Paint for an exhaust (what one)
pepperami
PostPosted: 21:12 - 14 May 2020    Post subject: Paint for an exhaust (what one) Reply with quote
So as some of you may be aware, I’ve been twatting about with a spare exhaust for my bike.
After much swearing, drilling, grinding, and tack-welding in new bolts to the silencer , I have a complete, tatty, but usable spare exhaust.
I now want to smarten up the down pipes and collector box.
So after a wire brush up and a clean up, I want to paint them.
So oh mighty BCF, do you have any recommendations?
Any particular product or brand of uht paint?
Thumbs Up Thumbs Up
xX-Alex-Xx
PostPosted: 22:39 - 14 May 2020    Post subject: Reply with quote
Have you thought about wrapping rather than paint? I've painted the pipes on my 929 before I replaced the system and it looked naff, even with a decent job.
DILLIGAF
PostPosted: 22:45 - 14 May 2020    Post subject: Reply with quote
Plastikote woodstove paint.
Just did Mrs stinkwheels exhaust with simonize VHT but never used it on an exhaust before. Seems to cope with enfield cylinder barrely well though.
Both are very easy to apply.
Mr Hammers
PostPosted: 22:46 - 14 May 2020    Post subject: Re: Paint for an exhaust (what one) Reply with quote
You mean paint the collector box, not the downpipes.. do you?
It's just i've yet to come across a really decent HT paint - at least out of all the ones i've tried so far, i'm sure someone will know of a good one, but nothing will stick to the downpipes. It'd burn off after a day's riding.
The best i've tried, or least worst, was oven/woodburner paint. I don't remember the brand i'm afraid. Although it held ok, it didn't really have a nice finish.
A Guide To Powerbands
kolu
PostPosted: 23:32 - 14 May 2020    Post subject: Reply with quote
if pepperami wants, I have bit of unused exhaust wrap at home
https://www.ebay.co.uk/itm/132848389262
should be at least 5 m I guess, with 6 unused cable ties...
pepperami
PostPosted: 23:34 - 14 May 2020    Post subject: Reply with quote
Nah! It’s the old pipes, they’re usable if needed.
Clean em up, paint them and put them away until needed.
pepperami
PostPosted: 23:38 - 14 May 2020    Post subject: Reply with quote
Thank you for the offer, but give it to someone more deserving Thumbs Up
Appreciated Thumbs Up
pepperami
PostPosted: 23:39 - 14 May 2020    Post subject: Reply with quote
Oven/wood burner paint it is then Thumbs Up
Thank you chaps!
Bru
PostPosted: 20:18 - 15 May 2020    Post subject: Reply with quote
Maybe too late, but I second the Simoniz VHT paint. Other paints seem to be 'dusty' like the Halfords offering, when dry - before heat curing (using the exhaust). Simoniz dries like a conventional paint, ie. not 'dusty' or easy to wipe off, and has proved quite enduring on my collector. Definitely longer-lived than others I have tried. Not downpipes I admit, but close enough.
Easy-X
PostPosted: 00:09 - 16 May 2020    Post subject: Reply with quote
Good shout, I've done some exhaust bits in stove paint and you have to be a bit careful with it once it's dry but not yet had a blast of heat, quite easy to chip a bit off.
Islander
PostPosted: 11:59 - 16 May 2020    Post subject: Reply with quote
+1 for the Plastikote woodstove paint. It's a doddle to apply and produces an excellent finish. It does need heat to cure properly. Thumbs Up
ThatDippyTwat
PostPosted: 12:40 - 16 May 2020    Post subject: Reply with quote
MIPAtherm.
Lasts well on the Viffers downpipes. spray and brush on, oven (pipes) and air cure also available, check the spec sheets.
https://www.mipa-paints.com/fileadmin/product/gb/pi/lm/Mipatherm.pdf
pepperami
PostPosted: 12:59 - 16 May 2020    Post subject: Reply with quote
Thank you people Thumbs Up
pepperami
PostPosted: 13:02 - 16 May 2020    Post subject: Reply with quote
What about a hot air gun if kept at a sensible distance?
PostPosted: 13:06 - 16 May 2020    Post subject: Reply with quote
Ideal would be to bolt it back on the bike and run the engine for 5-10 minutes.
pepperami
PostPosted: 14:23 - 16 May 2020    Post subject: Reply with quote
Absolutely agree,
However the faff of getting the whole fairing off, getting the new exhaust off, blah blah blah!, not going down that road Tut Tut
Hot air gun it is.
Luckyfish133
PostPosted: 11:31 - 17 May 2020    Post subject: Reply with quote
https://ctc-powder-coating.co.uk/high-performance-ceramic-coatings/
The stuff's expensive, but ceramic coating's the way forward bro!
'99 VFR800 - XT125R
The last post was made 6 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 93.37 Kb
