Yamaha dtr 125 head gasket problem !!!
Dtr12503
PostPosted: 01:15 - 06 May 2020    Post subject: Yamaha dtr 125 head gasket problem !!! Reply with quote
Hey this has been bugging me for some time .........so my head gasket keeps going on my dtr, I buy a genuine gasket and a few weeks later it goes again, the coolant overflows into my expansion tank until that fills up and goes through overflow (due to pressure in rad)
Didn’t bother me to much I would just make sure rad is topped up and don’t run dry, and of course a new gasket every month or so.
Decided to get head skimmed and barrel bored from 56m standard to 57m as there was a Nasty scratch down the barrel,
Now it’s all back together I rid the bike to work and noticed same problem, coolant overflowing, I’m assuming gasket gone again but this time it only took a day to go.
Why does the gasket keep going in the first place ?
Do I need a bigger gasket for the 1mm oversize bore ?
Thanks
Riejufixing
PostPosted: 08:24 - 06 May 2020    Post subject: Reply with quote
Have you tried previous answers?
Lots of information if you try this search with yoiur favourite search engine:
"yamaha dtr125 head gasket site:bikechatforums.com"
PostPosted: 09:28 - 06 May 2020    Post subject: Reply with quote
Do the head nuts need re-torquing after fitting on one of those?
I know on my enfield that I run the bike up to temperature after having the head off then re-torque and get another maybe 1/4 turn. Then I do them again at 5, 50 and 500 miles. I usually get about half a turn at 5 and 50 then maybe 1/4 turn at 500.
Anywhere else you could be getting pressure blowpast into the water jacket? They'd have noticed a cracked liner on the rebore.
Could it just be a straight overheat? Are the hoses getting hard with revs (I'd expect this with a significant head gasket leak)?
jeffyjeff
PostPosted: 10:24 - 06 May 2020    Post subject: Reply with quote
maybe that nasty scratch was masking a crack and the shop didn't look for it or see it.
salem1987
PostPosted: 11:49 - 06 May 2020    Post subject: Reply with quote
If dome nuts are fitted to the head without washers it will cause the leak as the nut goes tight too soon.
This was the problem i found on one that had the same symptoms.
Dtr12503
PostPosted: 15:04 - 06 May 2020    Post subject: Reply with quote
Thanks for reply’s , I can’t torque bolts down because of where it’s positioned, one of them can’t even get a socket on, have to use spanner, but I do try and cris cross evenly tightening them up with washers
Hoses are solid
as for the thermostat could be a good idea to get the infrared gun to check temp
I can remember if the inner circle of gasket was overlapping bore as I didn’t think of the oversize 1mm could effect it, plus how would I obtain one to fit my bike with a bigger inner.
PostPosted: 16:44 - 06 May 2020    Post subject: Reply with quote
Well, that's probably the problem then. You're probably a) Undertightening and b) Unevenly tightening.
You don't necessarily need a torque-wrench to torque them properly. Got a spring balance/luggage scale?
If it needs doing up to, say 30Nm, that means you need to apply 3kg of force on a lever 1m long. So from there you can work out how hard you need to pull on the spanner with the spring balance.
So work out from Nm by dividing by 10 to give you kg/m. Divide this by the distance the balance is from the centre of the nut in metres. So to do up a nut to 30Nm with the balance hooked onto the spanner 35cm from the nut, divide by 10 and multiply by 0.35. Pull until you see 8.57kg on the balance and you're there.
Or drop the engine down and do it properly with a torque wrench. I'm not a fan of them but this is one place you need accurate tightening.
Easy-X
PostPosted: 16:53 - 06 May 2020    Post subject: Reply with quote
Oh yeah, that's a usual problem with water cooled barrels: 3 out of the 4 nuts are accessible and the last is tucked away in a recess Sad
Get a standard torque wrench and this for the last one:
https://www.ebay.co.uk/itm/Crow-Foot-Crowsfeet-Wrench-Spanner-Set-3-8-Drive-10mm-22mm-on-Storage-Rail/362827867078
https://i.ebayimg.com/images/g/BBYAAOxyJs5RakRS/s-l500.jpg
bladerunner
PostPosted: 01:13 - 07 May 2020    Post subject: Reply with quote
deffo worth trying a different rad as well.Not like these bikes usually get coolant changed or are even run just with water for some time which causes the rads to block. I now have an RS125 rad on the RD125LC and thats over cooled now...easy fix with some tape at least Laughing Laughing
The last post was made 6 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 71.87 Kb
