Speedfight 3 50cc issues!
Butch1978
PostPosted: 20:18 - 20 Apr 2020    Post subject: Speedfight 3 50cc issues! Reply with quote
Ok here it goes abit of a long story!
I brought a speedfight 3 for my boy last year, his previous bike was written off so I had to replace it! The bike was cheap and now I know why 😂! It was originally spluttering and then cutting out and irregular revs! We put a new carb, new reeds and there was a split in the airborne which was repaired! The bike ran you a day! But hit full revs without using the throttle! Then wouldn’t start! We got it started But it constantly revs to the maximum! I am scratching my head as to understand why! Can anyone please help me before I accidently poor petrol over it it and flick a match at it 😂😂! The previous owner changed the rollers and put a sports clutch in! Not sure if that has something to do with the issues! Any help or suggestions gratefully received!
Riejufixing
PostPosted: 20:25 - 20 Apr 2020    Post subject: Reply with quote
Sounds like the throttle sticking or being held open.
The clutch and the roller change are pretty much irrelevant (and also probably unhelpful; not bad, just of no "performance" use whatever).
Butch1978
PostPosted: 20:30 - 20 Apr 2020    Post subject: Reply with quote
The throttle cable isn’t sticking and it moves as it should! It just goes straight Max revs when it starts! And won’t back down unless it’s turned off!
Riejufixing
PostPosted: 20:43 - 20 Apr 2020    Post subject: Reply with quote
Does it emit huge clouds of smoke?
Butch1978
PostPosted: 20:45 - 20 Apr 2020    Post subject: Reply with quote
Nothing more than any other peds I have had
Riejufixing
PostPosted: 20:56 - 20 Apr 2020    Post subject: Reply with quote
If the throttle was closing it should not go to max revs.
If it revs up it should be trying to move off and should not immediately get to max revs.
jaffa90
PostPosted: 20:57 - 20 Apr 2020    Post subject: Reply with quote
Which carb is it?
Does the throttle cable enter the top of the carb or does it work at the side?
Butch1978
PostPosted: 21:05 - 20 Apr 2020    Post subject: Reply with quote
jaffa90 wrote:
Which carb is it?
The cable comes from the top! I will have to check Tommorrow! But it is an OEM standard carb
Butch1978
PostPosted: 21:06 - 20 Apr 2020    Post subject: Reply with quote
It revs like the throttle is on full! But it’s not! Note stuck! Which is really doing my head in!
PostPosted: 21:10 - 20 Apr 2020    Post subject: Reply with quote
It's a speedfight for pity's sake. It really bugs me that people call it a damn speedfighter. I don't know why that bugs me so much but it does.
cresad
PostPosted: 21:17 - 20 Apr 2020    Post subject: Reply with quote
I know this might sound a bit out there but is the throttle slide the right way round , this could cause what your saying.
Butch1978
PostPosted: 21:18 - 20 Apr 2020    Post subject: Reply with quote
Thanks for your useful input to the problem! Very helpful! But will change the post title to make you feel better 😂
bypass2
PostPosted: 21:19 - 20 Apr 2020    Post subject: Reply with quote
is the throttle slide fitted correctly. throttle slide screw in to far.faulty choke
Butch1978
PostPosted: 21:22 - 20 Apr 2020    Post subject: Reply with quote
Just to note the SPEEDFIGHT” “😂” has been started without the throttle cable attached! And it still high revs! So it’s not a Sticky cable
Butch1978
PostPosted: 21:24 - 20 Apr 2020    Post subject: Reply with quote
The auto choke has been disconnected and it still does it!
Riejufixing
PostPosted: 21:28 - 20 Apr 2020    Post subject: Reply with quote
You still haven't said whether or hot the throttle is sticking. If there's a slice in the carb, check that and that it's assembled properly (as others have said).
Butch1978
PostPosted: 21:29 - 20 Apr 2020    Post subject: Reply with quote
Forgot to mention that it was running fine! But when I gave it a long test run! A few days after the carb was fitted, It kept revving high when stationary! But only for a few seconds, then ticked over fine! Then when I dropped down from Full speed After about 10 minutes of riding that’s when the maximum rev kicked in! It popped off the lubricant pipe as well! Which I thought was strange as they are a tight fit in the carb!
Butch1978
PostPosted: 21:30 - 20 Apr 2020    Post subject: Reply with quote
It’s not sticking! The cable has been removed and still high revving! It was running fine for a day then became possessed!
Nobby the Bastard
Harley Gaydar
PostPosted: 21:43 - 20 Apr 2020    Post subject: Reply with quote
Video of the carb slide as you action the throttle plus.
Triumph Sprint ST 1050
jaffa90
PostPosted: 21:48 - 20 Apr 2020    Post subject: Reply with quote
""""The auto choke has been disconnected and it still does it!"""
I thought the auto choke needed connection for it to work and come off providing it works !
Butch1978
PostPosted: 21:50 - 20 Apr 2020    Post subject: Reply with quote
I will try and get a video Tommorrow! But it full revs with the throttle cable disconnected! Which is why I am so confused!
Riejufixing
So perhaps the slide isn't closing, or it's put together wrongly. Have a look at it.
Butch1978
PostPosted: 21:52 - 20 Apr 2020    Post subject: Reply with quote
The auto choke was removed because we thought that was causing the issue, but it wasn’t! It didn’t need the auto choke connected to start After a few attempts to diagnose the issue
Butch1978
PostPosted: 21:58 - 20 Apr 2020    Post subject: Reply with quote
Thanks! Will try and strip the carb down again and have a look! Something is defiantly wrong! And is frustrating!
Butch1978
PostPosted: 21:59 - 20 Apr 2020    Post subject: Reply with quote
Just seems strange that it was working for a day then didn’t after about 15 mins or so 🤔
The last post was made 6 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 125.17 Kb
