| Robthepiano |
 Robthepiano Derestricted Danger
| stinkwheel |
 Posted: 21:59 - 03 Apr 2020 Post subject: |
It'll run because the spark is on a different coil and I think it'll run the lights too without the battery (if they don't come on with the engine off, the lights are direct powered).
However the flashers, horn and brake light come off the battery.
One concern is that the charging system on these bikes is pretty weedy in terms of output so you may be drawing more than it can give.
Flashers is an easy fix. Fit LED bulbs and an electronic relay. I'd do this anyway, saves a lot of grief and makes for good, bright, reliable flashers.
It may be that the battery is so flat your optimiser isn't detecting enough voltage to start charging (doesn't know it's connected to a battery). You can sometimes "jump" thenm into charging mode by connecting them up momentarily to another 12v battery across the terminals.
You could also check this by testing the resting voltage of your battery. Anything below about 9v and a lot of chargers wont kick in.
Or run the bike for a bit to get some charge into it.
If you repeatedly flatten the battery, you will kill it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Robthepiano |
| Robthepiano |
| stinkwheel |
 Posted: 18:10 - 05 Apr 2020 Post subject: |
Older CG125s have direct AC lighting, newer ones have DC lighting. I'm not sure where the cut-off is in terms of models but if the headlight will come on with the engine off, it's DC. If they only work with the engine running, it's AC.
You can't use an LED bulb with AC. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Easy-X |
 Easy-X Super Spammer
| stinkwheel |
The last post was made 6 years, 173 days ago. Instead of replying here, would creating a new thread be more useful? |
