Ultrasonic cleaners
PostPosted: 09:34 - 22 Apr 2020    Post subject: Ultrasonic cleaners Reply with quote
What's the best concoction to use in a ultrasonic cleaner when you have run out of the proper fluid. I've tried water with washing up liquid and it's no where near as good.
Has anyone got any tips using stuff from around the house as my cleaning fluid doesn't look like coming for a week or so.
I have 2 cleaners, 1 big and 1 small so I can get away with smaller amounts for now, probably half a litre.
Triumph Trophy Launch Edition
PostPosted: 10:35 - 22 Apr 2020    Post subject: Reply with quote
I found a safety data sheet for carb cleaning ultrasonic solution.
https://cdn.bcf.44bytes.net/files/ultrasonic_cleaning_solution.jpg
It seems to be 10% volatile organic chemicals and I don't think there is much if any detergent in there. I'd say paraffin would be closer than water and washing up liquid? I'm not sure whether that's safe to use in an ultrasonic cleaner though?
PostPosted: 10:45 - 22 Apr 2020    Post subject: Reply with quote
Jesus, that looks nasty. Perhaps I'd better be a bit more careful with the real stuff when it arrives. Laughing
PostPosted: 11:01 - 22 Apr 2020    Post subject: Reply with quote
It's basically sodium silicate and a few solvents. It's certainly not on the nastier end of what is legally allowed to be sold to ordinary folk. Don't drink it, basically!
TravisBickle
PostPosted: 18:46 - 22 Apr 2020    Post subject: Reply with quote
Stab in the dark - carb cleaner if you can get it a liquid (non aerosol) form???
2024 BMW M1000XR
2021 Honda CMX500 Rebel S
2016 Triumph Tiger 1050 Sport
PostPosted: 19:04 - 22 Apr 2020    Post subject: Reply with quote
The problem is that's quite expensive, and not diluted. The volatile elements of the mixture need to be soluble so you can mix it with water.
I'll ask the missus (who has a masters in organic chemistry and is pretty much an expert in industrial cleaning solutions) when I get a chance. Thumbs Up
PostPosted: 19:14 - 22 Apr 2020    Post subject: Reply with quote
I did this. She said the alchohols make it evaporate, and the sodium Silicate is a thickener (which she's not used). It contains EDTA which is a chelating agent apparently.
She said that it has to be a formulated cleaner, but nothing too specific - her words were 'it's not a sophisticated cleaner'. She suggested floor cleaner? or Glass cleaner? She said fairy liquid was not a good idea.
Basically look for something that contains MEA and EDTA:
https://en.wikipedia.org/wiki/Ethanolamine
https://en.wikipedia.org/wiki/Ethylenediaminetetraacetic_acid
She's concerned about advising anything specific because she doesn't know about the ultrasonic cleaner and whether it's safe to use certain things in it? But she also said if she found the right product she'd know... It's not a simple answer sadly. For example different glass cleaners contain different ingredients so not all glass cleaners will work.
TravisBickle
PostPosted: 19:19 - 22 Apr 2020    Post subject: Reply with quote
Women! About as useful as the clip-on motorcycle handlebar ashtray designs I have on patent Thinking
2024 BMW M1000XR
PostPosted: 19:22 - 22 Apr 2020    Post subject: Reply with quote
Cheers Marjay.
We have glass cleaner so I'll try that. If it works I'll get a few bottles from Asda tomorrow to tide me over.
PostPosted: 20:27 - 22 Apr 2020    Post subject: Reply with quote
Polarbear wrote:
Cheers Marjay.
Look at the label, if it contains EDTA and MEA then it's OK. If it's got vinegar in? probably not because that's a different way of stopping the glass from going streaky. Sadly, glass cleaner is not just 'glass cleaner' and floor cleaner is not 'floor cleaner' even though there is a small number of chemicals that work to clean things and are still legal.
Hong Kong Phooey
PostPosted: 10:41 - 26 Apr 2020    Post subject: Reply with quote
You can put whatever your choice of cleaning fluid in a bag with the parts, then immerse the sealed bag in the ultrasonic bath, which you just fill with tap water.
The cleaning works as the ultrasonic pulses travel through the bag.
The dirty fluid gets thrown away, you'll have used less of it and the ultrasonic cleaner is pristine.
Riejufixing
PostPosted: 11:30 - 26 Apr 2020    Post subject: Reply with quote
That's a great idea! Thumbs Up
However, it's nothing really, in comparison to using trinitroxypropane fluid in your ultrasonic cleaner, which will clean the component, the cleaner, you, the room you're working in and, depending on how big your cleaner is, potentially the entire building.
kolu
PostPosted: 12:16 - 26 Apr 2020    Post subject: Reply with quote
Any idea where to buy in bulk? Just for the fun, you know...
Riejufixing
PostPosted: 12:23 - 26 Apr 2020    Post subject: Reply with quote
It's poison, amongst other things, so you'd have to apply to your local police for a permit. The only trouble is you'd probably only be able to obtain a more solid form, so it might be better to just make it. Tell them you're doing it, of course.
Suntan Sid
PostPosted: 13:06 - 26 Apr 2020    Post subject: Reply with quote
I don't have an ultrasonic cleaner, can't justify the cost.
However a while back I needed to clean the teeth of a tablesaw blade, they get covered in a "varnish" which, presumably, is the glue in plywood and other manmade boards melting and then coating the teeth.
It's a bugger to get off even with abrasives.
I got a washing up bowl, filled it with enough hot water to cover the blade and chucked in a dishwasher tablet.
Five minutes later the saw blade was like new.
Since then I've tried it on a couple of brass items, I found in the garden, obviously been there for decades, scrubbing with a plastic scourer didn't touch them, hot water and a dishwasher tab worked straightaway.
May be worth a shot in an ultrasonic cleaner!
- This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
panrider_uk
PostPosted: 11:21 - 30 Apr 2020    Post subject: Reply with quote
- wrote:
The Aldi ones are abut £25 and big enough to fit a carb in. For someone with a second home in Cyprus, that's hardly breaking the bank.
I use mine a lot, being into old 2T's and it's worthy it's weight in gold to me.
No need - just antagonises.
PostPosted: 12:32 - 30 Apr 2020    Post subject: Reply with quote
It's a thread about ultrasonic cleaners and - has to be a d*ck about it.
PostPosted: 14:58 - 30 Apr 2020    Post subject: Reply with quote
You had to have a dig with a political slant though, in a totally non political thread? That is a dick move however you cut it.
Just go, just leave. Just don't ever log on here... It's boring and it can't be doing you any good.
PostPosted: 16:08 - 30 Apr 2020    Post subject: Reply with quote
To update - glass cleaner worked reasonably well. Not as good as the proper liquid but then you wouldn't expect that.
I'm going to try water and a dishwasher tablet just for the lols but that will be in my big cleaner, I think it will be a bit much with one tablet in the 500ml of liquid my little cleaner takes.
Any way, the proper stuff should arrive tomorrow or Monday but it's fun experimenting.
panrider_uk
PostPosted: 16:58 - 30 Apr 2020    Post subject: Reply with quote
Would be interested in knowing how that goes.
hellkat
PostPosted: 18:02 - 30 Apr 2020    Post subject: Reply with quote
*wanders in, wonders what ultrasonic cleaner actually is, but wanders back out again anyway, wondering if there's such a thing as a recipe for piña colada flavoured biscuits*
edit: found one Cool Thumbs Up
The last post was made 6 years, 128 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 133.53 Kb
