| Alecf66 |
 Alecf66 L Plate Warrior
| iooi |
 iooi Super Spammer
 Posted: 20:54 - 13 May 2020 Post subject: |
Try the workshop..... ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Fisty |
 Fisty Super Spammer
| Alecf66 |
This post is not being displayed because it has a low rating (Boring). Unhide this post / all posts.
| Fisty |
 Fisty Super Spammer
| stinkwheel |
 Posted: 00:08 - 14 May 2020 Post subject: |
Instead of buying a load of jets, you can get jet drills and sequentially drill one out until it's right (then usually overshoot but you only need to buy one more jet then).
But it's not necessarily just the jet, depends what it's doing at what throttle opening position. The main jet itself is only really concerned with 3/4 to full throttle. Needle position, needle jet, slide cutout and slow running jet all play variably significant parts at other throttle openings. To do it properly, you need to mark the throttle twistgrip and sequentially do road tests with the throttle at different openings then changing one thing at a time to see what works best (which alters everything you did before slightly). Main jet diameter is usually last.
However. My main quesion is was it running ok on the standard setup? Because I wouldn't expect a basic, low compression OHV single to be THAT fussy about its airbox. Yes it might need fine tuning a bit for a pod filter but not to the point where it's bogging. CG125 airboxes are not accoustically tuned for pressure waves and laminar flow, the airbox is mostly to give it some still, clean air to breathe and to keep the induction noise down.
If it wasn't running right before, you're starting in the wrong place.
Sure you have the choke off? (getting the off and on positions wrong is a really common mistake on CG125s). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Easy-X |
 Easy-X Super Spammer
 Posted: 00:34 - 14 May 2020 Post subject: |
With all due respect, you're not giving us much to go on Things like what year the bike is. What's this eBay carb? A knock-off of the original, something completely different, uprated size? Stock exhaust? Have you got the original airbox? If you do, does it run okay with it on?
I suspect we're missing the words "Café Racer"
Anyhoo, I've only really seen cookie-cutter jet choices for the off-road scene where every combo's been done to death. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Alecf66 |
| stinkwheel |
 Posted: 10:22 - 14 May 2020 Post subject: |
So has it ever run right? Is the replacement carb even correct for the bike? I'd check by checking how it IS jetted and how it's supposed to be jetted.
You may be able to get a carb repair kit for the bike which would have all the correct brasswork (tubes, jets and needles) for a standard carb. Might not be a bad plan. They are relatively cheap. NOT from china! Wemoto do them for under £20.
If I was a mechanic, I wouldn't touch a bike with a random cheap ebay carb and pod filters with the smelly end of a shitty stick. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Easy-X |
 Posted: 12:34 - 14 May 2020 Post subject: |
Picture of the bike, carb and exhausts would be good. Did you buy this as an unfinished project by any chance?
As an aside I'm reminded of a recent Tiff Needell video: F4 car, "it needs a bit of choke to start..." and he throws a rag over the air filter
"That's too much air!" Well, yes and no. You have a more free flowing system (air in and straight exhaust out) you balance it out with more fuel. So cheer up, that means moar powa, baby The downside is you may lose your sanity before you find the right combo of adjustments
Whatever jet that's in there is wrong so just buy bigger. If it's a #110 then buy half a dozen sizes above, e.g. 115, 120, 125 etc. (I have no idea what sort of carb, your numbers might be different.) Keep swapping till it starts performing more to your liking and then go one jet bigger. Richer = safer. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Alecf66 |
| Easy-X |
 Posted: 00:04 - 16 May 2020 Post subject: |
Haha! Called it
Anyhoo, thankfully that carb's so basic it may as well be made of wood Some sort of old-skool Keihin knockoff at a guess.
Pay careful attention to the jet type: short screw, long screw, hex-style or whatever as quite often the friendly merchants will say they have your ones and then send over some Mikunis  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| P.addy |
 P.addy Red Rocket
 Posted: 18:34 - 16 May 2020 Post subject: |
Well I bet that sounds fucking annoying.
Be cheaper to get the airbox and standard pipe or another bike vs getting that one running properly. |
| Alecf66 |
| stinkwheel |
 Posted: 22:59 - 16 May 2020 Post subject: |
In fairness, I'd also be cagey about how well made a complete carb that cost less than a genuine kehin throttle slide is.
Thought that should be at least mentioned. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Easy-X |
The last post was made 6 years, 162 days ago. Instead of replying here, would creating a new thread be more useful? |
