[CAR] Radiator Fans issue - im stuck! (SOLVED)
Hawkeye1250FA
PostPosted: 15:12 - 04 Feb 2020    Post subject: [CAR] Radiator Fans issue - im stuck! (SOLVED) Reply with quote
Afternoon all,
Opening this up to the world of BCF as I have exhausted everything I can think of.
Car: Honda Civic 57 plate petrol 1.8
Problem : Overheating
Cause : Radiator fan and AC fan not kicking in when up to temp
Stuff tried so far:
1) replaced ECT2 sensor
2) replaced both relays
3) Fans kick in when I complete the circuit from the relay to ground
4) Fuses ok in engine bay
5) Fuses ok in cockpit
Based on the above - I have figured that it was the ECT2 sensor causing the problem, but when I've replaced that, and it still doesnt work - im stumped!
I'm left with two options:
1) Blocked coolant pipes causing no heated coolant to get to the sensor to trigger it
2) Electric issue / damaged wires / etc in the cabling to the ECT sensor
If anyone has any advice on how likely the above is - or if there is another simpler thing to test first, please let me know! Im not working on it again until the weekend, so just getting stuff together now.
Thanks!
1993 RF400R - 2002 Bandit 1200 - 2012 1250 FA
Easy-X
PostPosted: 15:35 - 04 Feb 2020    Post subject: Reply with quote
What sort of situations is the overheating happening? Just stationary in traffic or even when you're moving and getting natural airflow?
Things I find helpful to check: get a Bluetooth/WiFi OBDC dongle and you can plot the temperature sensor(s) on a nice graph in the Torque app. Also, when up to temp, whack on your heater. The heater matrix is like a tiny rad that dumps some of the heat from the water system so getting no heating hints at an airlock. It's also interesting to see if turning on the heater (fan on max) makes any odds to the coolant temp.
If you're okay with auto electrics you could rig up a temporary switch and, coupled with a monitoring app, switch on the fan as you see fit. Not practical but it might help to decide whether it's a coolant flow issue or actually a coolant monitoring issue.
Hawkeye1250FA
PostPosted: 16:08 - 04 Feb 2020    Post subject: Reply with quote
Overheats in all situations, but takes longer if I keep the revs at idling speed. But eventually gets to the red.
Toyed with a switch but it's annoying because all the individual elements work correctly.
I'll try the heater thing later, the heaters do definitely work, but I've not checked if they cool the engine down.
WD Forte
PostPosted: 16:20 - 04 Feb 2020    Post subject: Reply with quote
https://honda-tech.com/how-tos/a/honda-why-wont-my-my-radiator-fan-work-377261
bikers smell of wee
Hawkeye1250FA
PostPosted: 16:44 - 04 Feb 2020    Post subject: Reply with quote
Yeah, already done all that. It's the "non-obvious" issues I need now. 👍
Copycat73
PostPosted: 17:15 - 04 Feb 2020    Post subject: Reply with quote
thermostat fitted wrong way round..
caveat emptor
Hawkeye1250FA
PostPosted: 17:43 - 04 Feb 2020    Post subject: Reply with quote
Thermostat as in ect sensor?
I'd normally say no chance, but at this point I'm willing to try anything! I'll get back under the car on Saturday and check.
jaffa90
PostPosted: 17:51 - 04 Feb 2020    Post subject: Reply with quote
What tells you it is overheating???????
Hawkeye1250FA
PostPosted: 18:00 - 04 Feb 2020    Post subject: Reply with quote
The temperature gauge
The smell of burning
The heat from the engine when I open it
Also if I let it overheat and then stop somewhere, it then won't start until it's cooled down.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:03 - 04 Feb 2020    Post subject: Reply with quote
How many wires to the sensor? Can you bypass it?
Triumph Sprint ST 1050
Hawkeye1250FA
PostPosted: 18:44 - 04 Feb 2020    Post subject: Reply with quote
2 wires, Ive shorted it out to prove it was the sensor (prior to buying and fitting the new sensor) and it didnt run the fans, so bought new sensor and fitted.
Now when i short it, it STILL doesnt run the fans!
Hence me moving on to the relays etc.
This weekends task is to :
- Check that supplying voltage to the relay does actually run the fans which should then prove that the issue is on the sensor side of things.
- Once proved, I cant think of any easy way to do the testing other than dive in with my multimeter and trace the wires from the fusebox to the sensor Sad
I do have a switch ready to go for a "fudge" to mount on the dash - which will just send power to the relay (assuming the above test works).
tbh Id rather that - than crawl around for hours testing which cable is broken! Sad
Nobby the Bastard
Harley Gaydar
PostPosted: 18:53 - 04 Feb 2020    Post subject: Reply with quote
If he shorted out the switch (disconnect ting it and using a it of metal to the two ends of the wires) doesn't switch the fan on it's not the sensor.
Hawkeye1250FA
PostPosted: 18:56 - 04 Feb 2020    Post subject: Reply with quote
Good point Smile
Well I have a new sensor anyway Smile
Nobby the Bastard
Harley Gaydar
PostPosted: 18:58 - 04 Feb 2020    Post subject: Reply with quote
There should be a trigger wire from the control unit (this could be the sensor or it could be the ecu.)
Is there a.voltage there when the engine is hot?
The other positive on the relay will always be live when the ignition is on.
Hawkeye1250FA
PostPosted: 19:01 - 04 Feb 2020    Post subject: Reply with quote
The trigger wire does go from the sensor to energise the relay - My multimeter wire snapped last week so im waiting for the new one to arrive this week. Will test it and see.
Its a proper pain in the arse to get to because its under the radiator. Sad
Nobby the Bastard
Harley Gaydar
PostPosted: 19:05 - 04 Feb 2020    Post subject: Reply with quote
Energise the relay by providing 12 from the battery directly to the trigger with the ignition on.
If it's easier, apply the voltage to the sensor end of the trigger wire.
Hawkeye1250FA
PostPosted: 19:09 - 04 Feb 2020    Post subject: Reply with quote
Cool - will test that.
The sensor is the twat to get to - i need to take the bottom pan off the car to get to it. Thats why ive been putting it off Smile
Looks like i need to though. Sad
yen_powell
PostPosted: 21:58 - 04 Feb 2020    Post subject: Reply with quote
Not an iffy thermostat is it?
XT1200Z and a DR350 in bits
jaffa90
PostPosted: 00:01 - 05 Feb 2020    Post subject: Reply with quote
"""""""Overheats in all situations, but takes longer if I keep the revs at idling speed. But eventually gets to the red."""""
If it overheats on the move then a fan won`t make any difference.
Can air get to the rad?
Is the rad front full of crap?
Is the top hose hot first and then the rad and then the bottom hose warm last?
Any bleed valves? (air pockets)
Does the engine perform ok from cold and when heating up (thinking of a weak mixture).?
You may have to remove top & bottom hoses to check engine & rad circulation,( get the hose pipe out).
WD Forte
PostPosted: 00:08 - 05 Feb 2020    Post subject: Reply with quote
have you tried turning it off and back on again?
bikers smell of wee
Sister Sledge
PostPosted: 07:25 - 05 Feb 2020    Post subject: Reply with quote
The bold bit. Radiators work by air flow. If normal driving on a free flowing road overheats the engine then you have a bigger problem than a sensor.
Faulty thermostat, air locks, faulty water pump, blown head gasket will all show overheating on normal driving cycles.
CCM 404 DS
Hawkeye1250FA
PostPosted: 08:43 - 05 Feb 2020    Post subject: Reply with quote
Ok Thanks gents,
Are you confident in that statement across all car makes and models? Ive purposely overheated the engine and then shorted the fan to run - which then brought the temps back down.
Top hose gets hot first - then lower hoses, although thinking about it, I didnt spend much time on that - so Ill re-investigate that - a blockage could be the culprit.
Dont know of any bleed valves, the only valve I know is the coolant drain under the engine which id imagine wont do the job Sad
Can you expand on the hosepipe test for me? Not done that before but sounds fun Smile
Nobby the Bastard
Harley Gaydar
PostPosted: 08:49 - 05 Feb 2020    Post subject: Reply with quote
If the fan is cooling it down then that's airflow through the radiator. The coolant system is doing its job.
I'm inclined to think it's actually the relay.
Is it a normal 4 prong one? For the sake of 6 quid theres an easy test....
https://www.halfords.com/webapp/wcs/stores/servlet/ProductMobileDisplay?catalogId=10151&langId=-1&categoryId=310504&productId=756415&storeId=10001
Hawkeye1250FA
PostPosted: 08:51 - 05 Feb 2020    Post subject: Reply with quote
Yeah standard 4 prong - theres 2.
1 for the rad fans and 1 for the air con fan
Ive swapped them (no difference) and ended up replacing both with brand new ones.
Hawkeye1250FA
PostPosted: 08:52 - 05 Feb 2020    Post subject: Reply with quote
Another thing to note is the air con fan never kicks in either, which is why im being mentally led down the dodgy elecrics route.
The last post was made 6 years, 30 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 129.55 Kb
