CPI 50 SM Project - Final touches before taking project bike
Ruxlan3
PostPosted: 09:26 - 09 Feb 2020    Post subject: CPI 50 SM Project - Final touches before taking project bike Reply with quote
<Assume I have zero experience with a motorbikes repair>
I’m trying to figure out how to connect my engine so I can get it started for the first time since it was refurbished. I have no idea what needs to connect to what and what I need to buy.
If you can give me some advice I’d be grateful as the manual provided is not covering it.
Here are some photos, it will help greatly if you can reference the photo and number so I can understand what you think I should do. E.g. photo B, connect something at point 1
note: with photo I, I bought a Technigas E-Nox exhaust though I have no idea how to connect it to the frame. What would I need to get?
I can provide as many additional photos as you would like.
Thanks for reading and if you are willing to help, thank you for your time. I really want to be able to ride it to the mechanic, when I got it it was basically scrap.
https://i.ibb.co/tmBpC9V/1st-photo.jpg
https://i.ibb.co/yF2Y1S3/2nd-photo.jpg
https://i.ibb.co/L5qqG2R/3rd-photo.jpg
https://i.ibb.co/fQs0st7/4th-photo.jpg
https://i.ibb.co/2SjhrSZ/5th-photo.jpg
https://i.ibb.co/p0Ty5yM/6th-photo.jpg
https://i.ibb.co/s15FZgR/7th-photo.jpg
https://i.ibb.co/RD9xBz9/8th-photo.jpg
https://i.ibb.co/c1tcrgB/9th-photo.jpg
https://i.ibb.co/cXk4MQF/10th-photo.jpg
Sister Sledge
PostPosted: 09:32 - 09 Feb 2020    Post subject: Reply with quote
Pass the popcorn
CCM 404 DS
Nobby the Bastard
Harley Gaydar
PostPosted: 11:09 - 09 Feb 2020    Post subject: Reply with quote
Why did you take it apart without noting where everything went?
Triumph Sprint ST 1050
PostPosted: 11:26 - 09 Feb 2020    Post subject: Reply with quote
Because clever. Laughing
Much like my reply which doesn't add anything useful or constructive to the thread. Laughing
Someone helpful will arrive in this thread at some point. Mr. Green
Formerly known as
P.
PostPosted: 11:50 - 09 Feb 2020    Post subject: Reply with quote
Bad photos man, but the things are for pillion pegs and where is the bolt for the rear shock. Laughing
Basically... thats going to need someone going over every single part of it, and that first pic is well wrong... Laughing
OK, and right now its close. It needs a proper going over.
Easy-X
PostPosted: 13:35 - 09 Feb 2020    Post subject: Reply with quote
Workshop manual? Dead easy with that!
Anyhoo,
Pic A is the auto lube pump. Pipe 1 is the incoming feed from the oil tank, pipe 2 is the outgoing feed to either a small port on the carb (large port on carb = fuel) or straight to the barrel somewhere. Looks like the pump cable is aligned correctly from that piccy.
Pic B is the fuel tank petcock. This goes to the larger port on the carb. Take a peek in the fuel tank. If it's full of crud you may want to add an in-line fuel filter between the tank and the carb.
Pic C this is the top of the barrel. Not quite sure what you're trying to circle but you should have a jubilee clip or similar on that water pipe on the left!
Pic D a connector (probably ignition) might want to plug that in Smile Don't get tangled up with the flasher relay (brown/brown-white/black) that's in that area.
Pic E looks to be the likely candidate for the oil feed from the autolube system in Pic A. Where's the pipe 1 going to?! Pipe 2 looks to be a case breather pipe, the other end connects to... nothing really, just fresh air Very Happy
Pic F is where the fuel tank / petcock pipe should connect to.
Pic G exhaust mount? Need a better picture (stand back a bit) but yeah, looks a bit janky. I'd need the workshop or parts manual to check in that's right.
Pic H terrible photo! That cable 1 is either from the front brake lever switch or the kill switch, hard to tell. Kill switch probably, judging from the colours. 1.5 - I think you have the throttle at the wrong angle on the handlebars Smile
Pic I - I would imagine some sort of cover went here. Oh yeah! Pillion pegs Smile
Pic J - another breather pipe. Doesn't need to go anywhere.
Hope that helps!
Sister Sledge
PostPosted: 21:06 - 09 Feb 2020    Post subject: Reply with quote
I just knew Easy-X would take the challenge!
Unfortunately I think op might well ignore any advice given. Just a gut feeling..
CCM 404 DS
Easy-X
PostPosted: 22:40 - 09 Feb 2020    Post subject: Reply with quote
Having failed dismally on the Yamaha Custom "what's wrong in this picture?" Facebook ad I thought I'd better put some effort in Smile
The last post was made 6 years, 25 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 59.47 Kb
