deresrictor
phill.c
PostPosted: 17:47 - 31 Mar 2005    Post subject: deresrictor Reply with quote
well im just about to get my restrictors out tomorrow, but browsing on ebay and i came across a derestrictor and it says it will allow my bike to go over 180kmh, so is there already a standard restrictor in there? ive got a cbr400, and are they worth the pennies? where can i get a new one from or is it not worth getting a new one. also are they easy to fit?
cheers
phill
CBR400RR the funs started - Honda MTX 125 ongoing project when i can be arsed Smile
ZaphodBeeble
PostPosted: 17:57 - 31 Mar 2005    Post subject: Reply with quote
As far as I was aware you just have to remove the plates from between your carbs and the engine (inlet ports). The carbs may also require rejetting though but I'm not sure.
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
instigator
PostPosted: 18:13 - 31 Mar 2005    Post subject: Reply with quote
Its worth checking for the restriction washers firstly and if they aren't there, then buy the item, as I believe the cbr400 is derestricted differently (in some electronic form Confused)
EuropeanNC30R...
Gay Hairdresser
PostPosted: 18:24 - 31 Mar 2005    Post subject: Reply with quote
In short....
When the speedo needle hits 180kmph it passes through a little light-gate/similar that results in a message being sent to the CDI telling it to cut two cylinders. It's like hitting a brick wall.
Some bikes have had this disabled by bending back a tab in the speedo, some have plug-in boxes behind the speedo, some have plugin boxes going into the CDI. You can also get around it with a kph >mph converter, or by just disconnecting the speedo cable.
Don't try to blindly pull the wire out as it'll result in the bike misfiring above 5,000rpm (crude anti-tampering idea).
The last post was made 21 years, 233 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 39.27 Kb
