| Dtr12503 |
 Dtr12503 Derestricted Danger
| Riejufixing |
 - Super Spammer
 Posted: 08:40 - 06 May 2020 Post subject: |
A few tips.
With a latex glove on, smear a very thin layer of Threebond on both sides of the genuine basket and make sure you fit it the correct way up.
If the head has been skimmed, I can't see the barrel warping, so are you torquing the head nuts in order and to the right setting?
I normally made the central circle a bit larger in the hard gaskets of my race bike, but this was 2.5mm overbore. Please the gasket over the barrel. Is there a lip that needs removing? I think at 1mm, you should be OK, but worth checking. Squish will be tight, so it could be the piston banging into the lip of the gasket.
I take it the cooling system is all in order and the thermostat isn't stuck shut? Those £7 infrared thermometer guns from Ebay are awesome at checking which parts of a cooling system are at what temperature. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Jaguar S Type 3.0 V6 Sport R, VW Transporter T5 GP LWB Shuttle 140ps DSG. |
 Posted: 09:28 - 06 May 2020 Post subject: |
Do the head nuts need re-torquing after fitting on one of those?
I know on my enfield that I run the bike up to temperature after having the head off then re-torque and get another maybe 1/4 turn. Then I do them again at 5, 50 and 500 miles. I usually get about half a turn at 5 and 50 then maybe 1/4 turn at 500.
Anywhere else you could be getting pressure blowpast into the water jacket? They'd have noticed a cracked liner on the rebore.
Could it just be a straight overheat? Are the hoses getting hard with revs (I'd expect this with a significant head gasket leak)? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jeffyjeff |
 jeffyjeff World Chat Champion
| salem1987 |
 salem1987 Scooby Slapper
| Dtr12503 |
 Posted: 16:44 - 06 May 2020 Post subject: |
| Dtr12503 wrote: | Thanks for reply’s , I can’t torque bolts down because of where it’s positioned, one of them can’t even get a socket on, have to use spanner, but I do try and cris cross evenly tightening them up with washers |
Well, that's probably the problem then. You're probably a) Undertightening and b) Unevenly tightening.
You don't necessarily need a torque-wrench to torque them properly. Got a spring balance/luggage scale?
If it needs doing up to, say 30Nm, that means you need to apply 3kg of force on a lever 1m long. So from there you can work out how hard you need to pull on the spanner with the spring balance.
So work out from Nm by dividing by 10 to give you kg/m. Divide this by the distance the balance is from the centre of the nut in metres. So to do up a nut to 30Nm with the balance hooked onto the spanner 35cm from the nut, divide by 10 and multiply by 0.35. Pull until you see 8.57kg on the balance and you're there.
Or drop the engine down and do it properly with a torque wrench. I'm not a fan of them but this is one place you need accurate tightening. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Easy-X |
 Easy-X Super Spammer
 - Super Spammer
 Posted: 20:56 - 06 May 2020 Post subject: |
Hoses are solid
as for the thermostat could be a good idea to get the infrared gun to check temp
I can remember if the inner circle of gasket was overlapping bore as I didn’t think of the oversize 1mm could effect it, plus how would I obtain one to fit my bike with a bigger inner. |
So it could yet be a broken cooling system, maybe a knackered water pump impeller or stuck shut thermostat too.
Check that first, if the coolant is circulating, take the engine out and do the head gasket properly. It’s an hour’s work at most.
I just increase the hole in the head gasket by going round it with a grinding stone on a Dremmel. I don’t think they sell over bore genuine head gaskets. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
| bladerunner |
 Posted: 01:13 - 07 May 2020 Post subject: |
deffo worth trying a different rad as well.Not like these bikes usually get coolant changed or are even run just with water for some time which causes the rads to block. I now have an RS125 rad on the RD125LC and thats over cooled now...easy fix with some tape at least  ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
The last post was made 6 years, 126 days ago. Instead of replying here, would creating a new thread be more useful? |
