1985 Honda Melody Delux stuck on full revs
Jacknz
PostPosted: 18:27 - 09 May 2020    Post subject: 1985 Honda Melody Delux stuck on full revs Reply with quote
Hi all,
Recently I purchased a Honda Melody which was in pretty reasonable running condition. It was running slightly rough so I thought I'd give the carb a clean.
After filling the reservoir with fuel and reinstalling it I was able to get it started again with some difficulty, but unfortunately its stuck on full revs and if I dropped it off the stand it'd fly through the fence.
After googling I thought it could be the carb slide but after tinkering with it I can confirm it is in the right position, the idle screw is also fully unscrewed.
Really not sure what it could be, as it was idling fine just before I cleaned the carb I must have installed it incorrectly. If anyone has any ideas about what I could do that'd be much appreciated.
Cheers,
Jack
Tankie
PostPosted: 18:55 - 09 May 2020    Post subject: Reply with quote
Throttle cable ends not seated correctly in carb or twistgrip
So the throttle slide is visually at the bottom of its range of movement, resting on the idle screw?
Is the needle still in position in the bottom of the throttle slide? They can get pushed up as you insert them.
Easy-X
PostPosted: 12:29 - 10 May 2020    Post subject: Reply with quote
Did you remember to put the spring back in? Wink
Seriously though, take off the airbox and hose and work the throttle and see if it's moving up and down smoothly. If it's at all "crunchy" there might be a bit of grit jamming up the slide.
The last post was made 6 years, 135 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 39.43 Kb
