| Devoid |
 Devoid L Plate Warrior
 Posted: 10:49 - 27 Feb 2020 Post subject: The Bogging Gremlin - Hyosung GT125R |
Intro
Frustrating problem which sucks the enjoyment out of riding a bike and make me anxious to get on it from fear of getting a car ram me up the ass.
Had this bike in the past had no issues with it loved it so I brought it again after my KTM was giving my jip. Before this issue my Hyosung felt and rode a lot better than my KTM.
The Gremlin
Problem is my Hyosung GT125R has started to run crap, bogging down when pulling away from standing at a traffic light so much so that I need to rev the bollocks out of it to pull away.
Bogging down also affects the bike intermittently when traveling at speed it will pull back and also start bogging down, I have to drop a gear and again rev the bollocks out of the bike to get the revs back up to accelerate.
On some occasion the bogging is that bad I have to pull over(roll actually, maybe even use my foot to push) then play with the throttle (attempt to rev the bollocks out of it) until the bike wakes up again and can continue for a little bit longer before bogging down again.
Then on some occasions the bike seems to run fine with maybe 1 or 2 bouts of slight bogging.
Below is a brief summary of what I remember the mechanic said he did
Mechanic
Cleaned out carbs, re-jet, replaced spark plug cap and plugs, fuel lines checked, all unnecessary electrical mods i.e. led lights disconnected(for troubleshooting, still disconnected now), electrical cables checked, Vaseline applied to particular areas where risk to weathering exists. Exhaust checked for obstruction, throttle tuned, and manual choke cleaned/tuned, cleaned bike. I think that’s everything he said he tried that was in response to the bogging down. £300 that cost several days of work.
He also replaced regular parts during service i.e. brake pads.
Interlude
A week later the bike has started bogging down again, it ran perfect for the previous week after the service, however the mechanic did say it seems to be working now but I have no idea what was really causing it.
Present day
Issue remains and I’ve got to a point where I with little mechanical knowledge plan to investigate this myself with the help of random internet folk, fecking you tube and many other sources such as forums etc.
Requesting help
If anyone has some suggestions of what could be causing this or where I should look, your assistance would be gratefully received.
Please explain the reasons of your suggestions so I can learn rather than blindly following the help so that I may have some understanding of what is going on, like I said I have little knowledge and a base understanding of the workings but more in-depth troubleshooting may be a little more difficult. I play to “dry dock” the bike to work on it in-between working which sucks as I use the bike to get to work so the wife isn’t going to be happy driving me to work 3 days a week.
Information and materials
I have the usual home tools for a bike owner with the extra bonus tool, an impact wrench which I don’t see the need to use with this issue.
High quality pictures and videos of the bike and its guts can be posted on request to aid in the trouble shooting.
Any questions please ask I will do my best to answer and fill gaps.
If something is suggested that has already been tried I will let you know but just because it’s been tried doesn’t mean it’s been done the way you’re thinking so make it a step by step how too if possible.
Finally
Thank you so much for all who add their input I will endeavor to stay in contact here at regular intervals during the battle, family and work. I will post the final solution once it has been identified for others that may run into this issue. |
| Nobby the Bastard |
| Devoid |
| Nobby the Bastard |
| Devoid |
| Nobby the Bastard |
| Devoid |
| Nobby the Bastard |
| pepperami |
 pepperami Super Spammer
 Posted: 12:18 - 27 Feb 2020 Post subject: |
The side-stand switch can become corroded and cause an intermittent fault
I disconnected mine and added a loop, intermittent fault cured .
Might be worth having a look there? ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| Devoid |
| Devoid |
 Posted: 12:23 - 27 Feb 2020 Post subject: |
| pepperami wrote: | The side-stand switch can become corroded and cause an intermittent fault
Might be worth having a look there? |
That was the first attempt to fix this issue. The mechanic had that safety feature disabled at my request but the problem persisted. |
| Nobby the Bastard |
| Riejufixing |
 Riejufixing World Chat Champion
| Nobby the Bastard |
| Easy-X |
 Easy-X Super Spammer
| pepperami |
| P.addy |
 P.addy Formerly known as P.
| martin734 |
 martin734 Spanner Monkey
| Sister Sledge |
 Sister Sledge World Chat Champion
| Nobby the Bastard |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 05:08 - 28 Feb 2020 Post subject: |
Intermittent or randomly occurring problems are always a bast to trace, cos you never know when they are gboing to occur, or if something you have 'fixed', was actually the problem to start with.... that's the nature of the game... good luck.
First bit of normal diagnostics though is a plug-chop. Look in the Heynes manual, usually at the back, and there's usually a photo chart showing what bad spark plugs look like for you you to compare yours too.... when you pull it out and if when you pull it out the problem was happening...
But, to this end, stick a spark-plug spanner in your pocket or in the gap twixt seat and tank... possibly a pair of pliers or a cotton rag too cos spark plugs tend to be hot when removed from a hot engine... and watch your fingers... go ride the bike 'till symptoms occur, haul in the clutch, coast to a halt and pull plug(s) and coimpare to piccies.
IF plugs black and sooty, you are over fueling. Usually implies that the choke is stuck on, and or you are burning oil 'cos valve stame seals or piston rings are worn out.
If white and maybe knobly, tends top mean that the engine's running weak, like it's run out or petrol, indicating that the jets are blosked and or your float needle is sticking in it's guide.... that, at the mo is a top candidate, as it wont always stick...
But this is first resort checking.. and an excuse to just ride around a bit...
Go try, report back on plug colour... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| stevo123 |
 stevo123 Nitrous Nuisance
| A100man |
 A100man World Chat Champion
| Devoid |
The last post was made 5 years, 359 days ago. Instead of replying here, would creating a new thread be more useful? |
