Dirty Chinese Quad
Stanlee
PostPosted: 12:49 - 25 Apr 2020    Post subject: Dirty Chinese Quad Reply with quote
New here but not to bikes.
During this lockdown period I have been unlucky enough for one of my neighbours to donate a sickly Apache 4S quad 50cc for my 7 yr old.
It has been stood so here we go:
Stripped out carb cleaned all jets needle float, set float.
CV carb so replaced lines splits in at least 2
Carb manifold boot split now repaired.
Fuel pump replaced.
Carb has new K&N style filter fitted no sign of original air box!!
Bike will not start without putting hand over the air intake, it then sucks fuel through and with hand removed and fettling of the throttle will run badly at full throttle or runs for 10 seconds and bogs down.
Seems to me it is not getting enough fuel through or to much air.
These things are bad enough when new!
Any ideas appreciated as now have 7yr old asking when it will be running every day of lockdown!!
Thanks
Stannerz
A100man
PostPosted: 11:07 - 27 Apr 2020    Post subject: Reply with quote
50cc with a cv carb - you sure?
Have you checked valve clearances/ tappets - assuming its a four stroke..
Stanlee
PostPosted: 11:30 - 27 Apr 2020    Post subject: Reply with quote
Yes unfortunately so with auto choke!
No fuel tap two inline filters, plenty of pump when the engine turns so assuming fair compression
Don't really want to go to the pain of checking clearance and no reference to sizes available to me.
Thanks
Stannerz
Easy-X
PostPosted: 11:38 - 27 Apr 2020    Post subject: Reply with quote
I would imagine it's based on scooter tech. Does it have a gearbox or is it CVT?
Stanlee
PostPosted: 11:45 - 27 Apr 2020    Post subject: Reply with quote
CVT
Previous owner says carb was renewed but obviously has been stood as it was green inside and the needle was stuck in position all been cleaned and set at least four times so far.
If I place my palm over the carb intake there is plenty of pull and fuel vapor on palm, keep cranking with hand removed and feathering the throttle can sometimes get it to run very poorly at full throttle.
I have it jacked up at the rear !!
Or will fire run for 5-10 seconds then die
Stannerz
Riejufixing
Something's still bunged up. Take the carb apart again and double-check. Don't poke jets through with wire, use air or a plastic bristle. Water in there somewhere? Corrosion? "Detritus"?
Pics?
Stanlee
PostPosted: 12:03 - 27 Apr 2020    Post subject: Reply with quote
Will get some pics and strip it again as I have time on my hands.
Thanks
Stay Safe.
Stannerz
PostPosted: 12:40 - 27 Apr 2020    Post subject: Reply with quote
If it's a CV carb, have you checked the diaphragm for splits/pinholes?
Stanlee
PostPosted: 13:53 - 27 Apr 2020    Post subject: Reply with quote
Here's a few pics attached
Sadly can't do much more for now as the solenoid just gave up the ghost and now no crank! just gets better!
Stannerz
Stanlee
PostPosted: 13:55 - 27 Apr 2020    Post subject: Reply with quote
Or not!
will not let me post up any images for some reason!
Stannerz
PostPosted: 17:06 - 27 Apr 2020    Post subject: Reply with quote
You can short across the terminals of the solenoid with a bit fo metal and it'll turn over.
Stanlee
PostPosted: 18:20 - 27 Apr 2020    Post subject: Reply with quote
Cranking and pushing fuel like a good un but not firing
Will strip carb again tomorrow and new plug
Thank all for input, any idea how to attach pics??! says add attachment, browse, add but no joy!
Stay safe
Stannerz
PostPosted: 18:57 - 27 Apr 2020    Post subject: Reply with quote
Stay safe
There may be a small message comes up on the next screen but the text is quite small, easy to miss it. There is a maximum file size of 1MB for images.
Stanlee
PostPosted: 19:04 - 27 Apr 2020    Post subject: Reply with quote
Thanks Stinkwheel that will be it!
Will try to resize unless I get joy! tomorrow
Stannerz
Stanlee
PostPosted: 19:29 - 27 Apr 2020    Post subject: Pics Reply with quote
Pics
Stannerz
A100man
PostPosted: 23:02 - 27 Apr 2020    Post subject: Reply with quote
water or diesel in the fuel?
Easy-X
PostPosted: 02:14 - 28 Apr 2020    Post subject: Reply with quote
Pretty much a 50cc scooter engine whacked in a quad frame...
For "fun" I did experiment with pod filters on my "Turd Scooter" refurb. You might want to look over the thread in "Show & Tell" as it looks to be basically the same engine. Basically I gave up and used the stock airbox and all was lovely.
Is it the stock exhaust? What size jets does it have in the carb?
Stanlee
PostPosted: 18:06 - 06 May 2020    Post subject: Winner! Reply with quote
Well gents:
starter or solenoid jammed and fried the electrics!
so:
renewed electrics
renewed solenoid
renewed coil
stripped starter motor and engine casing and re furbed
New boot for carb manifold
stripped carb and cleaned again
stripped and replaced all fuel line, filters and pump.
happy to say she starts runs and pulls like a 50cc train Very Happy
One happy 7 yr old and a happy Grandad can get back to real bikes.
Though it has proved its worth I fitted a large rake device and levelled the garden ready for turf!!
Thanks for the input chaps
link to video:
https://youtu.be/lFKkd-hu1pk
stay safe
Stannerz
The last post was made 6 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 96.39 Kb
