Lexmoto 125 completely dead?
h07swilkinson
PostPosted: 00:50 - 05 May 2020    Post subject: Lexmoto 125 completely dead? Reply with quote
Hi guys,
I've taken my Lexmoto out of storage today only to discover its completely dead, no power whatsoever, nothing is happening, no light, no clicking sound with the starter switch.
I've already looked at the kill switch, checked the battery with a multimeter, checked for corrosion on the terminals themselves, followed the wire to the ignition barrel and tested for output witch was also fine and checked the fuse.
I really can't put my finger on what the issue is, if it was the starter motor the lights on the clock would still illuminate, thinking it might be something the do with corrosion in the wiring itself?
any help would be much appreciated.
Thanks, Shaun
spottedtango
PostPosted: 12:49 - 05 May 2020    Post subject: Reply with quote
Hi there,
Have you tried shorting the starter relay, this basically proves if it’s a battery or an electrical fault.
Basically you’re connecting the battery straight to the starter motor and seeing if it turns. You do this by bridging the two terminals on the relay with a piece of wire. ( don’t do it with a screw driver, I’ve melted a few of them doing that)
If it doesn’t turn over then either the battery looks good on the multimeter but doesn’t have juice enough to turn it over
Or it’s a starter motor problem such as a bad earth, seized motor etc
If it does turn over it’s a wiring fault somewhere or it’s more than likely that the starter relay has went.
Riejufixing
PostPosted: 13:35 - 05 May 2020    Post subject: Re: Lexmoto 125 completely dead? Reply with quote
Get an old-fashioned headlamp bulb and connect it across thabattery terminals. If it's OK for a couple of minutes that's a good sign.
If you have a charger, connect that up. If it's not charging, that's a bad sign.
1198
PostPosted: 13:35 - 05 May 2020    Post subject: Reply with quote
Is there another fuse box somewhere with smaller fuses for lights, indicators, horn etc in addition to the one main one? I wouldn't be looking at the starter motor circuitry if nothing else works... Have you a bad earth somewhere? Can you check conductivity between the part that would connect to the battery and a frame rail? My Monster has a small lead that connects the negative terminal of the battery purely to the frame. It's simply bolted on, if that connection isn't good you won't get a circuit on any system?
spottedtango
PostPosted: 14:34 - 05 May 2020    Post subject: Reply with quote
I misread your text, I thought everything was lighting up but not turning over,
As the other guys have said look for a fuse first. In the main fuse holder or on the starter relay. Some bikes have a 30a one the relay which can pop.
WD Forte
PostPosted: 16:46 - 05 May 2020    Post subject: Reply with quote
Lexmoto what?
bikers smell of wee
Easy-X
PostPosted: 17:22 - 05 May 2020    Post subject: Reply with quote
WD Forte wrote:
Lexmoto what?
They're much of a muchness, TBH. Probably some "safety" switch like the kickstand... bit keen to cut all the power though Thinking
h07swilkinson
PostPosted: 07:16 - 07 May 2020    Post subject: Reply with quote
Thanks for your help guys, it turned out to be the Regulator wires, they were so corroded that they just fell off when I inspected them. When I stripped the earth wire to make a new connection the copper was as dark as a bankers soul.
Easy-X
PostPosted: 11:18 - 07 May 2020    Post subject: Reply with quote
...the copper was as dark as a bankers soul.
Lmao!
The last post was made 6 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 59.39 Kb
