brakes are crap
Akiraprise
PostPosted: 00:51 - 30 Mar 2005    Post subject: brakes are crap Reply with quote
Ok, went down to collect my bike from the garage today, to be told they'd fitted new pads and fixed the fork seals, So I thought oh great Smile.
Went outside - bumpstarted the bike (they haven't fixed that yet) and when needing the front brake, realised THERE WASNT ONE! There was not one bit of resistance in it, so I started pumping at it (no jokes please) and the resistance finally started coming back, however after doing this loads it's still crap.
I've been told they didn't bleed it - after reading on the net this involves changing oil, but I've been told just to pin the brake to the bars overnight and it should be fixed tomorow.
What do I need to do, the brakes are still very crap at the front.
if it's any help its a 04 derbi gpr
Frost
PostPosted: 01:17 - 30 Mar 2005    Post subject: Reply with quote
Yes they need bleeding, tieing the lever back does help a bit, but thats not what bleeding is.
Just ask them at the garage to bleed to front brake when you get them to look at the starting problem.
Scotsman37
PostPosted: 01:47 - 30 Mar 2005    Post subject: Reply with quote
Have you checked the brake fluid level level in your master cylinder as it may have dropped far to low and do try tie wrapping the brake lever brake back to be left over night as it does actually help it after it's been bleed too.
Akiraprise
PostPosted: 11:48 - 30 Mar 2005    Post subject: Reply with quote
the brake fluid seems fine.
Just took it back up the garage, they told me:
My front disk is worn, so the brake pad's not gripping the surface, once it wears in it'll be fine.
Is this the case? It's only a 9000KM (5000miles) bike so should the disks be worn already?
Anyway they said they'd take a look at it.
Also tied it up to the handles last night, didn't seem to do much - wat does that do? Draw all the air from the brake lines?
Scotsman37
PostPosted: 12:22 - 30 Mar 2005    Post subject: Reply with quote
If you can get hold of a micrometer you can take a note of the general thickness of the brake disk and compare to what it states in the service manual to see if it still within manufacturers guidelines. If it is to thin then you will definitely need a new brake disk(s) or if the surface is rippled then try contacting an engineering company to see if they can skim the surface of brake disk to make it smooth once more.
Another possibility that one of the connection points along the brake line is not torqued properly and so allowing air in or it could be the case that the caliper's non-return valves are allowing air back in.
When tie wrapping the front lever you're best to leave the bike on it's side stand stand with the wheel turned to the left to help any remaining air pockets rise up from the left front brake line.
Robby
Dirty Old Man
PostPosted: 14:50 - 30 Mar 2005    Post subject: Reply with quote
Brake pads can take a while to bed in, And if the disk if a bit worn or scored then they might only be touching 20% of the surface for the first few miles.
Bleeding it is piss easy and takes about 30 seconds, so I'd recommend that - theres a howto somewhere on the forum.
Guest
PostPosted: 14:56 - 30 Mar 2005    Post subject: Reply with quote
So this dealer had fitted new pads but hadn't pumped the pistons back out again?
I wouldn't go there again Rolling Eyes
Patto
PostPosted: 20:09 - 30 Mar 2005    Post subject: Reply with quote
I am a mechanic by trade and if anyone had done that in the shop , the dealership would have been falling over themselves
to placate you as it is seriously incompetent.
They are damn lucky you didn't have a major accident.
having said that , if it is an old bike, the action of bleeding brakes
by pumping the lever has been known to see off a failing brake master cylinder so be sure it is sound and then bleed using the one pump and lock up the nipple method or better still a tight fitting hose over the brake nipple leading into a bottle partially filled
with brake fluid lets you pump continuously on the lever ( watch the level in the pot , make sure it does not run dry ) pump until no bubbles can be seen in the bleed pot, finally hold the lever down and lock off the bleed nipple.
You should then have a firm lever, check that the wheel is braked firmly when applying pressure and released cleanly and completely when letting go of the lever, if not you may have seized or sticking caliper pistons. probably best not to assume your garage would have picked that up when they changed the pads.
if you do nothing else get them brakes working right Thinking
hope this helps you
Patto
Akiraprise
PostPosted: 23:40 - 30 Mar 2005    Post subject: Reply with quote
Thanks for all of your replies,
The bike is only 6 months old and I'd be shocked if the brakes have gone by now...actually judging by build quality i wouldn'\t be at all suprised.
That's what the mechanic said to me aswell, however the brake wasn't working AT ALL when i first went to it - I thought it was the clutch after riding their scooter round Razz.
to placate you
I got no such treatment, however they said they'd try to fix it all the same day, now thats:
Fix brake light
fit new starter motor
fix brakes
fix side panel (on the original panel it touched the exhaust and melted, they fitted the new one and it's melted again).
fix battery / electrics
It wasn't ready same day but picking it up tomorow 12:00 so will post back and see what they 'found'.
Scotsman37
PostPosted: 01:41 - 31 Mar 2005    Post subject: Reply with quote
to placate you
Fix brake light
fix brakes
If you're still not happy then you should be able to get a full refund as it wasn't fit for what is sold for and you didn't get enough usage from it, as noted by Trading Standards under section 5a.
As my friend would say "To be ridden, not looked at".
BFG
PostPosted: 10:53 - 31 Mar 2005    Post subject: Re: brakes are crap Reply with quote
Take it back, and play merry hell with them,. They are full of shit.
Their technical arguments may be valid, but there is no reason for such reasons to still be there when you pick the bike up. Brakes can be bled, brakes can be bedded in.
You should be able to ride out after having work done on the brakes and it should be roadworthy. I.e. it should pass an MOT there and then.
In fact - threaten to take it for an MOT at a different garage immediately after picking it up. Might help.
Personally I would drag the manager over the counter by his tie.
Akiraprise
PostPosted: 11:45 - 31 Mar 2005    Post subject: Reply with quote
ok they said they can't do anything about the brakes as they're bedding in, but they seemed to have done something to them, as they're a bit better, still not very good though - but enough to stop quickish, which i had to try on the way home (bloody van pulled out).
They've fixed
back brake light
starter motor
side panel
fuel tap
But they couldn't find a reason for the battery depletion, it's apparently something to do with my dipped beam as it charges on the full beam, so we'll have to see with that one.
they'd probably laugh in my face, tehre's no MOT in the channel islands Razz.
About sending it back, I sent the letter off yesterday with everyones comments, recorded to derbi head office, and said to reply within 10 days...so we'll see.
Akiraprise
PostPosted: 17:41 - 31 Mar 2005    Post subject: Reply with quote
another update, this time concerning the back brake.
Basically at some point it jammed, luckily the back brakes not very good as i only noticed it after a little bit.
when my bike'd set off it would need revving very high to go off and wouldnt hit the powerband, so i thought i was in second gear, but i wasnt....I then checked choke etc and all the usual stuff but it was fine. Then i played with the brake and it went properly again.
Took it to the garage (with the hydralic oil being below the 'min' level, they fitted new pads, checked the brakes and road tested it for me whilst i waited - good eh?
but seem fine now :s
Guest
PostPosted: 20:51 - 31 Mar 2005    Post subject: Reply with quote
I should bloody well think so given their recent performance - sounds like you've put the wind up them Thumbs Up
bish777
PostPosted: 12:03 - 02 Apr 2005    Post subject: Reply with quote
Next time dont let them let the work experience boy work on your bike ok
In the future invest in a screwdriver set, cheap set of spannners and socket set and do the work yourself lol
GSXR1100J
overdog
PostPosted: 13:33 - 02 Apr 2005    Post subject: Reply with quote
Wotcha mate-another mechanic here(place is full of em...)
Sounds like the muppet who worked on your bike didnt pump the lever to contact the disc after changing the pads.(Confession time-Ive done it meself on my bike and I just about sh1t meself when I needed to stop the thing).
Depending on the disc condition I would say the 20% contact thing is about right-they should get better with use-if they dont take it back to the dealership and ask them to sort it.
FYI unless you asked them to change the fluid they wont have bled the brakes-no need to. Shocked
Ooooh-thats gonna leave a scar!
The last post was made 21 years, 230 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 94.29 Kb
