Need help with carburetor
Liuuu
PostPosted: 19:50 - 29 May 2020    Post subject: Need help with carburetor Reply with quote
What is the purpose of these 3?
PostPosted: 20:25 - 29 May 2020    Post subject: Reply with quote
At a guess a vent, an overflow and a tip-over drain. Traditionally all routed to atmosphere or the road but on more modern stuff, probably re-circulated into a closed system to reduce emissions.
One of them might be a take-off for a pulse air device, again emissions.
No idea which is which or if that's even correct. What's it off?
jaffa90
PostPosted: 21:34 - 29 May 2020    Post subject: Reply with quote
Could that be a water cooled carb? (never seen one).
xX-Alex-Xx
PostPosted: 21:40 - 29 May 2020    Post subject: Reply with quote
If it's for water, it'll be not cooling but warming to stop icing in bad weather.
Otherwise take-offs for vacuum hoses? I only do FI, fuck carbs sideways - too much hassle.
DILLIGAF
PostPosted: 21:41 - 29 May 2020    Post subject: Reply with quote
Usually water heating for anti-icing. Never seen one set up like that but its possible. It's usually a lot more Heath-Robinson, couple of plastic spigots with rubber hose between them running through a bank of carbs.
I'm guessing that carb's off an aircooled single of some sort though? So carb icing unlikely to be an issue.
jaffa90
PostPosted: 22:55 - 29 May 2020    Post subject: Reply with quote
Yes, both correct, crazy really because you need heated carbs / fuel mixture before starting as in electric heated carbs.
PostPosted: 23:33 - 29 May 2020    Post subject: Reply with quote
Not so much, carb icing only usually happens when large volumes of cold, moist air are being drawn through the carb. Usually also requires it to have been drawing large volumes of vapourising fuel for a while too to cool down the internals. So the classic situation is as you wind off the throttle to pull off a motorway on a chilly, damp winters night. The vapourising fuel has chilled the point of the throttle needle to below zero, you wind off and the moisture condenses in the airbox then next time you open the throttle a big gulp of cold damp air leads to an ice crystal forming on the end of the throttle needle. Bike stutters and conks out.
It's not the fuel that freezes, its moisture in the air charge. Petrol has a flash point of -45C. You aren't going to get carb icing at startup.
steve the grease
PostPosted: 14:10 - 30 May 2020    Post subject: Reply with quote
The little pipe is a breather I guess. The two identical pipes go to a vertical chamber that is plugged at the top with a brass plug. Looks like it is water cooling, whether that is connected up for our mild UK climate is another thing. Carb icing can, rarely, be a problem in the UK, I have experienced it on one of my vehicles. Curiously enough there is a post about a Honda C110 on here. Some of these had the carb heated by the rocker oil feed from the engine, which went via the carb ( lots of copper washers required).
stirlinggaz
PostPosted: 18:20 - 02 Jun 2020    Post subject: Reply with quote
jaffa90 wrote:
Could that be a water cooled carb? (never seen one.
No?
Comes as standard on a Yamaha TDR 125, I have a couple of Mikuni TM28 ss carbs which have the 2 pipes for water HEATING which just circulates the coolant/water from rad.
I won't upload the pic as it's huge, but I'm sure you can Google the Mikuni & you'll see it.
I had to join the 3 hoses together when I junked the carb for a Dellorto vhsa32 which doesn't have that function.
cheers,
GAZ
The last post was made 6 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 61.1 Kb
