Kia Rio 2008 car woes - wont start
kramdra
PostPosted: 19:08 - 21 Mar 2020    Post subject: Kia Rio 2008 car woes - wont start Reply with quote
Please help with this - dads car, it is essential for him as a carer for my uncle and gran who are both seriously Ill, 30 miles away. It was recently serviced before.andnafter this problem started.
Wont run. I suspect it has an intermittent wiring fault. RAC guy claims its the crank angle sensor, new replacement did not help. When fault it does not try to start, turns over freely. It often takes about 5 seconds to fire up but often instant.
I have checked all visible connectors for corrosion and sprayed with wd40. It has HT cables which I find odd for a 12year old car. I will pull the plugs and check them next.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:09 - 21 Mar 2020    Post subject: Re: Kia Rio 2008 car woes - wont start Reply with quote
Have you connected an OBI reader to it?
Triumph Sprint ST 1050
kramdra
PostPosted: 19:38 - 21 Mar 2020    Post subject: Reply with quote
I have not got one, both RAC and garage have and claim Crank sensor is the problem.
WD Forte
PostPosted: 19:41 - 21 Mar 2020    Post subject: Reply with quote
Try changing the key fob battery as it may not be disabling the immobiliser
Check fuses
Open check clean all related connectors
I seriously doubt all 4 plugs and/or HT leads would fail at the same time
is it carb or FI?
bikers smell of wee
Nobby the Bastard
Harley Gaydar
PostPosted: 19:48 - 21 Mar 2020    Post subject: Reply with quote
Did they clear the error?
WD Forte
PostPosted: 19:49 - 21 Mar 2020    Post subject: Reply with quote
This may give some clues
https://www.cargurus.com/Cars/Discussion-t42997_ds673076
bikers smell of wee
A100man
PostPosted: 10:50 - 22 Mar 2020    Post subject: Reply with quote
Crank sensors have been know to be faulty from new I believe. May be worth trying another. Not too dear I think.
bugeye_bob
PostPosted: 11:57 - 22 Mar 2020    Post subject: Reply with quote
https://youtu.be/Wf0q3VVggg4
Tankie
PostPosted: 12:39 - 22 Mar 2020    Post subject: Reply with quote
On the crank sensor is an "o" ring which makes the sensor sit too high causing it to misread the crank position , remove and refit sensor
kramdra
PostPosted: 19:36 - 22 Mar 2020    Post subject: Reply with quote
That is interesting as the RAC guy tried a new sensor, didnt help so he put the old back, but seems with two oring seals. Garage has since refit I assume with just one.
It started today. Second try. I really think it is immobiliser as light went off just as it fired.
Tankie
PostPosted: 19:49 - 22 Mar 2020    Post subject: Reply with quote
The reason any o rings are removed is to get the sensor closer to the flywheel , a kia dealer told me this trick, the o ring is just to stop the ingress of crap
The last post was made 6 years, 214 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 71.47 Kb
