Another Dodgy Chinese 125
R1stu
Shrek!
PostPosted: 13:40 - 13 Apr 2020    Post subject: Another Dodgy Chinese 125 Reply with quote
Hey up folks. While lockdown is in place I thought I have a go at fixing the misses HN125-8
The electrics seem a bit screwy, as I have either no spark or such a tiny spark you can barely see it. so far I have
New plug
New Coil
Tested loom for continuity
Get fuel to the engine
have good compression
I have tested the diode next to the rectifier, and it is reading ok in both directions, so I assume this is ok?
There are a few nicks in the stator wiring, Would this be a cause of the issues?
How can I test the stator and pickup? a mate says these can cause the same issue.
The diode seems to be part of the clutch switch circuit according to this diagram.
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
Riejufixing
PostPosted: 15:07 - 13 Apr 2020    Post subject: Re: Another Dodgy Chinese 125 Reply with quote
HN125-8 ? That sounds like a virus itself! Wink It hasn't got a kill switch, has it? Just a thought...
PostPosted: 15:15 - 13 Apr 2020    Post subject: Reply with quote
Good god, you are playing with fire with that title.
Linuxyeti will release the wrath of 1000 Chinese camels on you for disrespecting their bikes. Laughing
Triumph Trophy Launch Edition
WD Forte
PostPosted: 18:46 - 13 Apr 2020    Post subject: Reply with quote
Not sure I trust that diagram as that shows a DC powered CDI ignition
not an AC powered type
An AC powered type would have a source coil at the stator
Ebay says this thing below is an Hn125-8 stator and you can see the source coil at the top and the black box to the left is the pulser
https://i.ebayimg.com/images/g/n-cAAOxyzi9Smg-R/s-l1600.jpg
A stator that conformed to your diagram would only have the charge coils and pulser
You need to establish what it is you have before you can start to debug it
AC source coils usually have a resistance of say 200-400 ohms
bikers smell of wee
R1stu
Shrek!
PostPosted: 19:19 - 13 Apr 2020    Post subject: Reply with quote
I have taken the stator off, and it looks the same as that, with 300 ohms.
The wires were nicked and showing the core on 3, I taped them all up.
I've rubbed the frame down, and put the original coil on and nothing else other than cdi, and its now running off the kickstart.
I am going to had each electrical part back and see if it falls over again.
The last post was made 6 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 49.99 Kb
