Gsxr k1 dead after trying to jump start it.
Dan5jj81
PostPosted: 19:30 - 05 Apr 2020    Post subject: Gsxr k1 dead after trying to jump start it. Reply with quote
As per the title I tried to jump my GSXR 750 k1 off my other bike but my leads touched together and after a few sparks my bike is dead.
I have checked the 30 amp fuse that is fine and the bike will try turn over by bridging the black and red terminal.
Where to look next? Green plug on the left side?
I have no idea about electrics any help will be greatly appreciated.
PostPosted: 19:42 - 05 Apr 2020    Post subject: Reply with quote
Wasn't it dead before you started? Otherwise, why were you trying to jump it?
What were the leads connected to at the time of the incident and which end did you short-out (donor bike or recipient)?
There are a whole load of other fuses which may be worth a check too.
Dan5jj81
PostPosted: 19:45 - 05 Apr 2020    Post subject: Reply with quote
No the bike was just fine it didn't quite have enough power in the battery to start it. Now it's totally dead other than what I stated. I'm just wondering where to look next for power issues
PostPosted: 19:47 - 05 Apr 2020    Post subject: Reply with quote
I'd lead with the fuse box.
Dan5jj81
PostPosted: 19:48 - 05 Apr 2020    Post subject: Reply with quote
Just read the last message in full. Great thanks. I can see 8 other fuses on the right side of the bike near the handle bar. Are there any more?
RhynoCZ
PostPosted: 21:36 - 05 Apr 2020    Post subject: Reply with quote
Is it fuel injected? Do you hear the fuel pump after you turn the key on?
Dan5jj81
PostPosted: 22:17 - 05 Apr 2020    Post subject: Reply with quote
Yes it's fuel injected. I'm not with the bike now but I'm sure I couldn't
RhynoCZ
PostPosted: 21:01 - 06 Apr 2020    Post subject: Reply with quote
Well, that's not good. Check all the fuses and hope you didn't burn the ECU. I do believe the fuel pump has to have its own relay and fuse, so I would start there. I take it the START button does nothing at the moment, right? Maybe the ECU won't engage the starter without the fuel pump running. It'd be also good if we knew whether the ignition still produces sparks.
Dan5jj81
PostPosted: 21:06 - 06 Apr 2020    Post subject: Reply with quote
Thanks for the reply. Bridged the starter relay with an old spanner it tried to start the bike. I will try find where the ECU fuse is. I'm not sure where all the fuses are. I will go to the bike now
RhynoCZ
PostPosted: 21:13 - 06 Apr 2020    Post subject: Reply with quote
When you bridge the starter relay you by-pass every electrical system on the bike. This only tells us the starter works and the battery is good enough to spin it.
Dan5jj81
PostPosted: 21:15 - 06 Apr 2020    Post subject: Reply with quote
Right ok thanks. I'm not sure how to check the ECU? I have a multi meter but I'm not sure how to use it
RhynoCZ
PostPosted: 21:22 - 06 Apr 2020    Post subject: Reply with quote
Just wondering, do you get any power at all to the bike when the key is in the ON position? Do the lights work? IF there is no power, whatsoever, the main fues must be at fault.
Checking the ECU requires a skilled electrician/engineer. The easiest way of checking whether it works is to replace the unit with a working one.
Dan5jj81
PostPosted: 21:24 - 06 Apr 2020    Post subject: Reply with quote
The neutral light comes on. The main fuse looks ok
RhynoCZ
PostPosted: 21:29 - 06 Apr 2020    Post subject: Reply with quote
Are you sure the kill switch is in the ON (run) possition? Do you hold the clutch in when starting the engine? Suzuki bikes tend to have that, the clutch in thing.
I know these things sound obvious, but once upon a time, I forgot about the killswitch (my first bike with such killswitch) and I couldn't start the engine for more than half an hour, I even tried to push start it, several times. Embarassed
Dan5jj81
PostPosted: 21:32 - 06 Apr 2020    Post subject: Reply with quote
Kill switch is on as in good to go. No lights anywhere other than neutral light.
Dan5jj81
PostPosted: 21:55 - 06 Apr 2020    Post subject: Reply with quote
So I guess my next question is what would be the symptoms of a fried rectifier? I just thought that it just wouldn't charge the battery.
So if it's the ECU would it be likely to have fried the rectifier also?
Right so my 3rd question is could I just pug in a new ECU?
Thanks
Riejufixing
PostPosted: 22:22 - 06 Apr 2020    Post subject: Re: Gsxr k1 dead after trying to jump start it. Reply with quote
Going back to that, how exactly did the "leads touch together" and where were the sparks from?
Did you connect to your bike, and short the leads at the other end, short your battery/the other battery to the frame, or connect something the wrong way around, disconnect your battery, or what? Did you connect to the battery of your bike, or a lead to an earth on the bike, or what did happen, as you best remember it?
Dan5jj81
PostPosted: 22:26 - 06 Apr 2020    Post subject: Reply with quote
I was using quite heavy duty leads over to my other bike. It was a bit if a struggle to keep them on whilst trying to pull the clutch and start it. The positive lead moved and touched the negative. A fair few sparks then zero power other than the neutral light. No lights at all other than that
Dan5jj81
PostPosted: 22:28 - 06 Apr 2020    Post subject: Reply with quote
The sparks seem to come from just where the leads touched. But incidentally I think that's above the ECU
Riejufixing
PostPosted: 22:46 - 06 Apr 2020    Post subject: Reply with quote
When you bridged the starter relay, did you use the terminals there somehow, or bridge from the battery to the starter side of the relay, or the starter motor? I have no idea what is positioned where on your bike, you see.
Dan5jj81
PostPosted: 22:48 - 06 Apr 2020    Post subject: Reply with quote
They are near the battery I did it with an old spanner
Riejufixing
Can you test it (meter)?
Dan5jj81
PostPosted: 22:49 - 06 Apr 2020    Post subject: Reply with quote
What do I test? The battery is at 12
Dan5jj81
PostPosted: 22:51 - 06 Apr 2020    Post subject: Reply with quote
I can go test the fuse but I have already tried other 30 amp fuses
Riejufixing
PostPosted: 23:03 - 06 Apr 2020    Post subject: Reply with quote
Oh, OK. There may be another fuse to check (10A, although I can't see how shorting the battery terminals should blow a fuse...):
https://www.manualslib.com/manual/813897/Suzuki-Gsx-R750.html?page=429&term=fuse&selected=16
The last post was made 6 years, 168 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 121.02 Kb
