Battery and ignition issues
Callumrayb
PostPosted: 22:05 - 17 May 2020    Post subject: Battery and ignition issues Reply with quote
so i recently bought a keeway superlight 2011 with 7500 miles on the clock, and a spare engine plus frame for quite cheap.
the spare engine is a later model efi k157fmi
im going to put a big bore kit on it and use the carb and maybe do a rejet. now the issue i am having is that to start the bike i need to kickstart it as there is no power, i changed the battery, fired up fine out the workshop but when i powered it off and tried restarting there was no electrical power. no neutral or indicator lights working. it seems like the battery died but i tested it and its at the correct voltages. i have made sure it is grounded correctly i dont know much about electrics so any help would be appreciated!
Hiiii
Easy-X
PostPosted: 03:25 - 18 May 2020    Post subject: Reply with quote
Check the fuses Smile
Callumrayb
PostPosted: 12:04 - 18 May 2020    Post subject: Reply with quote
Easy-X wrote:
Check the fuses :)
where is the fuse box located on the superlight? i cant find any info on this bike its kinda annoying
Hiiii
Easy-X
PostPosted: 12:33 - 18 May 2020    Post subject: Reply with quote
It's a generic Chinese bike, they're all much of a muchness.
Take off the plastic side panels and seat and a good chunk of the electrics are exposed for inspection. IIRC the fuses are under the nearside plastic panel.
Callumrayb
PostPosted: 13:28 - 18 May 2020    Post subject: Reply with quote
Thank you so much I checked the small red box leading from the positive terminal and a little fuse was in there but it had come away. Pushed it back in and the bike start d straight away! Thanks!
Hiiii
The last post was made 6 years, 148 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.79 - MySQL Queries: 13 - Page Size: 43.47 Kb
