| RXS katie |
 RXS katie L Plate Warrior
 Posted: 11:10 - 30 Mar 2005 Post subject: RXS1OO Indicators |
Hi, does anybody out there have any ideas how to make the indicators on my RXS brighter? They are hardly visible in daylight  |
| Josh|RD125LC |
 Josh|RD125LC World Chat Champion
 Posted: 12:10 - 30 Mar 2005 Post subject: |
Are they much dimmer when you have your headlights on? Because if they are, this happened to me a while back, and its most probably meaning that you need to charge your battery. Others may have something else to say though. ____________________ Honda MBX50 | Yamaha RD125LC | Suzuki RG125F Lucky Strike | Suzuki GSF600S
RD125LC Pictures |
| Kickstart |
 Kickstart The Oracle
 Posted: 13:33 - 30 Mar 2005 Post subject: |
Think the RXS has a 12V system. Probably worth giving the battery a good charge off the bike and checking that it is healthy.
Not sure whether the RXS has an electrical system all working off DC from the battery. If it does then try using some LED bulbs. Also worth replacing the relay with a new one (as it will be at least a decade old and probably a bit worn and corroded inside). Also clean up all the connectors. Also worth checking the reflectors in the indicators. Likely that these have dulled with age.
| ashhot84 |
 ashhot84 L Plate Warrior
| RXS katie |
 Posted: 18:07 - 30 Mar 2005 Post subject: Indicators |
It has a 6V system and only the indicators work direct from the battery! The problem is that there is only one wire to the indicators and so I can't change for a different type cos most have two wires!!!  |
| Patto |
 Patto Derestricted Danger
| Kickstart |
 Posted: 20:51 - 30 Mar 2005 Post subject: |
The indicators on your bike probably earth directly to the frame where they bolt on. As such the chances are that you can buy new indicators with 2 wires and just run one of the wires straight to earth.
Cheap replacement ones in the same style as the original ones would be around £10 each.
I would take the lenses off and clean up the reflectors first, and also clean the inside of the lenses thoroughly.
| Kickstart |
 Posted: 20:53 - 30 Mar 2005 Post subject: |
| RXS katie |
 Posted: 21:55 - 30 Mar 2005 Post subject: |
Thank you for all the advice!! I'll let you know how it goes.  |
| RXS katie |
 Posted: 21:56 - 30 Mar 2005 Post subject: |
| RXS katie |
 Posted: 21:57 - 30 Mar 2005 Post subject: |
The last post was made 21 years, 190 days ago. Instead of replying here, would creating a new thread be more useful? |
