| 09dudharb |
 09dudharb Derestricted Danger
 Posted: 19:28 - 23 Apr 2020 Post subject: |
I used Alkyd resin paint on my enfield frame recently. Sticks like shit to a blanket. Would use again.
It's effectively old fashioned machine enamel. Mostly used for farm machinery and painting skips these days (how much tougher do you want?).
Old brit bikes in the 1940's and 50's used to have their frames dipped in this stuff, most of them are still on their original paint.
Apply direct to metal. I was going to brush paint mine but it was a bit thick so I put it through the spray gun instead. It dries quick but I'd give it a week to cure (it's a resin, they chemically cure after drying) before fitting engines and stuff so it hardens properly.
Tractol 329 is one brand of alkyd resin machine enamel available in aerosols. It'll give you a tough and tidy finish quite easily with minimal faffing about using multiple coatings.
Some paint sold as machine enamel is polyurethane. This is also tough but it's not the same stuff.
https://lh3.googleusercontent.com/V44j6Rx2jZKtv3NY3enr3jlR7eRBsTR1fYmP_HXxkt9N8FudzhHMp4tEM2PVcQy1x_Nr38ca60A6T2mBG_wK017Ou3vls82BglYHVJMiP3xrBDdUe8UJns339j2x0E1LTUs5TmyRCw=w1155-h866-no
That said, if you want a very high quality finish, you're probably going to want 2k paint over a zinc primer. Respirator essential! (not face mask, and they are the type of P3 respirator the NHS is using for covid so if you don't already have one...)
However I would say it's a GS500 here. They came out of the factory with a single optimistic spray-over with something cheap and porous. Anything you use will be better than what it came with. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Riejufixing |
| spottedtango |
 spottedtango Trackday Trickster
| Easy-X |
 Easy-X Super Spammer
| 09dudharb |
 Posted: 13:55 - 09 May 2020 Post subject: |
You wouldn't normally laquer over machine enamel.
More is more when it comes to coats up to a point. Maybe have a poke at an inobtrusive bit and see what you think. It cures pretty hard.
I think I put 4 coats on mine but I have a spray gun so loads of paint to spare.
Pics? We like pics of peoples projects. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| 09dudharb |
| 09dudharb |
| 09dudharb |
 Posted: 22:33 - 09 May 2020 Post subject: |
Looked into bending box section but the bender and die are extremely expensive!
You got me thinking though... Not sure if I previously mentioned in the thread but I have a donar bike... There is a section on the gs frame that you remove to drop the engine. Just so happens it has the perfect curve and some straight box! Could chop that up. Found a pic of the part im talking about which ill attach.
So cut off my *call it a prototype* and see if I can get that curved section welded on and a cross beam a little further down... What are your thoughts on flux core wire? I've never used it before but run out of argon |
| P.addy |
 P.addy Red Rocket
 Posted: 01:29 - 10 May 2020 Post subject: |
I'm afraid I'm not great at welding. I do seagull-shite stick welding. I just know I could bend that thickness of flatbar by hand and that there is a lot more lateral force on a subframe when you're cornering than you'd expect.
While I'm not a frame builder either, I reckon even a single bit of that box as a cross-brace would be fine. If the bent bit of flat steel is just to hold a tailpiece and not be particularly load-bearing, it's fine. The frame is well triangulated in the vertical axis anyway and it's a monoshock so all the chassis force is forwards of there (there was a similarly chopped twinshock frame posted a couple of weeks ago that was actively dangerous).
But yes, if you could have a bent bit of box arching up (or down), it would be as strong as the original bracing.
Given the way this is heading, you're probably going to go for a single seat with a hump so plan how that's going to look, your brace could form the profile of the hump? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| 09dudharb |
| 09dudharb |
| 09dudharb |
 Posted: 12:08 - 10 May 2020 Post subject: |
Oil on hot metal will work on cast iron/steel, it's called "japanning". Not so sure about alloy. I think it would just go dull.
They do a matt finish in that simonize paint. If you want a really chalky matt finish, you could use brush-on wood stove paint but I find it less robust. PJ1 is also popular, although I think the simonize is more forgiving to apply. Just did Mrs stinkwheels exhaust with it. I am also a fan of plastikote, they do a woodstove and BBQ paint. I use that on a lot of parts.
Whatever paint you use needs to be VHT (very high temperature) paint. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Easy-X |
| Riejufixing |
| Riejufixing |
| 09dudharb |
| 09dudharb |
The last post was made 6 years, 152 days ago. Instead of replying here, would creating a new thread be more useful? |
