 and 7 (Upper Yoke Bearing Set) has been ordered but parts 4, 6 and 8 (Yoke Bearing Set) they cannot and the supplier has said they do not if they will be back in stock anytime soon.
After ringing my dealership where the bike was from, they said there is no lower yoke bearing, all it is is merely a plastic cup filled with grease and ball bearings.
Looking at the diagram, I can't tell what is what. Is the upper yoke bearing set likely to fix the issue? What is the difference between upper yoke bearing set and yoke bearing set? The last thing the garage wants is to take the bike to bits and then find out they can't get hold of the necessary part.
Any help will be much appreciated!
Current: Lexmoto ZSX-F 125
Previous: Lexmoto FMS 125 (Blew Up)
Lesson: Don't Blast a Moped Down the A38 for 70 miles
WD Forte
PostPosted: 23:58 - 18 Jan 2020    Post subject: Reply with quote
This sounds fishy to me
How did a theif manage to just damage bearings yet leave the headstock/Yoke untouched?
Sounds like no one has bothered to assess actual damage and faults
Besides, if they do need replacing
Do you think they make one off special bearings just for one model of a budget chinese bike?
bollox they would
I bet they're common as muck if someone took the time to investigate and there's probably taper roller option too.
bikers smell of wee
weasley
PostPosted: 00:12 - 19 Jan 2020    Post subject: Reply with quote
And it may turn out they just need tightening up.
steve the grease
PostPosted: 00:26 - 19 Jan 2020    Post subject: Reply with quote
Measure up the outer diameter of the outer races , the inner diameter of the inner races, and the overall thickness of the bearings when assembled. Then armed with the dimensions maybe 43mm 25mm and 11mm go and look somewhere like simply bearings website
https://simplybearings.co.uk/shop/p43708/43Y/25M1-Narrow-Section-Steering-Head-Set-Taper-Roller-Bearing-25x43x11mm/product_info.html
sorted
Codey90
PostPosted: 00:43 - 19 Jan 2020    Post subject: Reply with quote
sorted
My bearing size for the lower is 48 OD, 27 Bore and 14.6mm Height
I've found one on that website with the same dimensions but 14mm height. Doubt the 0.6mm height difference will affect much?
Easy-X
PostPosted: 00:48 - 19 Jan 2020    Post subject: Reply with quote
I was going to write a Tef-sized post about the generic nature of ball-bearings, their history, etc. but looking at the picture again I suspect the complication (for the hard of thinking garage mechanic seemingly) is they are caged ball races.
Still shouldn't be a problem. Ball races are common things you just need to know the size. If you have play in the steering then one would hope all the parts are still present to measure.
While I agree with my esteemed fellow member, weasley, that it may just need tightening up it seems rather lazy not to take the thing apart and assess the damage (if any) before ordering parts.
I suspect it's a case of "order all relevant parts, strip and replace, return unneeded parts to supplier." Wasteful but commonplace strategy in the spanner business.
steve the grease
PostPosted: 01:27 - 19 Jan 2020    Post subject: Reply with quote
0.6mm is 24 thou (0.024") in old money. Thats about the same as a sparkplug gap . It absolutely won't make any difference to the bike, that tiny an amount, if something rubs, (it shouldn't ) then any 'competent' garage will soon make up a shim out of sheet metal to space it out. There is always adjustment ...... in your diagram part 14 has a long thread so part 13 can be adjusted up or down with nut 11 to get the adjustment right.
PostPosted: 01:35 - 19 Jan 2020    Post subject: Reply with quote
Hitting the yoke with a hammer will not bother the actual bearings in the slightest. I've seen me whaling directly on a steering beraing race for half an hour with a lumphammer and drift trying to remove it and it just laughed at me. They are made from the hardest of hard steel.
So if there is play there, they either need tightening (most likely) or there is a more fundamental problem like missing ball bearings or damaged yoke.
WD Forte
PostPosted: 01:50 - 19 Jan 2020    Post subject: Reply with quote
We may all be going down the garden path here y'know
As Weasley says, they may just need nipping up.
I bet the OPs never checked the feckers and made a tenous link from
A
someone tried to nick his bike by breaking the steering lock
B
Then it fails the MOT for movement in the forks
( the MOT guy is only going to say it has excessive play
he isn't to going investigate why, not his job)
C
Therefore its 'broken' bearings due to the attempted theft not natural wear,tear and lack of checking/servicing
which all goes back to doing a proper investigation in the first place and not making assumptions
or believing some 'computer says no' spotty yoof in the parts department
On the off chance they are buggered.
I wouldn't be surprised if they're the same as YBR,CG or GN 125 head bearings anyway,
they've cloned just about everything else.
had a look out of curiosity my moneys on the GN 125
From Wemoto:
Suzuki GN 125 02-08 Tapered Headrace Lower Bearing
27x48x14. On RG 125 type NF12 you must re-use the original spacer on the lower bearing.
Suzuki GN 125 02-08 Tapered Headrace Top Bearing
25x45x14mm
bikers smell of wee
jaffa90
PostPosted: 02:06 - 19 Jan 2020    Post subject: Reply with quote
Maybe cheap and nasty like,
https://simplybearings.co.uk/shop/product_info.php?products_id=20027140&vat_inc=true&gclid=EAIaIQobChMIld7gr7iO5wIVCLrtCh29Jg_zEAQYAyABEgJJN_D_BwE
PostPosted: 02:17 - 19 Jan 2020    Post subject: Re: MOT Failure Head Bearings Reply with quote
Codey90 wrote:
Hi all,
Nut 11 is the adjuster for the headstock bearings. Remove bolt 10 to get access to it. Find some way of keeping the front wheel off the floor and have someone push/pull on the wheel to feel for play. Tighten nut 11 until the play is removed but not so much that the steering feels notchy (it won't take much). Once you can feel no front/back play in the steering tighten it all back up and go for your re-test.
yen_powell
PostPosted: 09:59 - 19 Jan 2020    Post subject: Reply with quote
That is exactly the same design as on my 2000 Africa Twin. The ball bearing sit in a plastic ring, you tap the metal cup all the way down the head stock, the shells get tapped into each end of the head stock tube and the plastic ring sits between them in a nice slathering of grease.
If you take the front wheel out it will give you room to undo the whole assembly and lower it with forks still attached to have a look and see if they really are damaged or if they just need a regrease and then readjustment.
XT1200Z and a DR350 in bits
The last post was made 6 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.79 - MySQL Queries: 13 - Page Size: 77.74 Kb
